Graylog unable to connect to AWS Elasticsearch cluster
I have setup the graylog-server following the instructions for (ubuntu 16.04). Everything works fine. Now, I would like to point the graylog-server to an AWS ES cluster. The only configuration I have changed is this in server.conf -
elasticsearch_hosts = [https://vpc-aws-es-cluster.com:443]
And this started throwing the below error on web interface -
Could not load field information
Loading field information failed with status: cannot GET https://graylog.xxxx/api/system/fields (500)
Below is the version information -
  • Graylog Version: 2.4
  • Elasticsearch Version: 5.6
Tried with ES version 2.3 aswell, still the same issue.
I am able to curl the ES cluster and print the health status as follows -
  "cluster_name" : "xxxx",
  "status" : "green",
  "timed_out" : false,
  "number_of_nodes" : 1,
  "number_of_data_nodes" : 1,
  "active_primary_shards" : 4,
  "active_shards" : 4,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
I have attached the complete server.log file with this thread.
Please let me know if I need to make any other configuration changes.
I do not find clear documentation on integration with AWS ES cluster. Please point to one if it is existing already.
Thank you.
Did you use the same connection string for the CURL Command and elasticsearch_hosts ?
Yes, I did !! Is there any other configuration I need to change?
no need for any other configuration setting.
It should work, but with the given information no additional hints how to solve this is possible.
Helpful would be, the server.conf, the server.log that include the startup of Graylog and might reveal what is working and what not.
Below is the server.log
2018-08-30T06:52:44.329Z INFO  [CmdLineTool] Loaded plugin: AWS plugins 2.4.6 [org.graylog.aws.plugin.AWSPlugin]
2018-08-30T06:52:44.332Z INFO  [CmdLineTool] Loaded plugin: Elastic Beats Input 2.4.6 [org.graylog.plugins.beats.BeatsInputPlugin]
2018-08-30T06:52:44.332Z INFO  [CmdLineTool] Loaded plugin: CEF Input 2.4.6 [org.graylog.plugins.cef.CEFInputPlugin]
2018-08-30T06:52:44.333Z INFO  [CmdLineTool] Loaded plugin: Collector 2.4.6 [org.graylog.plugins.collector.CollectorPlugin]
2018-08-30T06:52:44.334Z INFO  [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.4.6 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2018-08-30T06:52:44.334Z INFO  [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.4.6 [org.graylog.plugins.map.MapWidgetPlugin]
2018-08-30T06:52:44.335Z INFO  [CmdLineTool] Loaded plugin: NetFlow Plugin 2.4.6 [org.graylog.plugins.netflow.NetFlowPlugin]
2018-08-30T06:52:44.342Z INFO  [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.4.6 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2018-08-30T06:52:44.342Z INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 2.4.6 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2018-08-30T06:52:44.788Z INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2018-08-30T06:52:45.035Z INFO  [Version] HV000001: Hibernate Validator 5.1.3.Final
2018-08-30T06:52:47.195Z INFO  [InputBufferImpl] Message journal is enabled.
2018-08-30T06:52:47.221Z INFO  [NodeId] Node ID: eb5e4833-1dad-4838-8a34-3d4497d618f8
2018-08-30T06:52:47.416Z INFO  [LogManager] Loading logs.
2018-08-30T06:52:47.476Z INFO  [LogManager] Logs loading complete.
2018-08-30T06:52:47.477Z INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2018-08-30T06:52:47.491Z INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2018-08-30T06:52:47.511Z INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2018-08-30T06:52:47.562Z INFO  [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2018-08-30T06:52:47.590Z INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:13123}] to localhost:27017
2018-08-30T06:52:47.594Z INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 6, 6]}, minWireVersion=0, maxWireVersion=6, maxDocumentSize=16777216, roundTripTimeNanos=1630824}
2018-08-30T06:52:47.601Z INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:13124}] to localhost:27017
2018-08-30T06:52:48.093Z INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [https://vpc-graylog-xxx.amazonaws.com:443]
2018-08-30T06:52:48.100Z INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2018-08-30T06:52:48.224Z INFO  [JestClientFactory] Using custom ObjectMapper instance
2018-08-30T06:52:48.232Z INFO  [JestClientFactory] Node Discovery disabled...
