Problem Accessing Graylog webinterface via NAT
I’m currently trying out Graylog. I am trying to set it up so that it can be accessible outside via NAT. Currently I have set my router to allow port 9000 and point it to the same port of the server. I can access the web interface via local lan without problems but when accessing it via the internet I just get a blank screen. I would much appreciate any help. Kindly see details on my installation below:
Ubuntu 16.04
Graylog 3.1.2
Elastic Search 6
Thanks,
JC
The same here. Browsers Firefox on Windows 10, and Chrome on Android.
Ok, got it. You should set http_external_uri = http://your-external-ip:9000/ in server.conf file.
Thanks Karlis will try to do that.
this community has already multiple options for that. But in the end you need to have the http_external_uri or a specific header that points your browser to the Graylog API to retrieve data.
Hi Jan,
I was able to make it work using the DNS fix.
Thanks for the follow up.
Regards,
JC
