Graylog Big Problem
Dear Community,
I’m am having problem with Graylog as details below:
  • Graylog message appear 0 in / 0 out
  • Can not query message with error below:
While retrieving data for this widget, the following error(s) occurred:
Request cannot be executed; I/O reactor status: STOPPED.
  • Go to system/overview, found message notification below:
–There was no master Graylog server node detected in the cluster.
—Certain operations of Graylog server require the presence of a master node, but no such master was started. Please ensure that one of your Graylog server nodes contains the setting is_master = true in its configuration and that it is running. Until this is resolved index cycling will not be able to run, which means that the index retention mechanism is also not running, leading to increased index sizes. Certain maintenance functions as well as a variety of web interface pages (e.g. Dashboards) are unavailable.
–System messages:
—Node: Unknown Node
—Notification condition [NO_MASTER] has been fixed.
  • OS Information: CentOS 7.0
  • Package Version: Graylog v4.2.12+2c655fb
    –>As describe in incident above
–>I have tried googling, but it can not be fixed yet…
–>Please help advise.
Should you require for information, please kindly let me know.
Thank you.
Did you verify this was in the config file for one of your graylog servers?
Im using graylog version 3 on Ubuntu but my config file is located
/etc/graylog/server/server.conf
is_master is on line 47
Hi Patrick,
Thank you for your comment.
Yes, i checked: is_master = true
Would you please help advise more?
Can you remove any sensitive information and show your config file?
Dear Patrick,
Many thanks for your more comment, please find the config file below:
[graylog ~]$ cat /etc/graylog/server/server.conf
GRAYLOG CONFIGURATION FILE
is_master = true
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
Should you require more information, please kindly let me know.
Thank you.
Again Im looking at Graylog v3, but my config file has alot more info in it. You may want to look for a config file for v4 and compare yours to it. (I had to Split it into 2 Posts)
Server.conf Part 1
admin@graylog:~$ cat /etc/graylog/server/server.conf
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# ATTENTION: This value must be the same on all Graylog nodes in the cluster.
# Changing this value after installation will render all user sessions and encrypted values in the database invalid. (e.g. encrypted access tokens)
password_secret = SECRETPW
root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = ROOTPW
# Default is empty
#root_email = ""
# Default is UTC
root_timezone = America/New_York
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
Server.conf Part2
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
#http_bind_address = 127.0.0.7:9000
http_bind_address = 1.192.168.11:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
#http_publish_uri = http://192.168.1.1:9000/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri = https://graylog
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
#http_tls_cert_file = /etc/graylog/server/graylog-3.crt
#http_tls_key_file = /etc/graylog/server/graylog-3.pem
# The password to unlock the private key used for securing the HTTP interface.
# http_tls_key_password = ""
# requires authentication.
elasticsearch_hosts = http://elsdb:9200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 200
#elasticsearch_max_total_connections = 200
# elasticsearch server).
# Default: 20
#elasticsearch_max_total_connections_per_route = 20
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Set the default scheme when connecting to Elasticsearch discovered nodes
# Default: http (available options: http, https)
#elasticsearch_discovery_default_scheme = http
# Default: false
# Enable use of "Expect: 100-continue" Header for Elasticsearch index requests.
# If this is disabled, Graylog cannot properly handle HTTP 413 Request Entity Too Large errors.
# Default: true
#elasticsearch_use_expect_continue = true
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
message_journal_max_size = 5gb
async_eventbus_processors = 2
# disabled if not set.
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
# DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format
#mongodb_uri = mongodb+srv://server.example.org/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
