Index won't be creates
Hey there,
Graylog doesn’t like me anymore :frowning:
Indicies won’t be created
  • OS Information: Debian 11
Suppressed: org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ResponseException: method [PUT], host [http://127.0.0.1:9200], URI [/seed_0?master_timeout=30s&timeout=30s], status line [HTTP/1.1 400 Bad Request]
{"error":{"root_cause":[{"type":"validation_exception","reason":"Validation Failed: 1: this action would add [4] total shards, but this cluster currently has [1000]/[1000] maximum shards open;"}],"type":"validation_exception","reason":"Validation Failed: 1: this action would add [4] $                at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.convertResponse(RestClient.java:302) ~[?:?]
                at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:272) ~[?:?]
                at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
                at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.internalPerformRequest(RestHighLevelClient.java:1613) ~[?:?]
                at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequest(RestHighLevelClient.java:1598) ~[?:?]
                at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequestAndParseEntity(RestHighLevelClient.java:1565) ~[?:?]
                at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.IndicesClient.create(IndicesClient.java:145) ~[?:?]
                at org.graylog.storage.elasticsearch7.IndicesAdapterES7.lambda$create$3(IndicesAdapterES7.java:153) ~[?:?]
                at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:98) ~[?:?]
                at org.graylog.storage.elasticsearch7.IndicesAdapterES7.create(IndicesAdapterES7.java:153) ~[?:?]
                at org.graylog2.indexer.indices.Indices.create(Indices.java:196) ~[graylog.jar:?]
                at org.graylog2.indexer.MongoIndexSet.cycle(MongoIndexSet.java:291) ~[graylog.jar:?]
                at org.graylog2.indexer.MongoIndexSet.setUp(MongoIndexSet.java:259) ~[graylog.jar:?]
Nothing, cause I really don’t know what to do now :frowning:
Tell me whats going on and whats the issue is
Hello @Gamienator
If you could show your configurations from the following:
  • Graylog
  • Elasticsearch
Also could you show the full messages, leaving out personal information?
Sure thing :slight_smile:
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
#cluster.name: my-application
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
#node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
path.data: /var/lib/elasticsearch
# Path to log files:
path.logs: /var/log/elasticsearch
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
#network.host: 192.168.0.1
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when this node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.seed_hosts: ["host1", "host2"]
# Bootstrap the cluster using an initial set of master-eligible nodes:
#cluster.initial_master_nodes: ["node-1", "node-2"]
# For more information, consult the discovery and cluster formation module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
cluster.name: graylog
Graylog Part 1:
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# ATTENTION: This value must be the same on all Graylog nodes in the cluster.
# Changing this value after installation will render all user sessions and encrypted values in the database invalid. (e.g. encrypted access tokens)
password_secret = ''
root_username = huhu
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 =
# Default is empty
root_email = ""
# Default is UTC
root_timezone = CET
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 127.0.0.1:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
#http_publish_uri = http://192.168.1.1:9000/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri =
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
#elasticsearch_hosts = http://127.0.0.1:9200
# Maximum number of retries to connect to elasticsearch on boot for the version probe.
# Default: 0, retry indefinitely with the given delay until a connection could be established
#elasticsearch_version_probe_attempts = 5
# Waiting time in between connection attempts for elasticsearch_version_probe_attempts
# Default: 5s
#elasticsearch_version_probe_delay = 5s
# Maximum amount of time to wait for successful connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# (e. g. during search, index creation, or index time-range calculations)
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 200
#elasticsearch_max_total_connections = 200
# elasticsearch server).
# Default: 20
#elasticsearch_max_total_connections_per_route = 20
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Set the default scheme when connecting to Elasticsearch discovered nodes
# Default: http (available options: http, https)
#elasticsearch_discovery_default_scheme = http
# Default: false
# Enable use of "Expect: 100-continue" Header for Elasticsearch index requests.
# If this is disabled, Graylog cannot properly handle HTTP 413 Request Entity Too Large errors.
# Default: true
#elasticsearch_use_expect_continue = true
# Graylog will use multiple indices to store documents in. You can configure the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies, the default being "count":
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
#   - "time" interval between index rotations, use elasticsearch_max_time_per_index to configure
# A strategy may be disabled by specifying the optional enabled_index_rotation_strategies list and excluding that strategy.
