Monitoring Graylog
Dear All,
I was wanting to monitor Graylog servers. I plan to use the the graylog metrics plugin reporting to elasticsearch as shown here
I was going to use this to send the metrics to a separate linux server with elasticsearch and grafana installed on it.
Does anyone here have any experience of setting this up / pitfalls I should be aware of?
Cheers
Jake
the main problem is - elasticsearch is not a metric storage.
I can understand from one point that you do not want to add another piece of software to your stack - but it is like going on the race track with a jeep. Yes it is working but the fun starts in a racing car …
HI Jan,
I have settled on a Prometheus and Grafana setup for monitoring Graylog. I am using the prometheus Graylog plugin. It seems to work well and we have some nice dashboards in Grafana.
I was looking at using this prometheus exporter to monitor elasticsearch - see https://github.com/justwatchcom/elasticsearch_exporter.
What are your thoughts?
Do you know if anyone else is using this?
Cheers
Jake
