Graylog on docker and aws ES can't connect
( note: removed :// from links due to forum limitation )
I am stuck with this issue for more than 1 day now and don’t have any more ideas, some help if greatly appreciated.
Running the latest 2.3 graylog with mongo 3 in aws ECS with the official images and trying to connect it to the VPC enabled ES offered by amazon.
From all my tests the connection works fine if I manually try to run something from the graylog docker to ES but graylog doesn’t seem to be able to connect/communicate properly with ES 5.5 (also tried with ES 5.3, same issue).
All commands below are executed from the graylog docker
The cluster is healthy:
root@015f497a62c8:/usr/share/graylog# curl https vpc-stage-graylog-vzurm4fj2yg62didfh5l64zeoy.eu-west-1.es.amazonaws. com/_cluster/health?pretty=true
      "cluster_name" : "534996215098:stage-graylog",
      "status" : "green",
      "timed_out" : false,
      "number_of_nodes" : 4,
      "number_of_data_nodes" : 2,
      "active_primary_shards" : 1,
      "active_shards" : 2,
      "relocating_shards" : 0,
      "initializing_shards" : 0,
      "unassigned_shards" : 0,
      "active_shards_percent_as_number" : 100.0
I can send a test mesage to ES:
root@015f497a62c8:/usr/share/graylog# curl -X POST 'https vpc-stage-graylog-vzurm4fj2yg62didfh5l64zeoy.eu-west-1.es.amazonaws. com/tutorial/helloworld/1' -d '{ "message": "Hello World!" }'
{"_index":"tutorial","_type":"helloworld","_id":"1","_version":1,"result":"created","_shards":{"total":2,"successful":2,"failed":0},"created":true}
However the graylog-internal template is missing:
    root@015f497a62c8:/usr/share/graylog# curl -X GET 'https vpc-stage-graylog-vzurm4fj2yg62didfh5l64zeoy.eu-west-1.es.amazonaws. com//_template/graylog-internal?pretty'
These are the config values I overwrite from docker:
environment:
  - name: "GRAYLOG_ELASTICSEARCH_HOSTS"
    value: "https vpc-stage-graylog-vzurm4fj2yg62didfh5l64zeoy.eu-west-1.es.amazonaws. com/"
  - name: "GRAYLOG_MONGODB_URI"
    value: "mongodb://mongodb/graylog"
  - name: "GRAYLOG_WEB_ENDPOINT_URI"
    value: "https graylog-stage.domain. com/api/" # this connection is done trough haproxy, it works fine, can login
This is what graylog overview is saying:
Elasticsearch cluster is green. Shards: 0 active, 0 initializing, 0 relocating, 0 unassigned,
Here are the graylog logs:
08:32:40
2017-10-26 08:32:40,265 INFO : io.searchbox.client.AbstractJestClient - Setting server pool to a list of 1 servers: [https vpc-stage-graylog-vzurm4fj2yg62didfh5l64zeoy.eu-west-1.es.amazonaws. com/]
08:32:40
2017-10-26 08:32:40,266 INFO : io.searchbox.client.JestClientFactory - Using multi thread/connection supporting pooling connection manager
08:32:40
2017-10-26 08:32:40,409 INFO : io.searchbox.client.JestClientFactory - Using custom ObjectMapper instance
08:32:40
2017-10-26 08:32:40,409 INFO : io.searchbox.client.JestClientFactory - Node Discovery disabled...
08:32:40
2017-10-26 08:32:40,409 INFO : io.searchbox.client.JestClientFactory - Idle connection reaping disabled...
08:32:41
2017-10-26 08:32:41,939 INFO : org.graylog2.users.RoleServiceImpl - Admin role is missing or invalid, re-adding it as a built-in role.
08:32:42
2017-10-26 08:32:42,083 INFO : org.graylog2.users.RoleServiceImpl - Reader role is missing or invalid, re-adding it as a built-in role.
08:32:42
2017-10-26 08:32:42,748 INFO : org.graylog2.shared.buffers.ProcessBuffer - Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
08:32:45
2017-10-26 08:32:45,255 INFO : org.graylog2.bindings.providers.RulesEngineProvider - No static rules file loaded.
