Graylog as Grafana datasource
Hi all, I’m trying to add Graylog as Grafana datasource, but no succes so far. Is it still possible to integrate Grafana with the new Graylog Opensearch datanode?
I got it working by using a seperate opensearch service instead of the graylog datanode.
Any plans on making the Opensearch service accessible through the datanode api or allow/provide direct access? This way we could start using Grafana with the datanode as a datasource.
Managed to get this working by using the official OpenSearch grafana datasource plugin using TLS authentication with a Graylog generated client certificate (for 3rd party tools).
@jefvt I cant tell from your last comment if you used Graylog’s certifiicate management to enable certificate authorization to allow 3rd party access to Data Node API. There is a previous discussion here on it: Connecting Grafana to OpenSearch data node
Hi @SethG, yes implemented as described in the documentation and works like a charm. Thank you for your reply.
