How I can monitor Graylog nodes and cluster in grafana?
I would like to monitor all Graylog nodes and its health and also monitor Cluster (3 nodes) in Grafana… Is there a way or any guide to follow and configure monitoring of infrastructure ? Any suggestion without installing any additional tools ?
  • OS Information: Linux
  • Package Version: 4.3.3
I have done this past couple months.
Enable Prometheus in Graylog Config file shown here.
Once that done install Grafana I used this here
I logged into Grafana and enable the Prometheus Plugin.
Just create a dashboard after that, should be good.
Thanks @gsmith … does that metrics also has something related to disk space of the node or services status ?
There is a nice Grafana dashboard for Graylog metrics (built by @aaronsachs) which is linked in the discussion here.
Thanks guys for quick response and help.
