Graylog Datanode TLS/SSL Provision Certificate for Grafana Opensearch Connection
When using the opensearch docker container previously grafana was able to access the opensearch database using basic credentials. Currently there is no access due to my inability to find a way to provision certificates to the datanode database.
I’m using Docker and the “official” Graylog Docker Compose file.
3. How can the community help?
Does anyone know of a way to connect grafana with the new datanode as it’s form of security has changed to use certificates.
Main question:
Is there a way to provision a cert to the datanode for third party or self hosted applications?
Currently no, but it is on the near term roadmap.
Thank you @Joel_Duffield!
Looking forward to this.
In the meantime, is there a way to export the CA used by graylog so I can authenticate with it?
Grafana has the option to authenticate with a CA Cert, and because of the certificate generation and renewal process, I assume that’s what graylog is using to securely connect to graylog datanode instances.
In the meantime, I will look around on my own to see if I can find a way to export and authenticate with this info.
I dont think so, at least i havent heard of anyone doing it successfully. Good news is that 6 is only a month away
