I have standalone instance of Graylog 3.0, ES and mongo running on same server. Everything was running fine but we were facing storage issue quiet frequently so we increased the storage of VM. But after that I am not able to get the list of Indices at system/indices webpage. I am getting 500 status_code in “/api/system/indices/index_sets?skip=0&limit=10&stats=true” and “api/system/indices/index_sets/stats” in webpage.
There are is no error in graylog/server/log or in elasticsearch. I tried deleting the indices in elasticsearch and restarting graylog. It does create new index in elasticsearch but nothing in graylog.
$ curl http://127.0.0.1:9200/_cat/indices
green open default_0 XT3Uvv1TRKKKceZ2VuqRiw 4 0 0 0 1kb 1kb
green open nginx__0 T1xbMBKjQSK8zfJlrBa_7g 4 0 0 0 1kb 1kb
green open graylog_0 pUDy3Xl_SbClrleYxhRa8A 1 0 0 0 261b 261b
$ curl http://127.0.0.1:9200/_cat/shards
default_0 1 p STARTED 0 261b 127.0.0.1 BAxxy2s
default_0 3 p STARTED 0 261b 127.0.0.1 BAxxy2s
default_0 2 p STARTED 0 261b 127.0.0.1 BAxxy2s
default_0 0 p STARTED 0 261b 127.0.0.1 BAxxy2s
graylog_0 0 p STARTED 0 261b 127.0.0.1 BAxxy2s
nginx__0 1 p STARTED 0 261b 127.0.0.1 BAxxy2s
nginx__0 3 p STARTED 0 261b 127.0.0.1 BAxxy2s
nginx__0 2 p STARTED 0 261b 127.0.0.1 BAxxy2s
nginx__0 0 p STARTED 0 261b 127.0.0.1 BAxxy2s
Graylog server.conf file
$ sudo cat /etc/graylog/server/server.conf
is_master = true
password_secret = qZx4gYX1Ofc05MMPw7DGJjoS5ShRkanZXCeaglTotqJiO8jf0mPzodsYm103cvavf7hjB1nyL7WJfHK4ycrHo1i3DhyGeh0s
root_password_sha2 = c70f30de786b86042a8081dfebce10274ea847b85aabcd29c595523551712e21
http_external_uri = http://127.0.0.1:9000/
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
mongodb_uri = mongodb://graylog:PASSWORD@localhost:27017/graylog
elasticsearch_http_enabled = false
elasticsearch_discovery_zen_ping_unicast_hosts = 127.0.0.1:9200
/etc/elasticsearch/elasticsearch.yml
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
cluster.name: graylog
bootstrap.system_call_filter: false