transport_email_hostname = EMAILIP
transport_email_port = 25
transport_email_use_auth = true
transport_email_use_tls = true
transport_email_auth_username =
transport_email_auth_password =
transport_email_from_email = GraylogNotification@DOMAIN.com
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
transport_email_web_interface_url = https://graylog
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
dashboard_widget_default_cache_time = 10s
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
# The server is writing processing status information to the database on a regular basis. This setting controls how
# often the data is written to the database.
# Default: 1s (cannot be less than 1s)
#processing_status_persist_interval = 1s
# Configures the threshold for detecting outdated processing status records. Any records that haven't been updated
# in the configured threshold will be ignored.
# Default: 1m (one minute)
#processing_status_update_threshold = 1m
# Configures the journal write rate threshold for selecting processing status records. Any records that have a lower
# one minute rate than the configured value might be ignored. (dependent on number of messages in the journal)
# Default: 1
#processing_status_journal_write_rate_threshold = 1
# Configures the prefix used for graylog event indices
# Default: gl-events
#default_events_index_prefix = gl-events
# Configures the prefix used for graylog system event indices
# Default: gl-system-events
#default_system_events_index_prefix = gl-system-events
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
content_packs_auto_install = grok-patterns.json
# The allowed TLS protocols for system wide TLS enabled servers. (e.g. message inputs, http interface)
# Setting this to an empty value, leaves it up to system libraries and the used JDK to chose a default.
# Default: TLSv1.2,TLSv1.3  (might be automatically adjusted to protocols supported by the JDK)
#enabled_tls_protocols= TLSv1.2,TLSv1.3
Just chiming in @Grayuser78
if you could use the markdown on top of the text box before you hit the REPLY button that would help us out a lot. It makes it easier to read :+1:
Dear Patrick,
Please help recheck the config below into 3 parts, thanks…
[part1]
[graylog@graylog ~]$ cat /etc/graylog/server/server.conf
# as defined in Chapter 3. Lexical Structure, using the \u prefix.
# name=Stephen
# name = Stephen
# For example:
*# targetCities=*
*# Detroit,*
*# Chicago,*
# Los Angeles
# path=c:\docs\doc1
# instances as master. The master will perform some periodical tasks that non-masters won’t perform.
is_master = true
password_secret = password
# The default root user is named ‘admin’
#root_username = admin
root_password_sha2 = root_password
# Default is empty
#root_email = “”
# The time zone setting of the root user. See Joda-Time – Java date and time API - Time Zones for a list of valid time zones.
# Default is UTC
# Default: bin
# Default: data
[part2]
# HTTP settings
# This configuration setting must not contain a wildcard address!
# This setting can be overriden on a per-request basis with the “X-Graylog-Server-URL” HTTP request header.
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
# HTTPS settings
# Default: false
#http_tls_key_password = password
# Maximum number of retries to connect to elasticsearch on boot for the version probe.
# Default: 0, retry indefinitely with the given delay until a connection could be established
#elasticsearch_version_probe_attempts = 5
# Waiting time in between connection attempts for elasticsearch_version_probe_attempts
# Default: 5s
#elasticsearch_version_probe_delay = 5s
# Maximum amount of time to wait for successful connection to Elasticsearch HTTP port.
# (e. g. during search, index creation, or index time-range calculations)
# be tore down.
# Default: inf
# Default: 200
# Default: 20
# Default: 2
# see Nodes Info | Elasticsearch Reference [5.4] | Elastic
# Default: false
#elasticsearch_discovery_enabled = true
# see Cluster APIs | Elasticsearch Reference [5.4] | Elastic
# Default: empty
# Default: 30s
# Default: false
# Enable use of “Expect: 100-continue” Header for Elasticsearch index requests.
# Default: true
# Graylog will use multiple indices to store documents in. You can configure the strategy it uses to determine
# It supports multiple rotation strategies, the default being “count”:
# - “count” of messages per index, use elasticsearch_max_docs_per_index below to configure
# - “size” per index, use elasticsearch_max_size_per_index below to configure
# - “time” interval between index rotations, use elasticsearch_max_time_per_index to configure
# A strategy may be disabled by specifying the optional enabled_index_rotation_strategies list and excluding that strategy.
#enabled_index_rotation_strategies = count,size,time
# index related settings can be changed in the Graylog web interface on the ‘System / Indices’ page.
# Also see Index model
# Configure this if you used ‘rotation_strategy = count’ above.
# Configure this if you used ‘rotation_strategy = size’ above.
# Configure this if you used ‘rotation_strategy = time’ above.
# 1w = 1 week
# 1d = 1 day
# 12h = 12 hours
# Optional upper bound on elasticsearch_max_time_per_index
# elasticsearch_max_write_index_age = 1d
# be enabled with care. See also: Search query language
# Analyzer (tokenizer) to use for message and full_message field. The “standard” filter usually is a good idea.
# Elasticsearch documentation: Analysis | Elasticsearch Guide [2.3] | Elastic
# Default: 1h
# Default: 20
# Mute the logging-output of ES deprecation warnings during REST calls in the ES RestClient
#elasticsearch_mute_deprecation_warnings = true
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn’t
# Default: 1h
# (“outputbuffer_processors” variable)
[part3]
# The following settings (outputbuffer_processor_) configure the thread pools backing each output buffer processor.*
# See ThreadPoolExecutor (Java Platform SE 8 ) for technical details
# Default: 5000
# Default: 3
# Default: 30
# Possible types:
# - yielding
# - sleeping
# - blocking
# - busy_spinning
# Must be a power of 2. (512, 1024, 2048, …)
ring_size = 65536
# Manually stopped inputs are no longer auto-restarted. To re-enable the previous behavior, set auto_restart_inputs to true.
