Hello!
My graylog works fine, but sometimes the web gui doesn’t open.
After reboot, graylog will work again.
Pfsense ip: port => graylog ip: 9000
Hello @Galymzhan can you post this portion of your server.conf, specifically I am interested in
http_bind_address
http_publish_uri
http_external_uri
http_publish_uri = http://$http_bind_address/
#http_external_uri =
Per the documentation
# This configuration setting *must not* contain a wildcard address!
Installed http_bind_address = graylog lan ip: 9000 and reloaded graylog.
systemctl restart graylog-server
While working.
Thanks!
Doesn’t work again. What to do?
My problem is still not resolved. Help me please. Graylog still opens with a blank screen.
Sorry about your issue. For us to help you further we would need some more information.
Please take a look at this post and it will clarify on what is needed to get a quicker response.
Since the issue is sporadic, and a reboot (presumably only of Graylog Server) gets things working, I’d suggest:
As mentioned, more information would be useful.
yum info graylog-server
Installed Packages
Arch : noarch
Version : 4.1.3
Release : 1
Repo : installed
From repo : graylog
Summary : Graylog server
URL : https://www.graylog.org/
License : SSPL
Description : Graylog server
cat /etc/redhat-release
CentOS Linux release 7.9.2009 (Core)
mongod --version
db version v4.2.15
curl -XGET 'http://localhost:9200'
"name" : "XXX.XXX.loc",
"cluster_name" : "graylog",
"cluster_uuid" : "-------",
"version" : {
"number" : "7.10.2",
"build_flavor" : "oss",
"build_type" : "rpm",
"build_hash" : "747---",
"build_date" : "2021-01-13T00:42:12.435326Z",
"build_snapshot" : false,
"lucene_version" : "8.7.0",
"minimum_wire_compatibility_version" : "6.8.0",
"minimum_index_compatibility_version" : "6.0.0-beta1"
"tagline" : "You Know, for Search"
firewall-cmd --list-all
ports: 10051/tcp 9000/tcp 10000-20000/udp 5044/tcp 5045/tcp
grep -vE '(^[[:space:]]*([#;!].*)?$)' /etc/graylog/server/server.conf
is_master = true
password_secret = Password
root_password_sha2 = rootPassword
root_timezone = Asia/Tashkent
http_bind_address = 192.168.X.X:9000
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
transport_email_hostname = smtp.gmail.com
transport_email_port = 587
transport_email_use_auth = true
transport_email_auth_username = XXXX@gmail.com
transport_email_auth_password = emailPassword
transport_email_subject_prefix = [graylog_email]
transport_email_from_email = XXXX@gmail.com
transport_email_use_tls = true
ls -lh /usr/share/graylog-server/plugin
total 209M
-rw-r--r--. 1 root root 22M Aug 4 21:02 graylog-plugin-aws-4.1.3.jar
-rw-r--r--. 1 root root 6.8M Aug 4 21:02 graylog-plugin-collector-4.1.3.jar
-rw-r--r--. 1 root root 54M Aug 4 21:03 graylog-plugin-enterprise-4.1.3.jar
-rw-r--r--. 1 root root 17K Aug 4 21:03 graylog-plugin-enterprise-es6-4.1.3.jar
-rw-r--r--. 1 root root 17K Aug 4 21:03 graylog-plugin-enterprise-es7-4.1.3.jar
-rw-r--r--. 1 root root 35M Aug 4 21:04 graylog-plugin-enterprise-integrations-4.1.3.jar
-rw-r--r--. 1 root root 32M Aug 4 21:03 graylog-plugin-integrations-4.1.3.jar
-rw-r--r--. 1 root root 2.4M Aug 15 08:27 graylog-plugin-telegram-notification-2.3.6.jar
-rw-r--r--. 1 root root 8.2M Aug 4 21:02 graylog-plugin-threatintel-4.1.3.jar
-rw-r--r--. 1 root root 23M Aug 4 21:02 graylog-storage-elasticsearch6-4.1.3.jar
-rw-r--r--. 1 root root 29M Aug 4 21:02 graylog-storage-elasticsearch7-4.1.3.jar
-rw-r--r--. 1 root root 48 Aug 4 21:03 LICENSE-ENTERPRISE
top
top - 10:41:22 up 54 days, 22:25, 1 user, load average: 0.00, 0.01, 0.06
Tasks: 225 total, 1 running, 224 sleeping, 0 stopped, 0 zombie
%Cpu(s): 2.5 us, 1.6 sy, 0.0 ni, 95.7 id, 0.1 wa, 0.0 hi, 0.2 si, 0.0 st
KiB Mem : 16266128 total, 2365780 free, 5250100 used, 8650248 buff/cache
KiB Swap: 4063228 total, 3914236 free, 148992 used. 10250156 avail Mem
In my case I did not define this, I left it commented out
cat /etc/graylog/server/server.conf | grep http_publish_uri
#http_publish_uri = http://192.168.1.1:9000/
# Default: $http_publish_uri
What shows in the Graylog server log when you go to the UI and get the error?
