Dear All,
I am revisiting looking at building Graylog from source as I now have some time.
Is the 2.4 branch in github, the current 2.4.3 version?
I already managed this by another method.
Cheers
Jake
yes - Github is the single source of truth.
Hi Jochen,
I missed it on Github in the little graphics.
My bad.
Cheers
Jake
Hi Jan,
Here is build log at https://paste.ee/p/fHZea
it looks to be good, but is there anything of concern?
Cheers
Jake
Hi Graylog,
Where do I find the 2.4.3 release on github.
If i look at the 2.4 branch, pom .xml shows “2.4.4-SNAPSHOT”, the 2.3 branch shows “2.3.3-SNAPSHOT”.
I can’t seem to find the 2.4.3 release from the 24/01/2018.
Where do I find the release so that I can build it.
Cheers
Jake
Every release of Graylog corresponds to a tag in the GitHub repository.
Hi Jochen,
I was looking for branches not tags. Thanks.
Do you guys use an IDE to build graylog? If so can you tell me which one Eclipse, NetBeans or IntelliJ ?
Cheers
Jake
Most of us are using IntelliJ IDEA, but Netbeans and Eclipse should work as well.
Hi Jochen,
I am assuming most of you guys are using IntelliJ on Linux? Anyone using windows?
Cheers
Jake
No, and we neither support building, nor running Graylog on Windows, so you’re on your own with that.
hi Jochen,
i thought that would be the case. I am using Linux anyway
Cheers
Jake
Hi Jochen,
Is there a recommended Java version for building Graylog, I am using 1.8.0_161?
It compiles fine.
Cheers
Jake
Any recent JDK 8 will work.
Java 9 or 10 doesn’t work yet, though.
Hi Jochen,
Cheers
Jake
