alias
(alias)
December 13, 2017, 4:21pm
1
Hi all,
I’ve installed 3 graylod node (on each node : graylog, es, mongo).
The versions are:
Graylog : 2.3.2
ES : 5.6.5
Mongo : 3.4.10
Topo :
1 master node
2 slave nodes
I’ve differents errors :
In WebUI: [System/Overview] :
** Deflector exists as an index and is not an alias
** Elasticsearch cluster yellow status with shards unassigned
** System messages with : Deflector is pointing to [null], not the newest one : [graylog_0]. Re-pointing.
In logs:
** ERROR [IndexRotationThread] Couldn’t point deflector to a new index … Couldn’t collect aliases for index pattern graylog_*
** Index not found for query : graylog_2
If I use curl for shards:
curl -X GET localhost:9200/_cat_shards
All are started and unassigned
If I use curl for indices :
curl localhost:9200/_cat/indices?v
I’ve graylog indices:
graylog_0
graylog_1
graylog_2
All indices are in yellow state and open status.
Someone have an idea to resolv this errors ?
jochen
(Jochen)
December 13, 2017, 5:08pm
2
How did you install Graylog, Elasticsearch, and MongoDB?
What’s the full configuration of all Graylog, Elasticsearch, and MongoDB nodes?
What’s your network topology?
alias
(alias)
December 14, 2017, 8:48am
3
Hi @jochen ,
Nodes informations:
I’ve the “Sorry, new users can only put 2 links in a post.” error. What’s your regex to detect it ? I tried differents posts but errors …
jochen
(Jochen)
December 14, 2017, 9:21am
4
Try using proper formatting for code blocks and text snippets (see Markdown Reference ) or post your configuration files and logs to a paste service such as https://gist.github.com/ or https://0bin.net/ .
alias
(alias)
December 14, 2017, 9:31am
5
hi @jochen
Node01:
[root@node01 ~]# cat /etc/graylog/server/log4j2.xml
<?xml version="1.0" encoding="UTF-8"?>
<Configuration packages="org.graylog2.log4j" shutdownHook="disable">
<Appenders>
<RollingFile name="rolling-file" fileName="/var/log/graylog-server/server.log" filePattern="/var/log/graylog-server/server.log.%i.gz">
<PatternLayout pattern="%d{yyyy-MM-dd'T'HH:mm:ss.SSSXXX} %-5p [%c{1}] %m%n"/>
<Policies>
<SizeBasedTriggeringPolicy size="50MB"/>
</Policies>
<DefaultRolloverStrategy max="10" fileIndex="min"/>
</RollingFile>
<!-- Internal Graylog log appender. Please do not disable. This makes internal log messages available via REST calls. -->
<Memory name="graylog-internal-logs" bufferSize="500"/>
</Appenders>
<Loggers>
<!-- Application Loggers -->
<Logger name="org.graylog2" level="info"/>
<Logger name="com.github.joschi.jadconfig" level="warn"/>
<!-- This emits a harmless warning for ActiveDirectory every time which we can't work around :( -->
<Logger name="org.apache.directory.api.ldap.model.message.BindRequestImpl" level="error"/>
<!-- Prevent DEBUG message about Lucene Expressions not found. -->
<Logger name="org.elasticsearch.script" level="warn"/>
<!-- Disable messages from the version check -->
<Logger name="org.graylog2.periodical.VersionCheckThread" level="off"/>
<!-- Suppress crazy byte array dump of Drools -->
<Logger name="org.drools.compiler.kie.builder.impl.KieRepositoryImpl" level="warn"/>
<!-- Silence chatty natty -->
<Logger name="com.joestelmach.natty.Parser" level="warn"/>
<!-- Silence Kafka log chatter -->
<Logger name="kafka.log.Log" level="warn"/>
<Logger name="kafka.log.OffsetIndex" level="warn"/>
<!-- Silence useless session validation messages -->
<Logger name="org.apache.shiro.session.mgt.AbstractValidatingSessionManager" level="warn"/>
<Root level="warn">
<AppenderRef ref="rolling-file"/>
<AppenderRef ref="graylog-internal-logs"/>
</Root>
</Loggers>
</Configuration>
[root@node01 ~]# cat /etc/graylog/server/server.conf | grep -v "^#"
is_master = true
password_secret = ****************
