Graylog datanode to Grafana
I get “Failed to connect to server” when I try to configure grafana-opensearch-datasource
I have tried localhost, 127.0.0.1, 192.168.xx.xx with port 9200 and get the same error.
user@ubuntu3:~$ curl localhost:9200/
curl: (52) Empty reply from server
So, I can’t even run the curl command on the graylog server, either.
Your datanode server is most likely listening on https only, not plaintext http. That’s why you don’t get any response on 9200 port.
You will also need client certificates to access it: Graylog Datanode: admin access using client certification
I’m able to use curl to connect with https but I still can’t get connected from Grafana.
ahmuser@ubuntu3:/etc/graylog/certs$ curl “https://ubuntu3.network.local:9200/_cluster/health?pretty” -k --cert client-cert.crt --key client-cert.key --cacert CA.crt
Enter PEM pass phrase:
“cluster_name” : “datanode-cluster”,
“status” : “green”,
“timed_out” : false,
“number_of_nodes” : 1,
“number_of_data_nodes” : 1,
“discovered_master” : true,
“discovered_cluster_manager” : true,
“active_primary_shards” : 12,
“active_shards” : 12,
“relocating_shards” : 0,
“initializing_shards” : 0,
“unassigned_shards” : 0,
“delayed_unassigned_shards” : 0,
“number_of_pending_tasks” : 0,
“number_of_in_flight_fetch” : 0,
“task_max_waiting_in_queue_millis” : 0,
“active_shards_percent_as_number” : 100.0
I think Grafana has problems with password protected keys. This could be related to Allow Data Node Client Cert to have a blank password · Issue #23171 · Graylog2/graylog2-server · GitHub
Maybe also disable the basic auth in the connection dialog?
I have successfull connect my graylog-datanode with these settings:
With Client-Certificate, no basic auth would be needed.
please be aware of the runtime for your client certificate. :slight_smile:
