Dear graylog community, my dashboard in graylog showsthe latest logs with gl2_rempoe_ip, application name, timestamp,source (the host that send the log), loglevel etc… after filtering through pipelines and rules. I’d like to have this data exported in a form to use it with prometheus for alertig (e.g. if the number of logs of a host is increasing / reaching a general limit or by loglevel).
An additional metric could look like this - or similar - just to get an idea:
# HELP gl_host_logs counter for logs by reporting host
# TYPE gl_host_logs gauge
gl_host_logs{ip="192.168.0.5", host="hostname", loglevel="3", facility="kernel" } 42
- OS Information: Debian 12, deployment via docker
- Package Version: Graylog 6.0.5, MongoDB 6.0.14, Opensearch 2.12.0
- Already enabled the built-in prometheus exporter in graylog.conf like
prometheus_exporter_enabled = trueandprometheus_exporter_bind_address = 0.0.0.0:9833
- Enabled the ports in docker-compose.yml like
- "9833:9833"- I can access the metrics like http://server.domain.de:9833/api/prometheus/metrics
- Also already included this endpoint to my prometheus server like
- job_name: 'graylog_exporter'
metrics_path: /api/prometheus/metrics
scrape_interval: 1m
scrape_timeout: 1m
file_sd_configs:
- files:
- /opt/monitoring/graylog_exporter/graylog_exporter_targets.yml
- Where the graylog_exporter_targets.yml looks like
- targets:
- 'server.domain.de:9833'
labels:
category: graylog
- But the provided logs do not fit my needs
Note: For now I used the Grafana Dashboard from asachs01 and modified it a little so it shows my values - seems to be still working, but only covering a small set of metrics provided by the built-in exporter.
- Is there a way in graylog to just make additional metrics / more information available in the build-in prometheus exporter? (I believe not)
- If not, maybe there is a way to access the graylog api and write a script to extract the metrics myself - one could just setup a small webserver on another port to povide additional metrics - has anyone done that already / is willing to share some scripts?
Best regards,
justeverything