#enabled_index_rotation_strategies = count,size,time
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see https://docs.graylog.org/docs/index-model#index-set-configuration
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
# Optional upper bound on elasticsearch_max_time_per_index
# elasticsearch_max_write_index_age = 1d
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: https://docs.graylog.org/docs/query-language
allow_highlighting = false
# Default: 1h
# Default: 20
# Mute the logging-output of ES deprecation warnings during REST calls in the ES RestClient
#elasticsearch_mute_deprecation_warnings = true
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the message journal.
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
# DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format
#mongodb_uri = mongodb+srv://server.example.org/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
transport_email_hostname =
transport_email_port = 587
transport_email_use_auth = true
transport_email_use_tls = true
transport_email_auth_username = home@
transport_email_auth_password =
transport_email_from_email = home@
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of a native system stats collector (currently OSHI)
#disable_native_system_stats_collector = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
# The server is writing processing status information to the database on a regular basis. This setting controls how
# often the data is written to the database.
# Default: 1s (cannot be less than 1s)
#processing_status_persist_interval = 1s
# Configures the threshold for detecting outdated processing status records. Any records that haven't been updated
# in the configured threshold will be ignored.
# Default: 1m (one minute)
#processing_status_update_threshold = 1m
# Configures the journal write rate threshold for selecting processing status records. Any records that have a lower
# one minute rate than the configured value might be ignored. (dependent on number of messages in the journal)
# Default: 1
#processing_status_journal_write_rate_threshold = 1
# Configures the prefix used for graylog event indices
# Default: gl-events
#default_events_index_prefix = gl-events
# Configures the prefix used for graylog system event indices
# Default: gl-system-events
#default_system_events_index_prefix = gl-system-events
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = false
# The directory which contains content packs which should be loaded on the first start of Graylog.
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
#content_packs_auto_install = grok-patterns.json
# The allowed TLS protocols for system wide TLS enabled servers. (e.g. message inputs, http interface)
# Setting this to an empty value, leaves it up to system libraries and the used JDK to chose a default.
# Default: TLSv1.2,TLSv1.3  (might be automatically adjusted to protocols supported by the JDK)
#enabled_tls_protocols= TLSv1.2,TLSv1.3
# Enable Prometheus exporter HTTP server.
# Default: false
#prometheus_exporter_enabled = false
# IP address and port for the Prometheus exporter HTTP server.
# Default: 127.0.0.1:9833
#prometheus_exporter_bind_address = 127.0.0.1:9833
# Path to the Prometheus exporter core mapping file. If this option is enabled, the full built-in core mapping is
# replaced with the mappings in this file.
# This file is monitored for changes and updates will be applied at runtime.
# Default: none
#prometheus_exporter_mapping_file_path_core = prometheus-exporter-mapping-core.yml
# Path to the Prometheus exporter custom mapping file. If this option is enabled, the mappings in this file are
# configured in addition to the built-in core mappings. The mappings in this file cannot overwrite any core mappings.
# Default: none
#prometheus_exporter_mapping_file_path_custom = prometheus-exporter-mapping-custom.yml
# Configures the refresh interval for the monitored Prometheus exporter mapping files.
# Default: 60s
#prometheus_exporter_mapping_file_refresh_interval = 60s
# Optional allowed paths for Graylog data files. If provided, certain operations in Graylog will only be permitted
# if the data file(s) are located in the specified paths (for example, with the CSV File lookup adapter).
# All subdirectories of indicated paths are allowed by default. This Provides an additional layer of security,
# and allows administrators to control where in the file system Graylog users can select files from.
#allowed_auxiliary_paths = /etc/graylog/data-files,/etc/custom-allowed-path
Thanks for the add info. I found some configuration made. Im not sure if this would be the cause, just need to know if they were configured
I was wonder if you could explain the following
Does this persona have a Administrator roll for the system/Graylog?
Just checking, I assume you had these filled in, is this correct?
I realize this node is set for default, perhaps trying to uncomment this out for troubleshooting?
I have a couple questions to ask you.
Is it possible to show your elasticsearch/Graylog log files during that time when trying to create a Index?
What type of index are you creating, Is it possible to show how this was done?
Is this post referring to creating the default index set?
Heyho,
so, regards your questions:
are changed values, you said I should remove every personal data :slight_smile:
Here are some logs:
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
        at java.lang.Thread.run(Thread.java:829) [?:?]
