Feeding data from Graylog/Elasticsearch into Grafana
Following up on Connecting Graylog to Grafana via Elastisearch now that the 6.0 version is live.
Just trying to figure out the configuration required to connect graylog to grafana :smiley:
  • OS Information: Ubuntu 20.04 - Docker 20.10.21
  • Package Version: 6.0.2
Graylog Docker compose.yml used:
I can attach grafana’s configuration if needed.
Attempted configuring a client certificate via https://[graylogAddress]/system/datanodes/configuration, adding an elasticsearch source in grafana, entering the CA, private key, and client cert.
(Error grafana shows is “Elasticsearch error: Bad Gateway”)
I’m attempting to find a way to just simply feed data from graylog 6 into grafana. Previously this worked by just connecting Elasticsearch to grafana.
I know graylog 6 requires auth to connect to datanodes, just trying to get to the bottom of that.
Hey @brink
I have connected Grafana to Graylog, by using Elasticsearch plugin on Grafana.
But not Graylog to Grafana .
Yeah I think that’s the opposite direction from what I’m attempting to do.
I want to use the elasticSearch DataSource in Grafana to feed data from Graylog to Grafana. This is a thing that was achievable before, just trying to figure out what changed since I last did it in Graylog 4. :slight_smile:
I’m also going to tag @Joel_Duffield as he had responded to the previous thread on this topic, and I hope he can give us some guidance here.
Ya with datanode there is a new feature that you theoretically can make it work, but datanode is still mostly in beta so there isnt a ton of documentation or tribal knowledge about it yet. If possible i would continue to run graylog with just regular opensearch and connect the same way as before.
Dang, I was hoping someone would know. Ah well.
I’ll continue taking swings at it and post a thread if I figure out it. Thanks all!
