How to set ip static on graylog 3.1.0-6
Dear,
I can’t set ip static interface ens160 on graylog vm , after power on vm guest i don’t know command for set ip static.
I tried to do follow command linux still doesn’t work.
Please advise me.
you might want to check the documentation:
http://docs.graylog.org/en/3.1/pages/installation/virtual_machine_appliances.html#run-the-image
I tried to do as document but still can’t set ip address , edit file \etc\network\interfaces then reboot after show no ip address (refer pic below)
Please advise me.
Hi jan,
I tried to do as document still doesn’t work , can you help guide me step by step set ip static on vm graylog ?
Thank you in advance.
