Graylog Data Node 6.0.3 Certificate
I am getting yellow alerts on shards being unassigned and I want to see via the curl commands to the API what exactly is causing it but I don’t know where Graylog creates the certificate for GL Data Node.
  • OS Information:
    ubuntu 22.04 LTS
  • Package Version:
    6.0.3 via Docker Compose
If anyone knows what folder Graylog creates the Graylog Data Node certificate at. This is the certificate that is auto created by Graylog.
@spardok
In Graylog, you can go to System → Data Nodes → Configuration where you can generate a client certificate to be used for authenticating against the data node’s Opensearch.
Alternatively, you can use the Graylog REST API which offers an endpoint proxying a subset of requests to the datanode’s Opensearch (POST /datanodes/{hostname}/opensearch/{path: .*}) .
In case this is useful, here is our Documentation page on this topic:
https://go2docs.graylog.org/current/downloading_and_installing_graylog/install_graylog_data_node.htm
This talks specifically about Creating a Client Certificate for Third-Party Tools (such as curl).
Thank you both for the response.
@doktormo the GUI creation of the certificate is exactly what I had done previously, and that is the cert that I want to use to authenticate against Opensearch, but I have no idea where that cert is stored so I don’t know what path to use when calling it.
@drewmiranda-gl I see that the documentation has how to create the cert, including the way @doktormo suggested, but I do not see any indication of where that cert is then stored.
When you click on the ‘Generate client certificate button’
a modal popup appears.
Once you click on ‘Create Certification’, the text of the certificates is shown:
The text of these certificates can be copy/pasted and saved into a text file.
Well that explains that, I do not remember having to go through this when I did the initial set up for the first cert.
Thank you.