2018-08-30T06:52:48.233Z INFO  [JestClientFactory] Idle connection reaping disabled...
2018-08-30T06:52:48.673Z INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2018-08-30T06:52:50.533Z INFO  [RulesEngineProvider] No static rules file loaded.
2018-08-30T06:52:50.557Z INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:13125}] to localhost:27017
2018-08-30T06:52:50.695Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2018-08-30T06:52:50.702Z INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2018-08-30T06:52:50.724Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2018-08-30T06:52:50.738Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2018-08-30T06:52:50.750Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2018-08-30T06:52:50.763Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2018-08-30T06:52:50.948Z INFO  [ServerBootstrap] Graylog server 2.4.6+ceaa7e4 starting up
2018-08-30T06:52:50.948Z INFO  [ServerBootstrap] JRE: Oracle Corporation 1.8.0_181 on Linux 4.4.0-1061-aws
2018-08-30T06:52:50.948Z INFO  [ServerBootstrap] Deployment: deb
2018-08-30T06:52:50.949Z INFO  [ServerBootstrap] OS: Ubuntu 16.04.5 LTS (xenial)
2018-08-30T06:52:50.949Z INFO  [ServerBootstrap] Arch: amd64
2018-08-30T06:52:50.982Z INFO  [PeriodicalsService] Starting 25 periodicals ...
2018-08-30T06:52:50.982Z INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2018-08-30T06:52:50.982Z INFO  [Periodicals] Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [60s].
2018-08-30T06:52:50.983Z INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2018-08-30T06:52:50.984Z INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2018-08-30T06:52:50.989Z INFO  [Periodicals] Starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical, running forever.
2018-08-30T06:52:50.989Z INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2018-08-30T06:52:50.990Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2018-08-30T06:52:50.991Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2018-08-30T06:52:50.991Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2018-08-30T06:52:50.992Z INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2018-08-30T06:52:50.992Z INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2018-08-30T06:52:50.992Z INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2018-08-30T06:52:50.993Z INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2018-08-30T06:52:50.993Z INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2018-08-30T06:52:50.993Z INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2018-08-30T06:52:50.994Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2018-08-30T06:52:50.994Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2018-08-30T06:52:50.998Z INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:13126}] to localhost:27017
2018-08-30T06:52:50.999Z INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:13127}] to localhost:27017
2018-08-30T06:52:51.002Z INFO  [connection] Opened connection [connectionId{localValue:7, serverValue:13129}] to localhost:27017
2018-08-30T06:52:51.003Z INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:13128}] to localhost:27017
2018-08-30T06:52:51.011Z INFO  [connection] Opened connection [connectionId{localValue:8, serverValue:13130}] to localhost:27017
2018-08-30T06:52:51.012Z INFO  [connection] Opened connection [connectionId{localValue:9, serverValue:13131}] to localhost:27017
2018-08-30T06:52:51.033Z INFO  [connection] Opened connection [connectionId{localValue:10, serverValue:13132}] to localhost:27017
2018-08-30T06:52:51.058Z INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2018-08-30T06:52:51.059Z INFO  [Periodicals] Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2018-08-30T06:52:51.072Z INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2018-08-30T06:52:51.083Z INFO  [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2018-08-30T06:52:51.089Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2018-08-30T06:52:51.092Z INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2018-08-30T06:52:51.101Z INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2018-08-30T06:52:51.108Z INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2018-08-30T06:52:51.139Z INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2018-08-30T06:52:51.143Z INFO  [LookupTableService] Data Adapter otx-api-domain/5b7b32f4d0149b77291711dc [@ea7f3b3] STARTING
2018-08-30T06:52:51.143Z INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-domains/5b7b32f4d0149b77291711db [@49dad4b2] STARTING
2018-08-30T06:52:51.143Z INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-ip/5b7b32f4d0149b77291711de [@6b1db3d4] STARTING
2018-08-30T06:52:51.143Z INFO  [LookupTableService] Data Adapter otx-api-ip/5b7b32f4d0149b77291711dd [@2a0cf862] STARTING
2018-08-30T06:52:51.147Z INFO  [LookupTableService] Data Adapter tor-exit-node/5b7b32f4d0149b77291711df [@3f7d2a0d] STARTING
2018-08-30T06:52:51.148Z INFO  [LookupTableService] Data Adapter whois/5b7b32f4d0149b77291711d9 [@35516813] STARTING
2018-08-30T06:52:51.149Z WARN  [OTXDataAdapter] OTX API key is missing. Make sure to add the key to allow higher request limits.