root_password_sha2 = ****************
rest_listen_uri = http://10.0.0.1:9000/api/
web_listen_uri = http://10.0.0.1:9000/
elasticsearch_hosts = http://10.0.0.1:9200,http://10.0.0.2:9200,http://10.0.0.3:9200
rotation_strategy = count
elasticsearch_max_docs_per_index = 50000000
elasticsearch_max_number_of_indices = 50
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 1
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
mongodb_uri = mongodb://10.0.0.1:27017,10.0.0.2:27017,10.0.0.3:27017/graylog
[root@node01 ~]# cat /etc/graylog/server/node-id
c006c84e-51e6-****************-91d0396e9673
[root@node01 ~]# cat /etc/elasticsearch/elasticsearch.yml | grep -v "^#"
cluster.name: graylog
node.name: node-01
path.data: /data/elasticsearch
path.logs: /var/log/elasticsearch
network.host: ["127.0.0.1","10.0.0.1"]
[root@node01 ~]# cat /etc/elasticsearch/jvm.options | grep -v "^#"
-Xms2g
-Xmx2g
-XX:+UseConcMarkSweepGC
-XX:CMSInitiatingOccupancyFraction=75
-XX:+UseCMSInitiatingOccupancyOnly
-XX:+AlwaysPreTouch
-server
-Xss1m
-Djava.awt.headless=true
-Dfile.encoding=UTF-8
-Djna.nosys=true
-Djdk.io.permissionsUseCanonicalPath=true
-Dio.netty.noUnsafe=true
-Dio.netty.noKeySetOptimization=true
-Dio.netty.recycler.maxCapacityPerThread=0
-Dlog4j.shutdownHookEnabled=false
-Dlog4j2.disable.jmx=true
-Dlog4j.skipJansi=true
-XX:+HeapDumpOnOutOfMemoryError
[root@node01 ~]# cat /etc/elasticsearch/log4j2.properties | grep -v "^#"
status = error
logger.action.name = org.elasticsearch.action
logger.action.level = debug
appender.console.type = Console
appender.console.name = console
appender.console.layout.type = PatternLayout
appender.console.layout.pattern = [%d{ISO8601}][%-5p][%-25c{1.}] %marker%m%n
appender.rolling.type = RollingFile
appender.rolling.name = rolling
appender.rolling.fileName = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}.log
appender.rolling.layout.type = PatternLayout
appender.rolling.layout.pattern = [%d{ISO8601}][%-5p][%-25c{1.}] %marker%.-10000m%n
appender.rolling.filePattern = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}-%d{yyyy-MM-dd}.log
appender.rolling.policies.type = Policies
appender.rolling.policies.time.type = TimeBasedTriggeringPolicy
appender.rolling.policies.time.interval = 1
appender.rolling.policies.time.modulate = true
rootLogger.level = info
rootLogger.appenderRef.console.ref = console
rootLogger.appenderRef.rolling.ref = rolling
appender.deprecation_rolling.type = RollingFile
appender.deprecation_rolling.name = deprecation_rolling
appender.deprecation_rolling.fileName = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}_deprecation.log
appender.deprecation_rolling.layout.type = PatternLayout
appender.deprecation_rolling.layout.pattern = [%d{ISO8601}][%-5p][%-25c{1.}] %marker%.-10000m%n
appender.deprecation_rolling.filePattern = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}_deprecation-%i.log.gz
appender.deprecation_rolling.policies.type = Policies
appender.deprecation_rolling.policies.size.type = SizeBasedTriggeringPolicy
appender.deprecation_rolling.policies.size.size = 1GB
appender.deprecation_rolling.strategy.type = DefaultRolloverStrategy
appender.deprecation_rolling.strategy.max = 4
logger.deprecation.name = org.elasticsearch.deprecation
logger.deprecation.level = warn
logger.deprecation.appenderRef.deprecation_rolling.ref = deprecation_rolling
logger.deprecation.additivity = false
appender.index_search_slowlog_rolling.type = RollingFile
appender.index_search_slowlog_rolling.name = index_search_slowlog_rolling
appender.index_search_slowlog_rolling.fileName = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}_index_search_slowlog.log
appender.index_search_slowlog_rolling.layout.type = PatternLayout
