Node running but indices failed to fetch
Logged in to Graylog web to find default index not set. In the logs: ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
2018-04-30_05:40:53.31946 java.lang.IllegalStateException: No default index set configured. This is a bug!
I didn’t make any changes. Full logs here: https://pastebin.com/wL35mSRX
What Graylog Version did you run? What Elasticsearch Version did you run? Is this error after first start? How did you installed Graylog?
No this error is not after first start, i have been using this for a month with multiple streams and indices. I used a community AMI in AWS.
Graylog Version:
2.4.3+2c41897, codename Wildwuchs
ElasticSearch: “version” : {
“number” : “5.6.3”,
“build_hash” : “1a2f265”,
“build_date” : “2017-10-06T20:33:39.012Z”,
“build_snapshot” : false,
“lucene_version” : “6.6.1”
MongoDB: 3.4.9
Also i see the following in the system messages:
2018-04-30T01:40:47-04:00 908753fe / graylog Cycled index alias <indice_deflector> from to <indice_0>.
2018-04-30T01:40:47-04:00 908753fe / graylog There is no index target to point to. Creating one now.
2018-04-30T01:39:57-04:00 908753fe / graylog Cycled index alias <log_deflector> from to <log_0>.
2018-04-30T01:39:57-04:00 908753fe / graylog There is no index target to point to. Creating one now.
2018-04-30T01:38:17-04:00 908753fe / graylog Cycled index alias <set_deflector> from to <set_0>.
2018-04-30T01:38:17-04:00 908753fe / graylog There is no index target to point to. Creating one now.
what about the elasticseach in your setup?
Did you checked the logfiles? What is the cluster health and status?
curl -X GET "localhost:9200/_cluster/health"
Elasticsearch logs:
[o.e.t.n.Netty4Transport ] [2MXMvOB] exception caught on transport layer [[id: 0x5284ea6f, L:/172.31.43.119:9300 ! R:/185.143.223.154:2370]], closing connection
io.netty.handler.codec.DecoderException: java.io.StreamCorruptedException: invalid internal transport message format, got (3,0,0,2f)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:459) ~[netty-codec-4.1.13.Final.jar:4.1.13.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:392) ~[netty-codec-4.1.13.Final.jar:4.1.13.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:359) ~[netty-codec-4.1.13.Final.jar:4.1.13.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelInactive(ByteToMessageDecoder.java:342) ~[netty-codec-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:245) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:231) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelInactive(AbstractChannelHandlerContext.java:224) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.ChannelInboundHandlerAdapter.channelInactive(ChannelInboundHandlerAdapter.java:75) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.handler.logging.LoggingHandler.channelInactive(LoggingHandler.java:167) [netty-handler-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelInactive(DefaultChannelPipeline.java:1329) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelInactive(DefaultChannelPipeline.java:908) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.AbstractChannel$AbstractUnsafe$7.run(AbstractChannel.java:744) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) [netty-common-4.1.13.Final.jar:4.1.13.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:403) [netty-common-4.1.13.Final.jar:4.1.13.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:462) [netty-transport-4.1.13.Final.jar:4.1.13.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:858) [netty-common-4.1.13.Final.jar:4.1.13.Final]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_161]
Caused by: java.io.StreamCorruptedException: invalid internal transport message format, got (3,0,0,2f)
at org.elasticsearch.transport.TcpTransport.validateMessageHeader(TcpTransport.java:1276) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.transport.netty4.Netty4SizeHeaderFrameDecoder.decode(Netty4SizeHeaderFrameDecoder.java:36) ~[?:?]
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:489) ~[?:?]
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:428) ~[?:?]
… 24 more
Cluster Health:
“cluster_name”:“graylog”,
“status”:“yellow”,
“timed_out”:false,
“number_of_nodes”:1,
“number_of_data_nodes”:1,
“active_primary_shards”:24,
“active_shards”:24,
“relocating_shards”:0,
“initializing_shards”:0,
“unassigned_shards”:4,
“delayed_unassigned_shards”:0,
“number_of_pending_tasks”:0,
“number_of_in_flight_fetch”:0,
“task_max_waiting_in_queue_millis”:0,
“active_shards_percent_as_number”:85.71428571428571
first, please format your posts to have them easier to read for others. Our FAQ gives some hints on how to do that.
You have 4 unassigned shards, making the cluster yellow ( http://docs.graylog.org/en/2.4/pages/configuration/elasticsearch.html#cluster-status-explained ). As a wild guess - did you checkd the available space for Elasticsearch? Did you find something like low-water-mark in the elasticsearch logfiles?
When you fixed the Elasticsearch unassigned shards, your problem might be resolved. This might help you with that: https://www.datadoghq.com/blog/elasticsearch-unassigned-shards/
So after reading the article, i understood not to have a single node elasticsearch cluster. Is that true?