2018-08-30T06:52:51.153Z INFO  [LookupTableService] Data Adapter spamhaus-drop/5b7b32f4d0149b77291711da [@275ff4ec] STARTING
2018-08-30T06:52:51.150Z ERROR [LookupDataAdapter] Couldn't start data adapter <abuse-ch-ransomware-domains/5b7b32f4d0149b77291711db/@49dad4b2>
org.graylog.plugins.threatintel.tools.AdapterDisabledException: Abuse.ch service is disabled, not starting adapter. To enable it please go to System / Configurations.
	at org.graylog.plugins.threatintel.adapters.abusech.AbuseChRansomAdapter.doStart(AbuseChRansomAdapter.java:80) ~[?:?]
	at org.graylog2.plugin.lookup.LookupDataAdapter.startUp(LookupDataAdapter.java:59) [graylog.jar:?]
	at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) [graylog.jar:?]
	at com.google.common.util.concurrent.Callables$4.run(Callables.java:122) [graylog.jar:?]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_181]
2018-08-30T06:52:51.148Z ERROR [LookupDataAdapter] Couldn't start data adapter <spamhaus-drop/5b7b32f4d0149b77291711da/@275ff4ec>
org.graylog.plugins.threatintel.tools.AdapterDisabledException: Spamhaus service is disabled, not starting (E)DROP adapter. To enable it please go to System / Configurations.
	at org.graylog.plugins.threatintel.adapters.spamhaus.SpamhausEDROPDataAdapter.doStart(SpamhausEDROPDataAdapter.java:68) ~[?:?]
2018-08-30T06:52:51.147Z ERROR [LookupDataAdapter] Couldn't start data adapter <tor-exit-node/5b7b32f4d0149b77291711df/@3f7d2a0d>
org.graylog.plugins.threatintel.tools.AdapterDisabledException: TOR service is disabled, not starting TOR exit addresses adapter. To enable it please go to System / Configurations.
	at org.graylog.plugins.threatintel.adapters.tor.TorExitNodeDataAdapter.doStart(TorExitNodeDataAdapter.java:73) ~[?:?]
2018-08-30T06:52:51.156Z INFO  [LookupTableService] Data Adapter whois/5b7b32f4d0149b77291711d9 [@35516813] RUNNING
2018-08-30T06:52:51.159Z WARN  [OTXDataAdapter] OTX API key is missing. Make sure to add the key to allow higher request limits.
