Connecting Grafana to OpenSearch data node
I am unable to connect from Grafana to the Graylog OpenSearch data node.
  • OS Information:
    Ubuntu 22.04 LTS (VM)
  • Package Version:
    Graylog Enterprise 6.1.1. Clean install.
    Grafana 11.3 with Opensearch plug in 2.21.1
In datanode.conf, set opensearch http listen address to 9200 and tried connecting from Grafana with no authentication
In Grafana, set port to 9000, authentication to basic and used Graylog login
Please post settings will work to connect.
I think you have to use certificate authentication for any 3rd party tools you.want to connect to datanode, there is a section in the docs about setting it up.
Thank you @Joel_Duffield