appender.index_search_slowlog_rolling.layout.pattern = [%d{ISO8601}][%-5p][%-25c] %marker%.-10000m%n
appender.index_search_slowlog_rolling.filePattern = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}_index_search_slowlog-%d{yyyy-MM-dd}.log
appender.index_search_slowlog_rolling.policies.type = Policies
appender.index_search_slowlog_rolling.policies.time.type = TimeBasedTriggeringPolicy
appender.index_search_slowlog_rolling.policies.time.interval = 1
appender.index_search_slowlog_rolling.policies.time.modulate = true
logger.index_search_slowlog_rolling.name = index.search.slowlog
logger.index_search_slowlog_rolling.level = trace
logger.index_search_slowlog_rolling.appenderRef.index_search_slowlog_rolling.ref = index_search_slowlog_rolling
logger.index_search_slowlog_rolling.additivity = false
appender.index_indexing_slowlog_rolling.type = RollingFile
appender.index_indexing_slowlog_rolling.name = index_indexing_slowlog_rolling
appender.index_indexing_slowlog_rolling.fileName = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}_index_indexing_slowlog.log
appender.index_indexing_slowlog_rolling.layout.type = PatternLayout
appender.index_indexing_slowlog_rolling.layout.pattern = [%d{ISO8601}][%-5p][%-25c] %marker%.-10000m%n
appender.index_indexing_slowlog_rolling.filePattern = ${sys:es.logs.base_path}${sys:file.separator}${sys:es.logs.cluster_name}_index_indexing_slowlog-%d{yyyy-MM-dd}.log
appender.index_indexing_slowlog_rolling.policies.type = Policies
appender.index_indexing_slowlog_rolling.policies.time.type = TimeBasedTriggeringPolicy
appender.index_indexing_slowlog_rolling.policies.time.interval = 1
appender.index_indexing_slowlog_rolling.policies.time.modulate = true
logger.index_indexing_slowlog.name = index.indexing.slowlog.index
logger.index_indexing_slowlog.level = trace
logger.index_indexing_slowlog.appenderRef.index_indexing_slowlog_rolling.ref = index_indexing_slowlog_rolling
logger.index_indexing_slowlog.additivity = false
Node02:
[root@node02 ~]# cat /etc/graylog/server/log4j2.xml
<Appenders>
<Policies>
</Policies>
</RollingFile>
</Appenders>
<Loggers>
<Root level="warn">
</Root>
</Loggers>
</Configuration>
[root@node02 ~]# cat /etc/graylog/server/server.conf | grep -v "^#"
is_master = false
rest_listen_uri = http://10.0.0.2:9000/api/
web_listen_uri = http://10.0.0.2:9000/
ring_size = 65536
[root@node02 ~]# cat /etc/graylog/server/node-id
5259c1a5-9580-****************-435f094f5285
[root@node02 ~]# cat /etc/elasticsearch/elasticsearch.yml | grep -v "^#"
node.name: node-02
network.host: ["127.0.0.1","10.0.0.2"]
[root@node02 ~]# cat /etc/elasticsearch/jvm.options | grep -v "^#"
-Xms2g
-Xmx2g
-XX:+AlwaysPreTouch
-server
-Xss1m
-Djna.nosys=true
[root@node02 ~]# cat /etc/elasticsearch/log4j2.properties | grep -v "^#"
status = error
Node03:
[root@node03 ~]# cat /etc/graylog/server/log4j2.xml
<Appenders>
<Policies>
</Policies>
</RollingFile>
</Appenders>
<Loggers>
<Root level="warn">
</Root>
</Loggers>
</Configuration>
[root@node03 ~]# cat /etc/graylog/server/server.conf | grep -v "^#"
is_master = false
rest_listen_uri = http://10.0.0.3:9000/api/
web_listen_uri = http://10.0.0.3:9000/
ring_size = 65536
[root@node03 ~]# cat /etc/graylog/server/node-id
8ffa439a-b57d-****************-c61578ee3443
[root@node03 ~]# cat /etc/elasticsearch/elasticsearch.yml | grep -v "^#"
node.name: node-03
network.host: ["127.0.0.1","10.0.0.3"]
[root@node03 ~]# cat /etc/elasticsearch/jvm.options | grep -v "^#"
-Xms2g
-Xmx2g
-XX:+AlwaysPreTouch
-server
-Xss1m
-Djna.nosys=true
[root@node03 ~]# cat /etc/elasticsearch/log4j2.properties | grep -v "^#"
status = error
jochen
(Jochen)
December 14, 2017, 10:14am
6
Try adding action.auto_create_index: false to your Elasticsearch configuration files and removing all indices in Elasticsearch.
