Unable to create index template graylog-internal
I have just done a clean installation with 3x graylog 2.2.3 instances. Aim being to cluster the three nodes.
WebUI and 3 nodes are functional, not reporting any issues.
Encountering an issue affecting the elasticsearch clustering / replicas that I’m struggling to find a resolution to.
As i have three nodes, i considered the following to be correct settings, however may not be related to the error below.
elasticsearch_shards = 3
elasticsearch_replicas = 3
Here is the error written to server.log
2017-05-23T13:32:43.530+10:00 INFO  [MongoIndexSet] Did not find an deflector alias. Setting one up now.
2017-05-23T13:32:43.532+10:00 INFO  [MongoIndexSet] There is no index target to point to. Creating one now.
2017-05-23T13:32:43.535+10:00 INFO  [MongoIndexSet] Cycling from <none> to <graylog_0>.
2017-05-23T13:32:43.535+10:00 INFO  [MongoIndexSet] Creating target index <graylog_0>.
2017-05-23T13:32:43.554+10:00 ERROR [IndexRotationThread] Couldn't point deflector to a new index
org.graylog2.indexer.ElasticsearchException: Unable to create index template graylog-internal
No handler for type [text] declared on field [full_message]
2017-05-23T13:32:53.537+10:00 INFO  [MongoIndexSet] Did not find an deflector alias. Setting one up now.
2017-05-23T13:32:53.540+10:00 INFO  [MongoIndexSet] There is no index target to point to. Creating one now.
2017-05-23T13:32:53.544+10:00 INFO  [MongoIndexSet] Cycling from <none> to <graylog_0>.
2017-05-23T13:32:53.544+10:00 INFO  [MongoIndexSet] Creating target index <graylog_0>.
2017-05-23T13:32:53.563+10:00 ERROR [IndexRotationThread] Couldn't point deflector to a new index
2017-05-23T13:32:55.526+10:00 ERROR [BatchedElasticSearchOutputFlushThread] Caught exception while trying to flush output: {}
org.graylog2.indexer.ElasticsearchException: Couldn't read cluster health for indices [graylog_deflector]
Here is the Elasticsearch configuration within elasticsearch.yaml
# ======================== Elasticsearch Configuration =========================
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: graylog
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
# node.name: node-1
# Add custom attributes to the node:
# node.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
# path.data: /path/to/data
# Path to log files:
# path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
# bootstrap.memory_lock: true
# Make sure that the `ES_HEAP_SIZE` environment variable is set to about half the memory
# available on the system and that the owner of the process is allowed to use this limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 10.40.1.231
# Set a custom port for HTTP:
# http.port: 9200
# For more information, see the documentation at:
# <http://www.elastic.co/guide/en/elasticsearch/reference/current/modules-network.html>
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
discovery.zen.ping.multicast.enabled: false
discovery.zen.ping.unicast.hosts: ["10.40.1.231:9300", "10.40.1.232:9300", "10.40.1.233:9300"]
# Prevent the "split brain" by configuring the majority of nodes (total number of nodes / 2 + 1):
# discovery.zen.minimum_master_nodes: 3
# <http://www.elastic.co/guide/en/elasticsearch/reference/current/modules-discovery.html>
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
# gateway.recover_after_nodes: 3
# <http://www.elastic.co/guide/en/elasticsearch/reference/current/modules-gateway.html>
# ---------------------------------- Various -----------------------------------
# Disable starting multiple nodes on a single system:
# node.max_local_storage_nodes: 1
# Require explicit names when deleting indices:
# action.destructive_requires_name: true
script.inline: false
script.indexed: false
script.file: false
And the main server.conf
# GRAYLOG CONFIGURATION FILE
is_master = true
password_secret = ZXfABUpDQBktG4y6WVxKTNqj2hs4vJdG4kcPjQBvx7LSh26ytvu78wDUwEJxgAwF
#root_username = admin
root_password_sha2 = e0bd3b19569b6834693785191b7ea093c9fdce46e38fe6760b64e30d80cf10bc
# Default is empty
#root_email = ""
# Default is UTC
root_timezone = Australia/Sydney
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
rest_listen_uri = http://10.40.1.231:12900/api/
#rest_transport_uri = http://192.168.1.1:9000/api/
#rest_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
#rest_enable_gzip = false
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
#rest_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
#rest_tls_cert_file = /path/to/graylog.crt
# The PKCS#8 private key file in PEM format to use for securing the REST API.
#rest_tls_key_file = /path/to/graylog.key
# The password to unlock the private key used for securing the REST API.
#rest_tls_key_password = secret
#rest_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
#rest_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
# Enable the embedded Graylog web interface.
# Default: true
web_enable = true
# Web interface listen URI..
web_listen_uri = http://10.40.1.231:9000/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#web_endpoint_uri =
#web_enable_cors = false
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
#web_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the web interface.
#web_tls_cert_file = /path/to/graylog-web.crt
# The PKCS#8 private key file in PEM format to use for securing the web interface.
#web_tls_key_file = /path/to/graylog-web.key
# The password to unlock the private key used for securing the web interface.
#web_tls_key_password = secret
#web_max_header_size = 8192
#web_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the web interface.
#web_thread_pool_size = 16
# requires authentication.
# Default: "http://127.0.0.1:9200"
elasticsearch_hosts = http://10.40.1.231:9200,http://10.40.1.232:9200,http://10.40.1.233:9200
# The (major) version of Elasticsearch being used in the cluster. This setting controls which
# index mapping/index template is being used by Graylog. Valid values are 2 and 5.
# Default: 5
#elasticsearch_version = 5
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
elasticsearch_discovery_zen_ping_unicast_hosts = 10.40.1.231:9300,10.40.1.232:9300,10.40.1.233:9300
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://localhost/graylog
mongodb_uri = mongodb://grayloguser:password@10.40.1.231:27017,10.40.1.232:27017,10.40.1.233:27017/graylog2
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
#http_proxy_uri =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
your number of shards is equal to number of servers, which sounds fine, but your setting (number of replicas = 3) defines that you want 4 copies (one original and 3 replicas) of each message. In practice, you could say this means about this: “the elasticsearch cluster can stand sudden loss of 3 servers without losing data” (although you actually can lose data that is still in going through the indexing and copying process). You need at least 4 elasticsearch data nodes to make it work.
This is unrelated to your error message, but just so you will know you will not have a healthy ES cluster with these settings.
It looks like you’re running Graylog 2.3.0-alpha.1 or 2.3.0-alpha.2 and your elasticsearch_version setting is incorrect.
If you want to create a production setup, do not install an alpha version.