08:32:46
2017-10-26 08:32:46,052 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
08:32:46
2017-10-26 08:32:46,060 INFO : org.graylog2.buffers.OutputBuffer - Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
08:32:46
2017-10-26 08:32:46,077 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
08:32:46
2017-10-26 08:32:46,092 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
08:32:46
2017-10-26 08:32:46,107 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
08:32:46
2017-10-26 08:32:46,119 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:3, serverValue:3}] to mongodb:27017
08:32:46
2017-10-26 08:32:46,130 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
08:32:47
2017-10-26 08:32:47,792 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server 2.3.2+3df951e starting up
08:32:47
2017-10-26 08:32:47,793 INFO : org.graylog2.bootstrap.ServerBootstrap - JRE: Oracle Corporation 1.8.0_141 on Linux 4.9.43-17.38.amzn1.x86_64
08:32:47
2017-10-26 08:32:47,793 INFO : org.graylog2.bootstrap.ServerBootstrap - Deployment: docker
08:32:47
2017-10-26 08:32:47,793 INFO : org.graylog2.bootstrap.ServerBootstrap - OS: Debian GNU/Linux 9 (stretch) (debian)
08:32:47
2017-10-26 08:32:47,793 INFO : org.graylog2.bootstrap.ServerBootstrap - Arch: amd64
08:32:47
2017-10-26 08:32:47,805 WARN : org.graylog2.shared.events.DeadEventLoggingListener - Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
08:32:48
2017-10-26 08:32:48,004 INFO : org.graylog2.shared.initializers.PeriodicalsService - Starting 26 periodicals ...
08:32:48
2017-10-26 08:32:48,006 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
08:32:48
2017-10-26 08:32:48,022 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [60s].
08:32:48
2017-10-26 08:32:48,029 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
08:32:48
2017-10-26 08:32:48,035 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
08:32:48
2017-10-26 08:32:48,044 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical, running forever.
08:32:48
2017-10-26 08:32:48,045 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
08:32:48
2017-10-26 08:32:48,060 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
08:32:48
2017-10-26 08:32:48,063 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
08:32:48
2017-10-26 08:32:48,073 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
08:32:48
2017-10-26 08:32:48,077 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
08:32:48
2017-10-26 08:32:48,080 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
08:32:48
2017-10-26 08:32:48,082 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
08:32:48
2017-10-26 08:32:48,091 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
08:32:48
2017-10-26 08:32:48,100 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
08:32:48
2017-10-26 08:32:48,105 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
08:32:48
2017-10-26 08:32:48,108 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
08:32:48
2017-10-26 08:32:48,109 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
08:32:48
2017-10-26 08:32:48,114 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical, running forever.
08:32:48
2017-10-26 08:32:48,122 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
08:32:48
2017-10-26 08:32:48,122 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
08:32:48
2017-10-26 08:32:48,161 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:6, serverValue:7}] to mongodb:27017
08:32:48
2017-10-26 08:32:48,178 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:5, serverValue:5}] to mongodb:27017
08:32:48
2017-10-26 08:32:48,165 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:7, serverValue:6}] to mongodb:27017
08:32:48
2017-10-26 08:32:48,160 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:4, serverValue:4}] to mongodb:27017
08:32:48
2017-10-26 08:32:48,181 INFO : org.graylog2.periodical.UserPermissionMigrationPeriodical - Marking user permission migration as done.
08:32:48
2017-10-26 08:32:48,187 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:8, serverValue:8}] to mongodb:27017
08:32:48
2017-10-26 08:32:48,189 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
08:32:48
2017-10-26 08:32:48,213 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
08:32:48
2017-10-26 08:32:48,214 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical] periodical in [300s], polling every [21600s].
08:32:48
2017-10-26 08:32:48,214 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical] periodical in [300s], polling every [21600s].
08:32:48
2017-10-26 08:32:48,247 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
08:32:48
2017-10-26 08:32:48,250 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
08:32:48
2017-10-26 08:32:48,251 INFO : org.graylog2.migrations.V20151210140600_ElasticsearchConfigMigration - Migrated "elasticsearch_max_docs_per_index" setting: MessageCountRotationStrategyConfig{type=org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategyConfig, maxDocsPerIndex=20000000}
08:32:48
2017-10-26 08:32:48,273 INFO : org.graylog2.migrations.V20151210140600_ElasticsearchConfigMigration - Migrated "elasticsearch_max_size_per_index" setting: SizeBasedRotationStrategyConfig{type=org.graylog2.indexer.rotation.strategies.SizeBasedRotationStrategyConfig, maxSize=1073741824}
08:32:48
2017-10-26 08:32:48,300 INFO : org.graylog2.migrations.V20151210140600_ElasticsearchConfigMigration - Migrated "elasticsearch_max_time_per_index" setting: TimeBasedRotationStrategyConfig{type=org.graylog2.indexer.rotation.strategies.TimeBasedRotationStrategyConfig, rotationPeriod=P1D}
08:32:48
2017-10-26 08:32:48,300 INFO : org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration - Legacy default stream has no connections, no migration needed.
