Fresh installation on RH8 - index default error
Hi. I’ve installed graylog 4 with required packages:
elasticsearch.x86_64 7.0.1-1
graylog-server.noarch 4.0.5-1
java-1.8.0-openjdk-headless.x86_64 1:1.8.0.282.b08-2.el8_3
mongodb-org.x86_64 4.2.13-1.el8
mongodb-org-mongos.x86_64 4.2.13-1.el8
mongodb-org-server.x86_64 4.2.13-1.el8
mongodb-org-shell.x86_64 4.2.13-1.el8
mongodb-org-tools.x86_64 4.2.13-1.el8
It looks like it should work but not at all works. I have problem with index default. I’ve tried to recreate environment, but problem still occurs. Can you give some advises? Firewall and selinux are disabled.
Gui works with errors:
Could not retrieve global index stats.
Fetching global index stats failed: cannot GET http://<IP_address>:9000/api/system/indices/index_sets/stats (500)
Could not retrieve index sets.
Fetching index sets list failed: Unable to retrieve list of closed indices for [graylog_*]
ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchException: Unable to retrieve list of closed indices for [graylog_]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.exceptionFrom(ElasticsearchClient.java:136) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:99) ~[?:?]
at org.graylog.storage.elasticsearch7.cat.CatApi.perform(CatApi.java:89) ~[?:?]
at org.graylog.storage.elasticsearch7.cat.CatApi.requestIndices(CatApi.java:85) ~[?:?]
at org.graylog.storage.elasticsearch7.cat.CatApi.indices(CatApi.java:60) ~[?:?]
at org.graylog.storage.elasticsearch7.IndicesAdapterES7.closedIndices(IndicesAdapterES7.java:295) ~[?:?]
at org.graylog2.indexer.indices.Indices.getClosedIndices(Indices.java:266) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.getClosedIndices(Indices.java:270) ~[graylog.jar:?]
at org.graylog2.indexer.IndexSetStatsCreator.getForIndexSet(IndexSetStatsCreator.java:38) ~[graylog.jar:?]
at java.util.stream.Collectors.lambda$toMap$58(Collectors.java:1321) ~[?:1.8.0_282]
at java.util.stream.ReduceOps$3ReducingSink.accept(ReduceOps.java:169) ~[?:1.8.0_282]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948) ~[?:1.8.0_282]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482) ~[?:1.8.0_282]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472) ~[?:1.8.0_282]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:1.8.0_282]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_282]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:566) ~[?:1.8.0_282]
at org.graylog2.rest.resources.system.indexer.IndexSetsResource.list(IndexSetsResource.java:153) ~[graylog.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_282]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_282]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_282]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_282]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:124) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:167) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:219) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:79) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:469) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:391) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:80) ~[graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:253) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:232) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:680) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_282]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_282]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_282]
Caused by: org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ResponseException: method [GET], host [http://127.0.0.1:9200], URI [/cat/indices/graylog
?format=json&h=index%2Cstatus&s=index%2Cstatus&expand_wildcards=all], status line [HTTP/1.1 400 Bad Request]
{“error”:{“root_cause”:[{“type”:“illegal_argument_exception”,“reason”:“request [/cat/indices/graylog] contains unrecognized parameter: [expand_wildcards]"}],“type”:“illegal_argument_exception”,“reason”:"request [/cat/indices/graylog] contains unrecognized parameter: [expand_wildcards]”},“status”:400}
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.convertResponse(RestClient.java:302) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:272) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
at org.graylog.storage.elasticsearch7.cat.CatApi.lambda$perform$4(CatApi.java:92) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:97) ~[?:?]
… 43 more
2021-03-29T14:51:01.698+02:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchException: Unable to retrieve list of closed indices for [gl-system-events_, graylog_, gl-events_]
at org.graylog2.rest.resources.system.indexer.IndexSetsResource.globalStats(IndexSetsResource.java:175) ~[graylog.jar:?]
Caused by: org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ResponseException: method [GET], host [http://127.0.0.1:9200], URI [/cat/indices/gl-system-events
,graylog_,gl-events_?format=json&h=index%2Cstatus&s=index%2Cstatus&expand_wildcards=all], status line [HTTP/1.1 400 Bad Request]
{“error”:{“root_cause”:[{“type”:“illegal_argument_exception”,“reason”:“request [/cat/indices/gl-system-events,graylog_,gl-events_] contains unrecognized parameter: [expand_wildcards]"}],“type”:“illegal_argument_exception”,“reason”:"request [/cat/indices/gl-system-events,graylog_,gl-events_] contains unrecognized parameter: [expand_wildcards]”},“status”:400}
… 33 more
Hi @dkryszak
Running a manual “curl” in my end with the same URI in the error log I get this:
curl -s -H 'Content-Type: application/json' -XGET "x.x.x.x:9200/cat/indices/graylog?pretty"
  "error" : {
    "root_cause" : [
        "type" : "index_not_found_exception",
        "reason" : "no such index [cat]",
        "resource.type" : "index_expression",
        "resource.id" : "cat",
        "index_uuid" : "_na_",
        "index" : "cat"
    "index" : "cat"
  "status" : 404
With an error in “cat”, as you can see. But even with the righ “command”, it runs with error:
curl -s -H 'Content-Type: application/json' -XGET "x.x.x.x:9200/_cat/indices/graylog?pretty"
  "error" : {
    "root_cause" : [
        "reason" : "no such index [graylog]",
        "resource.type" : "index_or_alias",
        "resource.id" : "graylog",
        "index" : "graylog"
    "index" : "graylog"
  "status" : 404
The right way is:
curl -s -H ‘Content-Type: application/json’ -XGET “x.x.x.x:9200/_cat/indices/graylog_*?pretty”
Try to modify this in your end to see if works.
Hi @reimlima . Thanks for reply. I’ve resolved the issue. Problem was with elastic search version. After upgrade from 7.0.1 to 7.12.0 problem has disappeared.
FYI, Elasticseach version 7.11 and up is not officially suported:
https://docs.graylog.org/en/4.0/pages/configuration/elasticsearch.html#elasticsearch-versions