Make sure to show only what is relevant and use the forum tools such as </> to help with formatting
thank you, @tmacgbay
/var/log/graylog-server/server.log nothing, only errors:
ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
If there are no errors and you have a blank web page check your firewall rules. For troubleshooting purposes save your IPTABLES configuration. Once saved set all your chain/s to ACCEPT (Chain OUTPUT (policy ACCEPT), Chain INPUT (policy ACCEPT) ).
Save configuration and restart iptables but In your case Firewalld.
While you at it check you Selinux for any errors.
If your Selinux is enabled either forced or passive you can find out if there is any problems by executing this command
# sealert -a /var/log/audit/audit.log
If none of those work check permissions on Graylog directory . Make sure Graylog has access.
Question have you tried to comment out what @tmacgbay suggested earlier and restart Graylog service?
@gsmith
Hello!
Thanks for the help!
After rebooting the graylog service, everything works fine for me until a certain time. I don’t know exactly how many minutes it works, say, for example, 30 minutes.
SELinux is disabled.
#sestatus
SELinux status: disabled
Firewalld all required ports are open. I cannot turn off firewalld due to other systems (Asterisk, FreePBX, Zabbix-docker).
services: http https sip ssh
ports: 10051/tcp 9000/tcp 8081/tcp 5060/udp 5061/udp 5060/tcp 5061/tcp 4569/udp 5038/tcp 5038/udp 10000-20000/udp 5044/tcp 5045/tcp
Graylog permissions
# ls -lh /etc/graylog/
total 0
drwxr-xr-x. 2 root root 84 Nov 3 08:45 server
# ls -lh /etc/graylog/server/
total 71M
-rw-r--r-- 1 root root 71M Sep 30 01:57 GeoLite2-City.mmdb
-rw-r--r--. 1 root root 1.9K Aug 4 21:02 log4j2.xml
-rw-r--r--. 1 root root 37 Aug 14 21:22 node-id
-rw-r--r-- 1 root root 35K Nov 2 10:25 server.conf
At the moment, my server.conf is like this
is_master = true
password_secret = xxxxxx
root_password_sha2 = xxxxx
http_bind_address = 192.168.x.x:9000
ring_size = 65536
transport_email_auth_username = xxxxx@gmail.com
transport_email_auth_password = xxxxx
transport_email_from_email = xxxx@gmail.com
Yes I commented out http_publish_uri and reloaded the graylog service. But it did not help.
I think that if Elasticsearch and mongodb connect to graylog locally, then there is no need to open ports 9200, 9300, 27017 on firewalld
These are all running on the same machine as Graylog/MongoDB/Elastic? That’s more than I would want to put on a single machine - too much risk of conflict and (unless perhaps, it’s testing) difficult to work on particularly during business hours. Check for conflicts… web UI, inputs…
