Kubernetes install of Graylog not able to create indexes in elasticsearch
I am trying to install graylog into our new kubernetes cluster. I have elasticsearch up running version 6.8.3 and health check is green. Elasticsearch is running secure with certs and auth. I have configured the graylog.conf with the auth connection string and have imported the certs into the keystore to trust.
example: elasticsearch_hosts = https://elastic:password@elasticsearch-host:9200
From the graylog pod, I am able to manually create/delete/view indexes using the connection string listed in the graylog.conf. However when graylog starts - there are no logs received on the elasticsearch server and no indexes created.
The logs on the graylog server show:
019-10-04 15:51:02,799 INFO [MongoIndexSet] - Did not find a deflector alias. Setting one up now. - {}
2019-10-04 15:51:02,805 INFO [IndexRetentionThread] - Elasticsearch cluster not available, skipping index retention checks. - {}
2019-10-04 15:51:02,777 ERROR [IndexFieldTypePollerPeriodical] - Uncaught exception in periodical - {}
org.graylog2.indexer.IndexNotFoundException: Couldn’t collect indices for alias graylog_deflector
Index not found for query: . Try recalculating your index ranges.
This is followed by this error repeatedly:
2019-10-04 15:51:02,810 ERROR [IndexRotationThread] - Couldn’t point deflector to a new index - {}
org.graylog2.indexer.IndexNotFoundException: Couldn’t collect aliases for index pattern graylog_*
at org.graylog2.indexer.cluster.jest.JestUtils.buildIndexNotFoundException(JestUtils.java:118) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:84) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:57) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:62) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.getIndexNamesAndAliases(Indices.java:314) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.getNewestIndexNumber(MongoIndexSet.java:151) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.getNewestIndex(MongoIndexSet.java:146) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.setUp(MongoIndexSet.java:252) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.checkAndRepair(IndexRotationThread.java:138) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:76) ~[graylog.jar:?]
at java.lang.Iterable.forEach(Iterable.java:75) [?:1.8.0_222]
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:73) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
When I login to the graylog server and go to “Overview” the Elasticsearch status show “Elasticsearch cluster is green”.
I created an Input and graylog is receiving logs, but I can’t search them of course since nothing is going to elasticsearch.
I have been troubleshooting this for several days and at a loss - any help is appreciated.
graylog.conf:
node_id_file = /usr/share/graylog/data/journal/node-id
root_username = admin
root_email =
root_timezone = UTC
plugin_dir = /usr/share/graylog/plugin
http_external_uri = https://graylog.domainurl.net/
elasticsearch_hosts = https://elastic:password@graylog-es-http:9200
elasticsearch_max_retries = 10
elasticsearch_compression_enabled = true
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_dir = /usr/share/graylog/data/journal
mongodb_uri = mongodb://graylog_admin:password@mongodb:27017/graylog
transport_email_enabled = false
transport_email_hostname =
transport_email_port = 2587
transport_email_use_auth = true
transport_email_use_tls = true
transport_email_auth_username =
transport_email_auth_password =
transport_email_from_email =
transport_email_web_interface_url = https://graylog.domainurl.net
content_packs_dir = /usr/share/graylog/data/contentpacks
Graylog Startup Logs:
Launching graylog-0 as master
pod/graylog-0 labeled
Starting graylog
Graylog Home /usr/share/graylog
JVM Options -Djava.net.preferIPv4Stack=true -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -XX:+UnlockExperimentalVMOptions -XX:+UseCGroupMemoryLimitForHeap
2019-10-04 16:57:00,688 INFO [CmdLineTool] - Loaded plugin: AWS plugins 3.1.2 [org.graylog.aws.AWSPlugin] - {}
2019-10-04 16:57:00,692 INFO [CmdLineTool] - Loaded plugin: Collector 3.1.2 [org.graylog.plugins.collector.CollectorPlugin] - {}
2019-10-04 16:57:00,693 INFO [CmdLineTool] - Loaded plugin: Threat Intelligence Plugin 3.1.2 [org.graylog.plugins.threatintel.ThreatIntelPlugin] - {}
2019-10-04 16:57:01,388 INFO [CmdLineTool] - Running with JVM arguments: -Djava.net.preferIPv4Stack=true -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -XX:+UnlockExperimentalVMOptions -XX:+UseCGroupMemoryLimitForHeap -Dlog4j.configurationFile=/usr/share/graylog/config/log4j2.xml -Djavax.net.ssl.trustStore=/k8s/truststore.jks -Djava.library.path=/usr/share/graylog/lib/sigar/ -Dgraylog2.installation_source=docker - {}
2019-10-04 16:57:02,111 INFO [Version] - HV000001: Hibernate Validator 5.1.3.Final - {}
2019-10-04 16:57:09,315 INFO [InputBufferImpl] - Message journal is enabled. - {}