08:32:48
2017-10-26 08:32:48,316 INFO : org.graylog2.migrations.V20151210140600_ElasticsearchConfigMigration - Migrated "elasticsearch_max_number_of_indices" setting: ClosingRetentionStrategyConfig{type=org.graylog2.indexer.retention.strategies.ClosingRetentionStrategyConfig, maxNumberOfIndices=20}
08:32:48
2017-10-26 08:32:48,360 INFO : org.graylog2.migrations.V20151210140600_ElasticsearchConfigMigration - Migrated "elasticsearch_max_number_of_indices" setting: DeletionRetentionStrategyConfig{type=org.graylog2.indexer.retention.strategies.DeletionRetentionStrategyConfig, maxNumberOfIndices=20}
08:32:48
2017-10-26 08:32:48,377 INFO : org.graylog2.migrations.V20151210140600_ElasticsearchConfigMigration - Migrated "rotation_strategy" and "retention_strategy" setting: IndexManagementConfig{rotationStrategy=org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy, retentionStrategy=org.graylog2.indexer.retention.strategies.DeletionRetentionStrategy}
08:32:48
2017-10-26 08:32:48,382 INFO : org.graylog2.migrations.V20151210140600_ElasticsearchConfigMigration - Creating searches cluster config: SearchesClusterConfig{queryTimeRangeLimit=PT0S, relativeTimerangeOptions={PT5M=Search in the last 5 minutes, PT15M=Search in the last 15 minutes, PT30M=Search in the last 30 minutes, PT1H=Search in the last 1 hour, PT2H=Search in the last 2 hours, PT8H=Search in t
08:32:49
2017-10-26 08:32:49,056 INFO : org.graylog2.migrations.V20161116172200_CreateDefaultStreamMigration - Successfully created default stream: All messages
08:32:49
2017-10-26 08:32:49,114 INFO : org.graylog2.migrations.V20161124104700_AddRetentionRotationAndDefaultFlagToIndexSetMigration - Adding rotation_strategy_class <org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy> to index set <59f19db0d6018000019e6fdb>
08:32:49
2017-10-26 08:32:49,114 INFO : org.graylog2.migrations.V20161124104700_AddRetentionRotationAndDefaultFlagToIndexSetMigration - Adding retention_strategy_class <org.graylog2.indexer.retention.strategies.DeletionRetentionStrategy> to index set <59f19db0d6018000019e6fdb>
08:32:49
2017-10-26 08:32:49,125 INFO : org.graylog2.migrations.V20161124104700_AddRetentionRotationAndDefaultFlagToIndexSetMigration - Setting index set <59f19db0d6018000019e6fdb> as default
08:32:49
2017-10-26 08:32:49,156 INFO : org.graylog2.shared.initializers.JerseyService - Enabling CORS for HTTP endpoint
08:32:49
2017-10-26 08:32:49,177 INFO : org.graylog2.migrations.V20161125142400_EmailAlarmCallbackMigration - No streams needed to be migrated.
08:32:49
2017-10-26 08:32:49,217 INFO : org.graylog2.migrations.V20161125161400_AlertReceiversMigration - No streams needed to be migrated.
08:32:49
2017-10-26 08:32:49,316 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:9, serverValue:9}] to mongodb:27017
08:32:49
2017-10-26 08:32:49,399 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:10, serverValue:10}] to mongodb:27017
08:32:49
2017-10-26 08:32:49,397 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:11, serverValue:11}] to mongodb:27017
08:32:50
2017-10-26 08:32:50,338 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:12, serverValue:12}] to mongodb:27017
08:32:58
2017-10-26 08:32:58,100 INFO : org.graylog2.indexer.MongoIndexSet - Did not find a deflector alias. Setting one up now.
08:32:58
2017-10-26 08:32:58,108 INFO : org.graylog2.indexer.MongoIndexSet - There is no index target to point to. Creating one now.
08:32:58
2017-10-26 08:32:58,149 INFO : org.graylog2.indexer.MongoIndexSet - Cycling from <none> to <graylog_0>.
08:32:58
2017-10-26 08:32:58,149 INFO : org.graylog2.indexer.MongoIndexSet - Creating target index <graylog_0>.
08:32:58
2017-10-26 08:32:58,251 ERROR: org.graylog2.periodical.IndexRotationThread - Couldn't point deflector to a new index
08:32:58
org.graylog2.indexer.ElasticsearchException: Unable to create index template graylog-internal
08:32:58
Compressor detection can only be called on some xcontent bytes or compressed xcontent bytes
08:32:58
at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:94) ~[graylog.jar:?]
