Could not retreve global index stats & index sets?
Is there a way to fix this problem ?
thanks in advance
is elastic running and configured for graylog to access?
I forgot to say that i delete default index and all indices.Can I recreate all over again?
My setup is working with 2 ES nodes servers(thay are green)
Is there a way to reconfigure all over without need to reinstall?
Update: so i purge graylog and mongo from ubuntu svr. , and also two separate elasticsearch end install again manualy from tar and use same server.cofig but the error remain ? How’s that posible?
I delete graylog mongo elaastic purge everything…then search for file leftovers also delete all …and install all over again and got the same error msg like on screen above…What is my solution in this situation?