Caused by: org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchStatusException: Elasticsearch exception [type=validation_exception, reason=Validation Failed: 1: this action would add [4] total shards, but this cluster currently has [1000]/[1000] maximum shards open;]
        at org.graylog.shaded.elasticsearch7.org.elasticsearch.rest.BytesRestResponse.errorFromXContent(BytesRestResponse.java:187) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.parseEntity(RestHighLevelClient.java:1892) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.parseResponseException(RestHighLevelClient.java:1869) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.internalPerformRequest(RestHighLevelClient.java:1626) ~[?:?]
        ... 15 more
{"error":{"root_cause":[{"type":"validation_exception","reason":"Validation Failed: 1: this action would add [4] total shards, but this cluster currently has [1000]/[1000] maximum shards open;"}],"type":"validation_exception","reason":"Validation Failed: 1: this action would add [4] total shards, but$
                at org.graylog2.periodical.IndexRotationThread.checkAndRepair(IndexRotationThread.java:138) ~[graylog.jar:?]
                at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:76) ~[graylog.jar:?]
                at java.lang.Iterable.forEach(Iterable.java:75) [?:?]
                at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:73) [graylog.jar:?]
2022-04-22T20:40:50.410+02:00 ERROR [IndexRotationThread] Couldn't point deflector to a new index
java.lang.RuntimeException: Could not create new target index <seed_0>.
        at org.graylog2.indexer.MongoIndexSet.cycle(MongoIndexSet.java:292) ~[graylog.jar:?]
[2022-04-22T18:40:47.029+0000][126][gc,marking  ] GC(68198) Concurrent Mark (173252.039s)
[2022-04-22T18:40:47.029+0000][126][gc,marking  ] GC(68198) Concurrent Mark From Roots
[2022-04-22T18:40:47.029+0000][126][gc,task     ] GC(68198) Using 1 workers of 1 for marking
[2022-04-22T18:40:47.977+0000][126][gc,marking  ] GC(68198) Concurrent Mark From Roots 948.272ms
[2022-04-22T18:40:47.978+0000][126][gc,marking  ] GC(68198) Concurrent Preclean
[2022-04-22T18:40:47.980+0000][126][gc,marking  ] GC(68198) Concurrent Preclean 2.354ms
[2022-04-22T18:40:47.980+0000][126][gc,marking  ] GC(68198) Concurrent Mark (173252.039s, 173252.990s) 950.859ms
[2022-04-22T18:40:47.980+0000][126][gc,start    ] GC(68198) Pause Remark
[2022-04-22T18:40:48.019+0000][126][gc          ] GC(68198) Pause Remark 560M->560M(1024M) 38.667ms
[2022-04-22T18:40:48.019+0000][126][gc,cpu      ] GC(68198) User=0.04s Sys=0.02s Real=0.04s
[2022-04-22T18:40:48.019+0000][126][safepoint   ] Safepoint "G1Concurrent", Time since last: 963546896 ns, Reaching safepoint: 251250 ns, At safepoint: 38950441 ns, Total: 39201691 ns
[2022-04-22T18:40:48.020+0000][126][gc,marking  ] GC(68198) Concurrent Rebuild Remembered Sets
[2022-04-22T18:40:48.727+0000][126][gc,marking  ] GC(68198) Concurrent Rebuild Remembered Sets 707.320ms
[2022-04-22T18:40:48.728+0000][126][gc,start    ] GC(68198) Pause Cleanup
[2022-04-22T18:40:48.728+0000][126][gc          ] GC(68198) Pause Cleanup 607M->607M(1024M) 0.869ms
[2022-04-22T18:40:48.728+0000][126][gc,cpu      ] GC(68198) User=0.00s Sys=0.00s Real=0.00s
[2022-04-22T18:40:48.729+0000][126][safepoint   ] Safepoint "G1Concurrent", Time since last: 707671347 ns, Reaching safepoint: 534165 ns, At safepoint: 1046076 ns, Total: 1580241 ns
[2022-04-22T18:40:48.729+0000][126][gc,marking  ] GC(68198) Concurrent Cleanup for Next Mark
[2022-04-22T18:40:48.730+0000][126][gc,marking  ] GC(68198) Concurrent Cleanup for Next Mark 1.379ms
[2022-04-22T18:40:48.730+0000][126][gc          ] GC(68198) Concurrent Cycle 1713.552ms