08:32:58
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:58) ~[graylog.jar:?]
08:32:58
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:63) ~[graylog.jar:?]
08:32:58
at org.graylog2.indexer.indices.Indices.ensureIndexTemplate(Indices.java:359) ~[graylog.jar:?]
08:32:58
at org.graylog2.indexer.indices.Indices.create(Indices.java:389) ~[graylog.jar:?]
08:32:58
at org.graylog2.indexer.indices.Indices.create(Indices.java:375) ~[graylog.jar:?]
08:32:58
at org.graylog2.indexer.MongoIndexSet.cycle(MongoIndexSet.java:293) ~[graylog.jar:?]
08:32:58
at org.graylog2.indexer.MongoIndexSet.setUp(MongoIndexSet.java:261) ~[graylog.jar:?]
08:32:58
at org.graylog2.periodical.IndexRotationThread.checkAndRepair(IndexRotationThread.java:138) ~[graylog.jar:?]
08:32:58
at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:76) ~[graylog.jar:?]
08:32:58
at java.lang.Iterable.forEach(Iterable.java:75) [?:1.8.0_141]
08:32:58
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:73) [graylog.jar:?]
08:32:58
08:32:58
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_141]
08:32:58
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_141]
08:32:58
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_141]
08:32:58
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_141]
08:32:58
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_141]
08:32:58
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_141]
08:32:58
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_141]
08:33:03
2017-10-26 08:33:03,172 INFO : org.graylog2.periodical.IndexRangesCleanupPeriodical - Skipping index range cleanup because the Elasticsearch cluster is unreachable or unhealthy
08:33:04
2017-10-26 08:33:04,442 INFO : org.glassfish.grizzly.http.server.NetworkListener - Started listener bound to [0.0.0.0:9000]
08:33:04
2017-10-26 08:33:04,444 INFO : org.glassfish.grizzly.http.server.HttpServer - [HttpServer] Started.
08:33:04
2017-10-26 08:33:04,444 INFO : org.graylog2.shared.initializers.JerseyService - Started REST API at <http 0.0.0.0:9000/api/>
08:33:04
2017-10-26 08:33:04,444 INFO : org.graylog2.shared.initializers.JerseyService - Started Web Interface at <http 0.0.0.0:9000/>
08:33:04
2017-10-26 08:33:04,448 INFO : org.graylog2.bootstrap.ServerBootstrap - Services started, startup times in ms: {OutputSetupService [RUNNING]=22, BufferSynchronizerService [RUNNING]=26, KafkaJournal [RUNNING]=48, JournalReader [RUNNING]=63, StreamCacheService [RUNNING]=143, LookupTableService [RUNNING]=146, InputSetupService [RUNNING]=148, ConfigurationEtagService [RUNNING]=159, PeriodicalsService
08:33:04
2017-10-26 08:33:04,449 INFO : org.graylog2.shared.initializers.ServiceManagerListener - Services are healthy
08:33:04
2017-10-26 08:33:04,450 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server up and running.
08:33:04
2017-10-26 08:33:04,451 INFO : org.graylog2.shared.initializers.InputSetupService - Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
08:33:08
2017-10-26 08:33:08,096 INFO : org.graylog2.indexer.MongoIndexSet - Did not find a deflector alias. Setting one up now.
08:33:08
2017-10-26 08:33:08,102 INFO : org.graylog2.indexer.MongoIndexSet - There is no index target to point to. Creating one now.
08:33:08
2017-10-26 08:33:08,109 INFO : org.graylog2.indexer.MongoIndexSet - Cycling from <none> to <graylog_0>.
08:33:08
2017-10-26 08:33:08,109 INFO : org.graylog2.indexer.MongoIndexSet - Creating target index <graylog_0>.
08:33:08
2017-10-26 08:33:08,117 ERROR: org.graylog2.periodical.IndexRotationThread - Couldn't point deflector to a new index
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
08:33:08
This seems to be the culprit.
Try disabling compression for the Elasticsearch HTTP connection in Graylog:
(This can be done with the GRAYLOG_ELASTICSEARCH_COMPRESSION_ENABLED environment variable in the Docker image).
Thanks, trying that now, but since the default is false, shouldn’t that be already disabled ?
It worked, thank you. Was going crazy :slight_smile:
Elasticsearch cluster is green. Shards: 4 active, 0 initializing, 0 relocating, 0 unassigned
so this is a bug, the default doesn’t work or in the docker image the config has it enabled ?
No, it’s just that AWS Elasticsearch Service is incompatible in various ways with Elasticsearch.
That’s a problem of the AWS Elasticsearch Service, not of Graylog. Feel free to let Amazon know.