#auto_restart_inputs = true
# Enable the message journal.
# ATTENTION:
# If you create a seperate partition for the journal files and use a file system creating directories like ‘lost+found’
# If the stream matching for one stream took longer than the timeout value, and this happened more than “max_faults” times
# messages end up.
# ‘+’-signs in the username or password need to be replaced by ‘%2B’
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_subject_prefix = [graylog]
# ATTENTION:
# Using SMTP with STARTTLS and SMTPS at the same time is not possible.
# Use SMTP with STARTTLS, see Opportunistic TLS - Wikipedia
# Use SMTP over SSL (SMTPS), see SMTPS - Wikipedia
# Default: 5s
# Default: 10s
# Default: 10s
# ATTENTION: If you configure a proxy, make sure to also configure the “http_non_proxy_hosts” option so internal
# Examples:
#http_proxy_uri =
# This is a list of patterns separated by “,”. The patterns may start or end with a "" for wildcards.*
# Examples:
# - 10.0.,.example.com
# cycled indices.
# Disable the use of a native system stats collector (currently OSHI)
#disable_native_system_stats_collector = false
# of threads available for this. Increase it, if '/cluster/’ requests take long to complete.*
# Configures the threshold for detecting outdated processing status records. Any records that haven’t been updated
# Default: 1
# Automatically load content packs in “content_packs_dir” on the first start of Graylog.
#content_packs_loader_enabled = false
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in “content_packs_dir”) which should be applied on
# Default: empty
#content_packs_auto_install = grok-patterns.json
# Enable Prometheus exporter HTTP server.
# Default: false
#prometheus_exporter_enabled = false
# IP address and port for the Prometheus exporter HTTP server.
# Default: 127.0.0.1:9833
#prometheus_exporter_bind_address = 127.0.0.1:9833
# Path to the Prometheus exporter core mapping file. If this option is enabled, the full built-in core mapping is
# replaced with the mappings in this file.
# This file is monitored for changes and updates will be applied at runtime.
# Default: none
#prometheus_exporter_mapping_file_path_core = prometheus-exporter-mapping-core.yml
# Path to the Prometheus exporter custom mapping file. If this option is enabled, the mappings in this file are
# configured in addition to the built-in core mappings. The mappings in this file cannot overwrite any core mappings.
# Default: none
#prometheus_exporter_mapping_file_path_custom = prometheus-exporter-mapping-custom.yml
# Configures the refresh interval for the monitored Prometheus exporter mapping files.
# Default: 60s
#prometheus_exporter_mapping_file_refresh_interval = 60s
# Optional allowed paths for Graylog data files. If provided, certain operations in Graylog will only be permitted
# if the data file(s) are located in the specified paths (for example, with the CSV File lookup adapter).
# All subdirectories of indicated paths are allowed by default. This Provides an additional layer of security,
# and allows administrators to control where in the file system Graylog users can select files from.
#allowed_auxiliary_paths = /etc/graylog/data-files,/etc/custom-allowed-path
END
I would recommend comparing the settings in yours to what I posted and/or try tracking down a working v4 config file and verify your settings against that.
Hello @Grayuser78
Add on to @tfpk suggestion.
When posting config files you can execute this…
cat /etc/graylog/server/server.conf | egrep -v "^\s*(#|$)"
It will make those configuration files smaller and easier to read, Just an FYI.
Hi @gsmith ,
Thank you for your advice. Please help advise more below if something wrong causing the issue, thanks…
$ cat /etc/graylog/server/server.conf | egrep -v “^\s*(#|$)”
is_master = true
password_secret = …
root_password_sha2 = …
ring_size = 65536
Hello.
what I understand from the configuration file that is posted.
MongoDb BY default, your using localhost:27017
Elasticsearch BY default, your using 127.0.0.1:9200
you binding this Graylog server to any IP address http_bind_address = 0.0.0.0:9000
Perhaps have you tried
http_bind_address = you_ip_address:9000
Example:
http_bind_address = 192.168.1.100:9000
Also, The Elasticsearch configuration should look something like this then.
[root@graylog streams]# cat /etc/elasticsearch/elasticsearch.yml | egrep -v "^\s*(#|$)"
cluster.name: graylog
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
network.host: 127.0.0.1
http.port: 9200
discovery.type: single-node
bootstrap.memory_lock: true
If your using the above configuration try this setting in Graylog configuration located here.
Perhaps something like this.
elasticsearch_hosts =http://127.0.0.1:9200
Remember when editing any one of these configuration files ensure the service is restarted.
And always ensure Elasticsearch/Opensearch is fully started before starting Graylog services
Dear @gsmith ,
Many thanks for your more information.
I have tried restart service Elasticsearch and service Graylog on the server. After that, i can search/query old logs message back. But it show another error as shown below…
Please you and everyone help more advise.
Thanks with best regards.
Hey
To many documents for your indices, Double check you log file’s.
ensure elasticsearch is working correct, may want to use cURL commands to check the health, indices, etc…
Try rotating you indices manually see it that clears it up, but it might just be a warning your seeing, so again check you log files for Graylog && Elasticsearch
Dear @gsmith,
Thank you for your more comment.
Could you please advise details below?:
  • the cURL commands
  • and how to rotate the indices manually…
  • and the command to check the log files for Graylog && Elasticsearch
Thanks,
Best regards
Hey,
Did a quick search for you, the following link’s under the questions should supply the information you need.
https://docs.graylog.org/docs/file-locations
hope that helps
Dear @gsmith , thank you for your more information.
During i’m verifying and now my graylog server below 100% state as image screenshot attached, would you or our graylog community team assist advise more on that?
Thanks with my best regards.