[2022-04-22T18:40:49.078+0000][126][gc,start    ] GC(68199) Pause Young (Concurrent Start) (G1 Humongous Allocation)
[2022-04-22T18:40:49.078+0000][126][gc,task     ] GC(68199) Using 2 workers of 2 for evacuation
[2022-04-22T18:40:49.078+0000][126][gc,age      ] GC(68199) Desired survivor size 19398656 bytes, new threshold 15 (max threshold 15)
[2022-04-22T18:40:49.092+0000][126][gc,age      ] GC(68199) Age table with threshold 15 (max threshold 15)
[2022-04-22T18:40:49.092+0000][126][gc,age      ] GC(68199) - age   1:    5292360 bytes,    5292360 total
[2022-04-22T18:40:49.092+0000][126][gc,age      ] GC(68199) - age   2:    1678592 bytes,    6970952 total
[2022-04-22T18:40:49.092+0000][126][gc,phases   ] GC(68199)   Pre Evacuate Collection Set: 0.2ms
[2022-04-22T18:40:49.092+0000][126][gc,phases   ] GC(68199)   Merge Heap Roots: 0.3ms
[2022-04-22T18:40:49.092+0000][126][gc,phases   ] GC(68199)   Evacuate Collection Set: 12.1ms
[2022-04-22T18:40:49.092+0000][126][gc,phases   ] GC(68199)   Post Evacuate Collection Set: 1.0ms
[2022-04-22T18:40:49.092+0000][126][gc,phases   ] GC(68199)   Other: 0.4ms
[2022-04-22T18:40:49.092+0000][126][gc,heap     ] GC(68199) Eden regions: 233->0(290)
[2022-04-22T18:40:49.092+0000][126][gc,heap     ] GC(68199) Survivor regions: 3->8(37)
[2022-04-22T18:40:49.092+0000][126][gc,heap     ] GC(68199) Old regions: 412->412
[2022-04-22T18:40:49.092+0000][126][gc,heap     ] GC(68199) Archive regions: 2->2
[2022-04-22T18:40:49.092+0000][126][gc,heap     ] GC(68199) Humongous regions: 16->7
[2022-04-22T18:40:49.092+0000][126][gc,metaspace] GC(68199) Metaspace: 82582K(85680K)->82582K(85680K) NonClass: 73279K(75696K)->73279K(75696K) Class: 9302K(9984K)->9302K(9984K)
[2022-04-22T18:40:49.092+0000][126][gc          ] GC(68199) Pause Young (Concurrent Start) (G1 Humongous Allocation) 664M->427M(1024M) 14.168ms
[2022-04-22T18:40:49.092+0000][126][gc,cpu      ] GC(68199) User=0.02s Sys=0.00s Real=0.01s
[2022-04-22T18:40:49.092+0000][126][gc          ] GC(68200) Concurrent Cycle
[2022-04-22T18:40:49.092+0000][126][gc,marking  ] GC(68200) Concurrent Clear Claimed Marks
[2022-04-22T18:40:49.092+0000][126][safepoint   ] Safepoint "G1TryInitiateConcMark", Time since last: 349242909 ns, Reaching safepoint: 198241 ns, At safepoint: 14339396 ns, Total: 14537637 ns
[2022-04-22T18:40:49.092+0000][126][gc,marking  ] GC(68200) Concurrent Clear Claimed Marks 0.069ms
[2022-04-22T18:40:49.092+0000][126][gc,marking  ] GC(68200) Concurrent Scan Root Regions
[2022-04-22T18:40:49.097+0000][126][gc,marking  ] GC(68200) Concurrent Scan Root Regions 4.342ms
[2022-04-22T18:40:49.097+0000][126][gc,marking  ] GC(68200) Concurrent Mark (173254.107s)
[2022-04-22T18:40:49.097+0000][126][gc,marking  ] GC(68200) Concurrent Mark From Roots
[2022-04-22T18:40:49.097+0000][126][gc,task     ] GC(68200) Using 1 workers of 1 for marking
[2022-04-22T18:40:50.105+0000][126][gc,marking  ] GC(68200) Concurrent Mark From Roots 1007.836ms
[2022-04-22T18:40:50.105+0000][126][gc,marking  ] GC(68200) Concurrent Preclean
[2022-04-22T18:40:50.107+0000][126][gc,marking  ] GC(68200) Concurrent Preclean 2.055ms
[2022-04-22T18:40:50.107+0000][126][gc,marking  ] GC(68200) Concurrent Mark (173254.107s, 173255.117s) 1010.017ms
[2022-04-22T18:40:50.107+0000][126][gc,start    ] GC(68200) Pause Remark
[2022-04-22T18:40:50.133+0000][126][gc          ] GC(68200) Pause Remark 521M->519M(1024M) 26.026ms
[2022-04-22T18:40:50.133+0000][126][gc,cpu      ] GC(68200) User=0.04s Sys=0.01s Real=0.03s
[2022-04-22T18:40:50.133+0000][126][safepoint   ] Safepoint "G1Concurrent", Time since last: 1014570315 ns, Reaching safepoint: 215059 ns, At safepoint: 26221867 ns, Total: 26436926 ns
