Building Graylog 3 from source
Dear All,
Have the fpm recipes at https://github.com/Graylog2/fpm-recipes been updated to allow building of Graylog 3 Alpha builds?
Is this still the official way to build Graylog?
Kind Regards
Jake
He @Magneton
yes it is - but we provide alpha builds available for download already …
Hi Jan,
I just found this post at Graylog 3.0 Alpha Fail Compiled
If you want to compile yourself, can you also do it using the following https://github.com/Graylog2/graylog-project
Regards
Jake
Jan,
If I want to use the precompiled version, what are the version requirements for elasticsearch and mongodb?
Regards
Jake
You can always switch the version in the documentation. What then reveals:
http://docs.graylog.org/en/3.0/pages/installation.html
ES 5
MongoDB 3.6
As of the current development state.