2019-10-04 16:57:09,388 INFO [NodeId] - Node ID: d667ce38-136d-4f36-8762-c5bec671209b - {}
2019-10-04 16:57:09,985 INFO [LogManager] - Loading logs. - {}
2019-10-04 16:57:10,075 WARN [Log] - Found a corrupted index file, /usr/share/graylog/data/journal/messagejournal-0/00000000000000000000.index, deleting and rebuilding index… - {}
2019-10-04 16:57:10,191 INFO [LogManager] - Logs loading complete. - {}
2019-10-04 16:57:10,205 INFO [KafkaJournal] - Initialized Kafka based journal at /usr/share/graylog/data/journal - {}
2019-10-04 16:57:10,288 INFO [cluster] - Cluster created with settings {hosts=[mongodb:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000} - {}
2019-10-04 16:57:10,414 INFO [cluster] - Cluster description not yet available. Waiting for 30000 ms before timing out - {}
2019-10-04 16:57:10,878 INFO [connection] - Opened connection [connectionId{localValue:1, serverValue:14764}] to mongodb:27017 - {}
2019-10-04 16:57:10,894 INFO [cluster] - Monitor thread successfully connected to server with description ServerDescription{address=mongodb:27017, type=REPLICA_SET_PRIMARY, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 12]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=6954221, setName=‘rs0’, canonicalAddress=mongodb-primary-0.mongodb-headless.graylog.svc.cluster.local:27017, hosts=[mongodb-primary-0.mongodb-headless.graylog.svc.cluster.local:27017, mongodb-secondary-0.mongodb-headless.graylog.svc.cluster.local:27017], passives=, arbiters=[mongodb-arbiter-0.mongodb-headless.graylog.svc.cluster.local:27017], primary=‘mongodb-primary-0.mongodb-headless.graylog.svc.cluster.local:27017’, tagSet=TagSet{}, electionId=7fffffff0000000000000002, setVersion=3, lastWriteDate=Fri Oct 04 16:57:04 UTC 2019, lastUpdateTimeNanos=83553118154519} - {}
2019-10-04 16:57:11,011 INFO [connection] - Opened connection [connectionId{localValue:2, serverValue:14765}] to mongodb:27017 - {}
2019-10-04 16:57:11,679 INFO [InputBufferImpl] - Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers. - {}
2019-10-04 16:57:12,209 INFO [AbstractJestClient] - Setting server pool to a list of 1 servers: [https://graylog-es-http:9200] - {}
2019-10-04 16:57:12,210 INFO [JestClientFactory] - Using multi thread/connection supporting pooling connection manager - {}
2019-10-04 16:57:12,407 INFO [JestClientFactory] - Using custom ObjectMapper instance - {}
2019-10-04 16:57:12,408 INFO [JestClientFactory] - Node Discovery disabled… - {}
2019-10-04 16:57:12,408 INFO [JestClientFactory] - Idle connection reaping disabled… - {}
2019-10-04 16:57:12,408 INFO [JestClientFactory] - Authentication cache set for preemptive authentication - {}
2019-10-04 16:57:12,900 INFO [ProcessBuffer] - Initialized ProcessBuffer with ring size <65536> and wait strategy . - {}
2019-10-04 16:57:13,605 WARN [GeoIpResolverEngine] - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb - {}
2019-10-04 16:57:13,626 INFO [OutputBuffer] - Initialized OutputBuffer with ring size <65536> and wait strategy . - {}
2019-10-04 16:57:13,886 WARN [GeoIpResolverEngine] - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb - {}
2019-10-04 16:57:13,998 INFO [connection] - Opened connection [connectionId{localValue:3, serverValue:14766}] to mongodb:27017 - {}
2019-10-04 16:57:14,107 WARN [GeoIpResolverEngine] - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb - {}
2019-10-04 16:57:14,273 WARN [GeoIpResolverEngine] - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb - {}
2019-10-04 16:57:14,378 WARN [GeoIpResolverEngine] - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb - {}
2019-10-04 16:57:17,299 INFO [ServerBootstrap] - Graylog server 3.1.2+9e96b08 starting up - {}
2019-10-04 16:57:17,300 INFO [ServerBootstrap] - JRE: Oracle Corporation 1.8.0_222 on Linux 4.19.66-coreos - {}
2019-10-04 16:57:17,300 INFO [ServerBootstrap] - Deployment: docker - {}
2019-10-04 16:57:17,300 INFO [ServerBootstrap] - OS: Debian GNU/Linux 10 (buster) (debian) - {}
2019-10-04 16:57:17,300 INFO [ServerBootstrap] - Arch: amd64 - {}
2019-10-04 16:57:17,424 INFO [PeriodicalsService] - Starting 29 periodicals … - {}
2019-10-04 16:57:17,424 INFO [Periodicals] - Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s]. - {}
2019-10-04 16:57:17,475 INFO [Periodicals] - Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever. - {}
2019-10-04 16:57:17,551 INFO [PeriodicalsService] - Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node. - {}
2019-10-04 16:57:17,554 INFO [Periodicals] - Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s]. - {}
2019-10-04 16:57:17,576 INFO [Periodicals] - Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s]. - {}
2019-10-04 16:57:17,589 INFO [Periodicals] - Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever. - {}
2019-10-04 16:57:17,599 INFO [Periodicals] - Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s]. - {}
2019-10-04 16:57:17,611 INFO [Periodicals] - Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s]. - {}