2018-08-30T06:52:51.163Z INFO  [LookupTableService] Data Adapter tor-exit-node/5b7b32f4d0149b77291711df [@3f7d2a0d] RUNNING
2018-08-30T06:52:51.151Z ERROR [LookupDataAdapter] Couldn't start data adapter <abuse-ch-ransomware-ip/5b7b32f4d0149b77291711de/@6b1db3d4>
2018-08-30T06:52:51.165Z INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-domains/5b7b32f4d0149b77291711db [@49dad4b2] RUNNING
2018-08-30T06:52:51.179Z INFO  [LookupTableService] Data Adapter spamhaus-drop/5b7b32f4d0149b77291711da [@275ff4ec] RUNNING
2018-08-30T06:52:51.180Z INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-ip/5b7b32f4d0149b77291711de [@6b1db3d4] RUNNING
2018-08-30T06:52:51.180Z INFO  [LookupTableService] Data Adapter otx-api-ip/5b7b32f4d0149b77291711dd [@2a0cf862] RUNNING
2018-08-30T06:52:51.180Z INFO  [LookupTableService] Data Adapter otx-api-domain/5b7b32f4d0149b77291711dc [@ea7f3b3] RUNNING
2018-08-30T06:52:51.185Z INFO  [LookupTableService] Cache whois-cache/5b7b32f4d0149b77291711d4 [@46ce4d0c] STARTING
2018-08-30T06:52:51.185Z INFO  [LookupTableService] Cache otx-api-ip-cache/5b7b32f4d0149b77291711d6 [@20c65304] STARTING
2018-08-30T06:52:51.186Z INFO  [LookupTableService] Cache spamhaus-e-drop-cache/5b7b32f4d0149b77291711d7 [@6e8d6228] STARTING
2018-08-30T06:52:51.190Z INFO  [LookupTableService] Cache whois-cache/5b7b32f4d0149b77291711d4 [@46ce4d0c] RUNNING
2018-08-30T06:52:51.190Z INFO  [LookupTableService] Cache otx-api-ip-cache/5b7b32f4d0149b77291711d6 [@20c65304] RUNNING
2018-08-30T06:52:51.190Z INFO  [LookupTableService] Cache spamhaus-e-drop-cache/5b7b32f4d0149b77291711d7 [@6e8d6228] RUNNING
2018-08-30T06:52:51.193Z INFO  [LookupTableService] Cache threat-intel-uncached-adapters/5b7b32f4d0149b77291711d3 [@6d7ef992] STARTING
2018-08-30T06:52:51.193Z INFO  [LookupTableService] Cache otx-api-domain-cache/5b7b32f4d0149b77291711d5 [@3a6f01f2] STARTING
2018-08-30T06:52:51.199Z INFO  [LookupTableService] Cache threat-intel-uncached-adapters/5b7b32f4d0149b77291711d3 [@6d7ef992] RUNNING
2018-08-30T06:52:51.199Z INFO  [LookupTableService] Cache otx-api-domain-cache/5b7b32f4d0149b77291711d5 [@3a6f01f2] RUNNING
2018-08-30T06:52:51.218Z INFO  [LookupTableService] Starting lookup table otx-api-ip/5b7b32f4d0149b77291711e1 [@5c996388] using cache otx-api-ip-cache/5b7b32f4d0149b77291711d6 [@20c65304], data adapter otx-api-ip/5b7b32f4d0149b77291711dd [@2a0cf862]
2018-08-30T06:52:51.218Z INFO  [LookupTableService] Starting lookup table tor-exit-node-list/5b7b32f4d0149b77291711e2 [@36d194af] using cache threat-intel-uncached-adapters/5b7b32f4d0149b77291711d3 [@6d7ef992], data adapter tor-exit-node/5b7b32f4d0149b77291711df [@3f7d2a0d]
2018-08-30T06:52:51.218Z INFO  [LookupTableService] Starting lookup table whois/5b7b32f4d0149b77291711e3 [@273c3bf6] using cache whois-cache/5b7b32f4d0149b77291711d4 [@46ce4d0c], data adapter whois/5b7b32f4d0149b77291711d9 [@35516813]
2018-08-30T06:52:51.218Z INFO  [LookupTableService] Starting lookup table abuse-ch-ransomware-ip/5b7b32f4d0149b77291711e4 [@4721877f] using cache threat-intel-uncached-adapters/5b7b32f4d0149b77291711d3 [@6d7ef992], data adapter abuse-ch-ransomware-ip/5b7b32f4d0149b77291711de [@6b1db3d4]
2018-08-30T06:52:51.219Z INFO  [LookupTableService] Starting lookup table spamhaus-drop/5b7b32f4d0149b77291711e5 [@50b33930] using cache spamhaus-e-drop-cache/5b7b32f4d0149b77291711d7 [@6e8d6228], data adapter spamhaus-drop/5b7b32f4d0149b77291711da [@275ff4ec]
