Unable to access web interface from the same network
Hello All, I am new to Graylog. I am unable to access the server via the web interface. I recently install ed Graylog on Ubuntu 19.10. In the config under http settings I made some changes and restarted/enabled both elastic search and Graylog server. I have even rebooted several times.
I will like to access Graylog from both the same machine it is on as well as from other machines on the same local network. I can access the web interface if I set everything to 127.0.0.1.
Any help is appreciated.
Here are the changes I have made (I have also tried different combinations):
http_bind_address
#Default: 127.0.0.1:9000
#http_bind_address = http://127.0.0.1:9000
#Changed to the local ip address
http_bind_address = http://10.0.0.237:9000
http_publish_uri
Default: http://$http_bind_address/
http_publish_uri = 10.0.0.237:9000
http_external_uri
Default: $http_publish_uri
http_external_uri = 10.0.0.237:9000
Please let me know which of these I am getting wrong and also if there is anything else besides these that I need to check.
please show output of
ip -br a
lsof -Pni :9000
ip -br a:
lo UNKNOWN 127.0.0.1/8 ::1/128
enp0s25 UP 10.0.0.237/24 2601:2c7:580:6190::b3f8/128 2601:2c7:580:6190:24ed:2ec2:bf48:7c5f/64 2601:2c7:580:6190:e7e5:a8ae:f9e0:a382/64 fe80::4e2f:a9d9:664e:3fb3/64
lsof -Pni :9000:
blank (no output)
Thanks…
Correct
to
http_bind_address = 10.0.0.237:9000
Hi zoulja,
Thanks! I made those changes and still not able to access from the same machine. I have included some screenshots.
A screenshot of terminal (ifconfig)
screenshot of config file
Hello All,
I am able to access it now! Thanks.
I put back the hash tags in front of http_publish_address and http_external_url so that they defaulted to the bind address and it is working now.
he @judel5
http_bind_address is an adress - like written EVERYWHERE and http_publish_uri and http_external_uri are URLS - that need the protocol added. Like written above the setting in the configuration file OR the documentation …
The default will add this silently … but if you but in a value that is used.
You would have seen that in the Graylog server.log …