alias
(alias)
December 14, 2017, 10:39am
7
I add this line in all nodes ES configuration file, use XDELETE on graylog_* and restart ES + graylog-server.
I’ve this:
Node 01 : tail -f server.log
2017-12-14T12:29:53.636+01:00 INFO [MongoIndexSet] Did not find a deflector alias. Setting one up now.
2017-12-14T12:29:53.641+01:00 INFO [MongoIndexSet] Pointing to already existing index target <graylog_2>
2017-12-14T12:30:03.615+01:00 WARN [IndexRotationThread] Deflector is pointing to [null], not the newest one: [graylog_2]. Re-pointing.
2017-12-14T12:30:03.635+01:00 ERROR [IndexRotationThread] Couldn't point deflector to a new index
org.graylog2.indexer.ElasticsearchException: Couldn't switch alias graylog_deflector from index null to index graylog_2
[alias_action] failed to parse field [remove]
at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:94) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:58) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:63) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.cycleAlias(Indices.java:608) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.pointTo(MongoIndexSet.java:357) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.checkAndRepair(IndexRotationThread.java:166) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:76) ~[graylog.jar:?]
at java.lang.Iterable.forEach(Iterable.java:75) [?:1.8.0_151]
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:73) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_151]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_151]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_151]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_151]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
2017-12-14T12:33:44.766+01:00 ERROR [MessageCountRotationStrategy] Unknown index, cannot perform rotation
org.graylog2.indexer.IndexNotFoundException: Couldn't check stats of index graylog_3
Index not found for query: graylog_3. Try recalculating your index ranges.
at org.graylog2.indexer.cluster.jest.JestUtils.buildIndexNotFoundException(JestUtils.java:124) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:80) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.indexStats(Indices.java:255) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.numberOfMessages(Indices.java:215) ~[graylog.jar:?]
at org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy.shouldRotate(MessageCountRotationStrategy.java:66) ~[graylog.jar:?]
at org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy.shouldRotate(MessageCountRotationStrategy.java:34) ~[graylog.jar:?]
at org.graylog2.indexer.rotation.strategies.AbstractRotationStrategy.rotate(AbstractRotationStrategy.java:67) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.checkForRotation(IndexRotationThread.java:113) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:77) ~[graylog.jar:?]
2017-12-14T12:33:44.766+01:00 ERROR [AbstractRotationStrategy] Cannot perform rotation of index <graylog_3> in index set <Default index set> with strategy <org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy> at this moment
Also, I not have any log for ES and the path.logs is configured on each node (elasticsearch.yml).
In WebUI system overview, I’ve the same error:
Deflector exists as an index and is not an alias.
And shards unassigned
System messages : Deflector is pointing to [null], not the newest one: [graylog_2]. Re-pointing.
jochen
(Jochen)
December 14, 2017, 10:50am
8
Delete all indices and index aliases in Elasticsearch, then start Graylog.
alias
(alias)
December 14, 2017, 2:23pm
9
Node 01 :
# systemctl stop elasticsearch.service && systemctl stop graylog-server
# systemctl start elasticsearch.service
# curl -XGET http://127.0.0.1:9200/_aliases
{"graylog_3":{"aliases":{}}}
# curl -XGET http://127.0.0.1:9200/_cat/indices/
yellow open graylog_3 AaLmm0ORQdaOfS9mRMwLMQ 4 1 0 0 764b 764b
# curl -XDELETE http://localhost:9200/graylog_*/
{"acknowledged":true}
# systemctl start graylog-server && tail -f /var/log/graylog-server/server.log
WebUI System overview :
Elasticsearch cluster is yellow. Shards: 8 active, 0 initializing, 0 relocating, 8 unassigned, What does this mean?
