Graylog using blank screen on web interface
Hi all,
I’ve managed to get Graylog running on a server and the Graylog Web Interface loads as expected using an internal IP address but shows a blank screen when using our external IP address (http: //178.238.141.207:9000). Any idea what may be causing the issuing? Perhaps something that I’ve omitted in the server.conf file. I’ve provided an error snapshot here.
Below is snippet of the server.conf which I believe is the relevant section.
#### HTTP bind address
#### HTTP publish URI
# The HTTP URI of this Graylog node which is used to communicate with the other Graylog nodes in the cluster and by $
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and conn$
# This configuration setting has to be used if this Graylog node is available on another network interface than $htt$
# If $http_bind_address contains a wildcard IPv4 address (0.0.0.0), the first non-loopback IPv4 address of this mach$
# This configuration setting *must not* contain a wildcard address!
# Default: http ://$http_bind_address/
#http_publish_uri = http ://178.238.141.207:9000/
#### External Graylog URI
# When using Graylog Collector, this URI will be used to receive heartbeat messages and must be accessible for all c$
# Default: $http_publish_uri
#http_external_uri =  http ://178.238.141.207:9000/
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
HTTP bind address
HTTP publish URI
This configuration setting must not contain a wildcard address!
This setting can be overriden on a per-request basis with the “X-Graylog-Server-URL” HTTP request header.
Your help and input would be greatly appreciated. If you need any more information regarding the above then please let me know and I’ll be willing to assist.
Best regards,
Mike.
You have set those options however, you haven’t un-commented the lines so, your values aren’t being applied.
Hi
Thanks for your prompt response I’ve un-commented those the lines as described but still get the same issue.
Another issue I forgot to mention in my original post is that I can’t send any logs to the Graylog Inputs with the settings 'GELF/UDP’. I’ve also provided the relevant IP address too. Any idea why that might be happening?
Thanks and best regards,
Mike.
Have you made all the adjustments with rules/ports/NAT etc with your firewall? Describe the entire path the data should take take. If your inputs aren’t receiving (Your other post) it is likely the same issue with how you have your firewall set up? Be careful to remove data in your posts that the public shouldn’t see… more detail always helps - particularly if it is formatted.
Thanks for all your suggestions, we’ve managed to resolve the issue. The problem was with how Graylog was setup on our webhost’s server. The javascript files which is responsible for rendering the Graylog user interface was prefixed with our webhost’s internal IP number, so even though we used our external IP number to load the Graylog web interface, it still made no difference. In the end we contacted our webhost to create a domain name for our Graylog server and that seemed to fix it.
Hope this helps anyone else having similar issues.
Best regards,
Mike.