[2022-04-22T18:40:50.133+0000][126][gc,marking  ] GC(68200) Concurrent Rebuild Remembered Sets
[2022-04-22T18:40:50.898+0000][126][gc,marking  ] GC(68200) Concurrent Rebuild Remembered Sets 764.420ms
[2022-04-22T18:40:50.898+0000][126][gc,start    ] GC(68200) Pause Cleanup
[2022-04-22T18:40:50.899+0000][126][gc          ] GC(68200) Pause Cleanup 626M->626M(1024M) 0.743ms
[2022-04-22T18:40:50.899+0000][126][gc,cpu      ] GC(68200) User=0.00s Sys=0.00s Real=0.00s
[2022-04-22T18:40:50.899+0000][126][safepoint   ] Safepoint "G1Concurrent", Time since last: 764742546 ns, Reaching safepoint: 266387 ns, At safepoint: 879465 ns, Total: 1145852 ns
[2022-04-22T18:40:50.899+0000][126][gc,marking  ] GC(68200) Concurrent Cleanup for Next Mark
I create a index Set with the rotation config of delete index after 365 days and no, it should be then a standalone index, so I can later search for that in the log search
The way you have your indexes set up you have created more shards than Elasticsearch is meant to handle by default - here is a related post on Elasticsearch forums
Hello
@tmacgbay I just caught that :smiley:
@Gamienator
As for your second Log post, That looks like the GC logs, I was referring to elasticsearch logs.
Should be in this directory…
What @tmacgbay stated is correct, you have to many shards.
Hey everyone,
wanted to shout out that I was still not able to check this, since I got sick :confused: I’ll read all the documents soon and hopefully understand how to fix that :slight_smile:
Only wanted to write that down :slight_smile:
Hey everyone,
so I read a lot but I really don’t unterstand why I got so many shards, and how to reduce them :confused:. I do really struggle how to interact with it :confused:
Does anybody can give me a hint where to start or got a documentation?
You can see a lot more detail than you need about Elasticsearch shards here. Good to skim so you have an understanding of how Elasticsearch data is stored relative to shards.
Each index you have in GRAYLOG manages settings in Elasticsearch for shards. If you go into Graylog System/Indicies and open an index, you likely have four shards (default) that would look like this:
Pulling a little math together - Your Index Set (perhaps named banana) has a series of indexes (banana_30, banana_31, banana_32…) depending on what your retention is. If your retention is 10 indexes, each having 4 shards… that is 40 shards of banana right there.
When you look at all of your Index Sets (System/Indicies) it should list in gray how many indexes are being retained - add those up, multiply by 4 (if you have taken 4 as default across the board) and you will have total shards.
I believe you only need a shard and/or replica per node in a cluster so if you are running a single node environment you only need one shard - DOUBLE CHECK THAT!!!
You can edit an index set and modify the number of shards it uses, but it won’t change until the index rotates to the next instance - which you can force.
Be careful on production systems - I am giving you forum advice, not expert advice… :smiley:
Aaah okay, so that happened.
I really overscaled the ability of the system. I got 23 Indicies, and I thought, well its okay to have a daily retention and save them vor 365 days! Oh boy was I wrong. When I was writing this post I changed that und turned the holding time for 30 days.
Yes I’m only running one node. Anyone other here that would say that too I’m needing only 1 shard?
Did some more research and here is some more detail on managing number of shards. if you have more than one they are used in parallel which would offer some advantage perhaps in a single node… more in a cluster of course.