System messages :
There is no index target to point to. Creating one now.
And after : Deflector is pointing to [null], not the newest one: [graylog_0]. Re-pointing.
WebUI search page (random issue):
Could not execute search
There was an error executing your search. Please check your Graylog server logs for more information.
Error Message:
Unable to perform search query. Index not found for query: graylog_0. Try recalculating your index ranges.
Details:
Search status code:
500
Search response:
cannot GET http://10.0.0.1:9000/api/search/universal/relative?query=%2A&range=300&limit=150&sort=timestamp%3Adesc (500)
I try "System/Indices/Default index set/Maintenance/Recalculate index range.
After this, I check system messages for verify if the job is start status :
SystemJob <c72da410-e0e1-11e7-9c71-5254006210e0> [org.graylog2.indexer.ranges.RebuildIndexRangesJob] finished in 60ms.
Done calculating index ranges for 1 indices. Took 21ms.
Try search again :
A search on two, I’ve the same error.
Node 02 :
{"graylog_2":{"aliases":{"graylog_deflector":{}}},"graylog_1":{"aliases":{}},"graylog_0":{"aliases":{}}}
# curl -XDELETE http://127.0.0.1:9200/graylog_2/_alias/_all
yellow open graylog_2 KGhy4-10TaqCCHXRriKjXQ 4 2 0 0 764b 764b
yellow open graylog_1 vu3-qoxMQWK8ZHyLuJobfw 4 2 0 0 764b 764b
yellow open graylog_0 6N2nbSuMQSSJEumi0S_xew 4 2 0 0 764b 764b
Node 03 :
{"graylog_0":{"aliases":{}},"graylog_2":{"aliases":{"graylog_deflector":{}}}}
yellow open graylog_0 Y1KM_ercT3aCplDICAFEOA 4 2 0 0 764b 764b
yellow open graylog_2 VQW1ZgFVRaWK97K1GPG0Eg 4 2 9 0 24.5kb 24.5kb
@jochen , do you have an idea for the error in search page ?
jochen
(Jochen)
December 14, 2017, 3:06pm
10
Your Elasticsearch nodes don’t seem to form a cluster but each runs for itself, ignoring all other nodes.
Check the logs of your Elasticsearch nodes and make sure your configuration is correct.
alias
(alias)
December 14, 2017, 3:23pm
11
@jochen
I have only graylog.log in /var/log/elasticsearch:
jochen
(Jochen)
December 14, 2017, 3:39pm
12
And what’s wrong with that?
alias
(alias)
December 18, 2017, 2:26pm
13
That I’ve configured a /var/log/elasticsearch.log in elasticsearch.yml, it’s strange to not have any log.
But I checked all ES configuration files on 3 nodes, and I not see errors.
In WebUI, I’ve 87 failed indexing attempts in the last 24 hours.
In the System messages, I’ve the same error “Deflector is pointing to [null], not the newest one: [graylog_0|1]. Re-pointing.”
When I try “curl -XGET localhost:9200/_cluster/state?pretty”; I’ve:
"routing_table" : {
"indices" : {
"graylog_0": {
"shards" : {
"1" : [
"state" : "UNASSIGNED"
"primary" : true,
"node" : null,
"relocating_node" : null,
"shard" : 1,
"index" : "graylog_0",
"recovery_source" : {
"type" : "EXISTING_STORE"
unassigned_info" : {
"reason" : "CLUSTER_RECOVERED",
"at" : time
"delayed" : false,
"allocation_status" : "no_valid_shard_copy"
Do you have an idea @jochen ?
jan
(Jan Doberstein)
December 18, 2017, 4:00pm
14
you should read the message that elasticsearch is giving you - together with google that should work.
Maybe you disabled cluster allocation and just need to re-enable that?