2019-10-04 16:57:17,613 INFO [Periodicals] - Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s]. - {}
2019-10-04 16:57:17,616 INFO [Periodicals] - Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s]. - {}
2019-10-04 16:57:17,618 INFO [Periodicals] - Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s]. - {}
2019-10-04 16:57:17,638 INFO [Periodicals] - Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s]. - {}
2019-10-04 16:57:17,650 INFO [Periodicals] - Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s]. - {}
2019-10-04 16:57:17,685 INFO [Periodicals] - Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s]. - {}
2019-10-04 16:57:17,694 INFO [Periodicals] - Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever. - {}
2019-10-04 16:57:17,706 INFO [Periodicals] - Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever. - {}
2019-10-04 16:57:17,727 INFO [Periodicals] - Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s]. - {}
2019-10-04 16:57:17,894 INFO [PeriodicalsService] - Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node. - {}
2019-10-04 16:57:17,894 INFO [Periodicals] - Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever. - {}
2019-10-04 16:57:17,980 INFO [Periodicals] - Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever. - {}
2019-10-04 16:57:17,986 INFO [connection] - Opened connection [connectionId{localValue:8, serverValue:14773}] to mongodb:27017 - {}
2019-10-04 16:57:17,986 INFO [connection] - Opened connection [connectionId{localValue:6, serverValue:14770}] to mongodb:27017 - {}
2019-10-04 16:57:18,006 INFO [Periodicals] - Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever. - {}
2019-10-04 16:57:18,027 INFO [Periodicals] - Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s]. - {}
2019-10-04 16:57:18,031 INFO [connection] - Opened connection [connectionId{localValue:4, serverValue:14769}] to mongodb:27017 - {}
2019-10-04 16:57:18,035 INFO [connection] - Opened connection [connectionId{localValue:7, serverValue:14771}] to mongodb:27017 - {}
2019-10-04 16:57:18,036 INFO [LegacyDefaultStreamMigration] - Legacy default stream has no connections, no migration needed. - {}
2019-10-04 16:57:18,037 INFO [connection] - Opened connection [connectionId{localValue:5, serverValue:14772}] to mongodb:27017 - {}
2019-10-04 16:57:18,106 INFO [connection] - Opened connection [connectionId{localValue:10, serverValue:14775}] to mongodb:27017 - {}
2019-10-04 16:57:18,107 INFO [connection] - Opened connection [connectionId{localValue:11, serverValue:14776}] to mongodb:27017 - {}
2019-10-04 16:57:18,116 INFO [connection] - Opened connection [connectionId{localValue:9, serverValue:14774}] to mongodb:27017 - {}
2019-10-04 16:57:18,124 INFO [Periodicals] - Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s]. - {}
2019-10-04 16:57:18,170 INFO [Periodicals] - Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s]. - {}
2019-10-04 16:57:18,176 INFO [Periodicals] - Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s]. - {}
2019-10-04 16:57:18,182 INFO [Periodicals] - Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s]. - {}
2019-10-04 16:57:18,190 INFO [Periodicals] - Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [0s], polling every [28800s]. - {}
2019-10-04 16:57:18,207 INFO [Periodicals] - Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s]. - {}
2019-10-04 16:57:18,271 INFO [Periodicals] - Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s]. - {}
2019-10-04 16:57:19,114 INFO [MongoIndexSet] - Did not find a deflector alias. Setting one up now. - {}
2019-10-04 16:57:19,126 INFO [IndexRetentionThread] - Elasticsearch cluster not available, skipping index retention checks. - {}
2019-10-04 16:57:19,086 ERROR [IndexFieldTypePollerPeriodical] - Uncaught exception in periodical - {}
at org.graylog2.indexer.indices.Indices.aliasTarget(Indices.java:336) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.getActiveWriteIndex(MongoIndexSet.java:204) ~[graylog.jar:?]
at org.graylog2.indexer.fieldtypes.IndexFieldTypePoller.poll(IndexFieldTypePoller.java:73) ~[graylog.jar:?]
at org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical.lambda$doRun$2(IndexFieldTypePollerPeriodical.java:120) ~[graylog.jar:?]
at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:407) ~[graylog.jar:?]
at org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical.doRun(IndexFieldTypePollerPeriodical.java:111) ~[graylog.jar:?]
2019-10-04 16:57:19,178 ERROR [IndexRotationThread] - Couldn’t point deflector to a new index - {}
I got this working my downgrading elasticsearch to version 6.7.2 - all worked after that.
So this page - https://docs.graylog.org/en/3.1/pages/configuration/elasticsearch.html
Did not work for me. I tried 6.8.1, 6.8.2, and 6.8.3 and none of them worked. I go back to 6.7.2 and it all works.
I guess
I guess that this is the issue:
Woot!! This is awesome! Thank you for posting - it is working great!
Good thing too, cause 6.7.2 wasn’t clustering well - so 6.8.3 is where I wanted to be!
Thanks again!!!