2018-08-30T06:52:51.219Z INFO  [LookupTableService] Starting lookup table abuse-ch-ransomware-domains/5b7b32f4d0149b77291711e6 [@6a7dbb65] using cache threat-intel-uncached-adapters/5b7b32f4d0149b77291711d3 [@6d7ef992], data adapter abuse-ch-ransomware-domains/5b7b32f4d0149b77291711db [@49dad4b2]
2018-08-30T06:52:51.219Z INFO  [LookupTableService] Starting lookup table otx-api-domain/5b7b32f4d0149b77291711e7 [@2c58de57] using cache otx-api-domain-cache/5b7b32f4d0149b77291711d5 [@3a6f01f2], data adapter otx-api-domain/5b7b32f4d0149b77291711dc [@ea7f3b3]
2018-08-30T06:52:51.469Z ERROR [ConfigurationManagementPeriodical] Error while running migration <V20170607164210_MigrateReopenedIndicesToAliases{2017-06-07T16:42:10Z}>
org.graylog2.indexer.ElasticsearchException: Couldn't read cluster state for reopened indices [graylog_*]
	at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:95) ~[graylog.jar:?]
	at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:57) ~[graylog.jar:?]
	at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:62) ~[graylog.jar:?]
	at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.getReopenedIndices(V20170607164210_MigrateReopenedIndicesToAliases.java:88) ~[graylog.jar:?]
	at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.getReopenedIndices(V20170607164210_MigrateReopenedIndicesToAliases.java:135) ~[graylog.jar:?]
	at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.lambda$upgrade$0(V20170607164210_MigrateReopenedIndicesToAliases.java:78) ~[graylog.jar:?]
	at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:267) ~[?:1.8.0_181]
	at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:1.8.0_181]
	at java.util.Collections$2.tryAdvance(Collections.java:4717) ~[?:1.8.0_181]
	at java.util.Collections$2.forEachRemaining(Collections.java:4725) ~[?:1.8.0_181]
	at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:1.8.0_181]
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:1.8.0_181]
	at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151) ~[?:1.8.0_181]
	at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174) ~[?:1.8.0_181]
	at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_181]
	at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418) ~[?:1.8.0_181]
	at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.upgrade(V20170607164210_MigrateReopenedIndicesToAliases.java:80) ~[graylog.jar:?]
	at org.graylog2.periodical.ConfigurationManagementPeriodical.doRun(ConfigurationManagementPeriodical.java:43) [graylog.jar:?]
2018-08-30T06:52:51.617Z INFO  [JerseyService] Enabling CORS for HTTP endpoint
2018-08-30T06:53:02.119Z INFO  [NetworkListener] Started listener bound to [127.0.0.1:9000]
2018-08-30T06:53:02.120Z INFO  [HttpServer] [HttpServer] Started.
2018-08-30T06:53:02.121Z INFO  [JerseyService] Started REST API at <http://127.0.0.1:9000/api/>
2018-08-30T06:53:02.121Z INFO  [JerseyService] Started Web Interface at <http://127.0.0.1:9000/>
2018-08-30T06:53:02.122Z INFO  [ServerBootstrap] Services started, startup times in ms: {OutputSetupService [RUNNING]=11, KafkaJournal [RUNNING]=12, BufferSynchronizerService [RUNNING]=12, InputSetupService [RUNNING]=56, JournalReader [RUNNING]=109, StreamCacheService [RUNNING]=124, ConfigurationEtagService [RUNNING]=125, PeriodicalsService [RUNNING]=142, LookupTableService [RUNNING]=256, JerseyService [RUNNING]=11147}
2018-08-30T06:53:02.127Z INFO  [ServiceManagerListener] Services are healthy
2018-08-30T06:53:02.127Z INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2018-08-30T06:53:02.130Z INFO  [ServerBootstrap] Graylog server up and running.
2018-08-30T06:53:02.152Z INFO  [InputStateListener] Input [GELF HTTP/5b7c7790d0149b26555cb366] is now STARTING
2018-08-30T06:53:02.207Z WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input GELFHttpInput{title=Gelf-http, type=org.graylog2.inputs.gelf.http.GELFHttpInput, nodeId=null} should be 1048576 but is 212992.
2018-08-30T06:53:02.209Z INFO  [InputStateListener] Input [GELF HTTP/5b7c7790d0149b26555cb366] is now RUNNING
Below is the server.conf
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = XYANpuo0ngM3amiF1q0GhRm1WhWSDf27rJZ30wEDWmqv5tQrn7RClSiK41vUMfh8UlVK0QQPdMckAhpv1RiGhhJo7Qp6qwi7
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = e3c652f0ba0b4801205814f8b6bc49672c4c74e25b497770bb89b22cdeb4e951
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
rest_listen_uri = http://127.0.0.1:9000/api/
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
# rest_transport_uri = http://18.222.234.98:12900
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
#rest_enable_gzip = false
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
# rest_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
# rest_tls_cert_file = /home/ubuntu/cert.pem
# The PKCS#8 private key file in PEM format to use for securing the REST API.
# rest_tls_key_file = /home/ubuntu/pkcs8-encrypted.pem
# The password to unlock the private key used for securing the REST API.
# rest_tls_key_password = secret
#rest_max_header_size = 8192
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
# Enable the embedded Graylog web interface.
# Default: true
#web_enable = false
# Web interface listen URI.
# Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
# for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
web_listen_uri = http://127.0.0.1:9000/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
web_endpoint_uri = http://graylog-xxx.io:9000/api/
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
#web_enable_cors = false
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
# web_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the web interface.
# web_tls_cert_file = /home/ubuntu/cert.pem
# The PKCS#8 private key file in PEM format to use for securing the web interface.
# web_tls_key_file = /home/ubuntu/pkcs8-encrypted.pem
# The password to unlock the private key used for securing the web interface.
# web_tls_key_password = secret
#web_max_header_size = 8192
# The size of the thread pool used exclusively for serving the web interface.
#web_thread_pool_size = 16
# requires authentication.
# elasticsearch_hosts = http://node1:9200,http://user:password@node2:19200
elasticsearch_hosts = https://vpc-graylog-xxx.amazonaws.com:443
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
# elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
# elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# elasticsearch_compression_enabled = false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
sorry I did not spot any issue that has the source visible in one of the provided information.
Are you sure that the connection to the Elasticsearch Cluster is made HTTP and not HTTPS and without username/password?
I have tried with the connection to elasticsearch cluster as http(with no username/password) and still face the same error in the log file
2018-08-31T17:33:50.593Z ERROR [ConfigurationManagementPeriodical] Error while running migration <V20170607164210_MigrateReopenedIndicesToAliases{2017-06-07T16:42:10Z}>
2018-08-31T17:33:50.746Z INFO  [JerseyService] Enabling CORS for HTTP endpoint
Hey, Are there any other config or log files which I can check that would help in debugging the issue. Please let me know.
Your first post and the config file the elasticsearch_hosts params are different. Are you sure you use the correct one?
I don’t see the elasticsearch_cluster_name param in your GL config. In the ES health state and in GL config you should use the same name.
try tcpdump, to check your GL try to connect to the ES cluster, and it get answer from it. I don’t know AWS, but I think a big cluster behind your
and try the curl command from your server.conf sometimes I can’t see any misstyped character, but there is. so copy, not retype it.
Check the ES information via curl. Do you use the same (copy, not type…) cluster name in ES and in GL? Do you have indecies with name graylog_*
curl -XGET 'https://vpc-aws-es-cluster.com:443/graylog_*?pretty'
