Request help for the contribution documentation
Hi All
Currently, I am pretty interesting in GrayLog2 project in GitHub and want to do some contributions. To be honest, it looks that some of the open bugs are waiting too long.
But when I checked out the project code (https://github.com/Graylog2/graylog2-server), I was stopped by few compiling issues.
If possible, could you please give me few help or documents which focused on how to compile or debug grayLog2 project.
By the way, I am running with Eclipse IDE.
It will much more efficient for my current items.
Stephen
You only need Java 8 (JDK) and Maven 3.1 or higher to build Graylog.
It’s pretty much only 2 steps:
If that doesn’t work for you, you need to elaborate on the issues you’re having.
Thanks, Jochen.
Below is my error messages:
My ubuntu 14.04 information:
root@graylog:/tmp/graylog2-server/graylog2-server# mvn -version
Apache Maven 3.3.9 (bb52d8502b132ec0a5a3f4c09453c07478323dc5; 2015-11-10T16:41:47+00:00)
Maven home: /usr/share/maven3
Java version: 1.8.0_101, vendor: Oracle Corporation
Java home: /opt/graylog/embedded/jre/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux", version: "4.4.0-71-generic", arch: "amd64", family: "unix"
root@graylog:/tmp/graylog2-server/graylog2-server# java -version
java version "1.8.0_131"
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
root@graylog:/tmp/graylog2-server/graylog2-server# node -v
v7.9.0
root@graylog:/tmp/graylog2-server/graylog2-server# npm -v
4.2.0
Error messages:
[DEBUG] -- end configuration --
[INFO] Running 'npm run build' in /tmp/graylog2-server/graylog2-server/graylog2-web-interface
[DEBUG] Executing command line [/tmp/graylog2-server/graylog2-server/graylog2-web-interface/node/node, /tmp/graylog2-server/graylog2-server/graylog2-web-interface/node/node_modules/npm/bin/npm-cli.js, run, build]
[INFO]
[INFO] > graylog-web-interface@2.3.0-SNAPSHOT build /tmp/graylog2-server/graylog2-server/graylog2-web-interface
[INFO] > disable_plugins=true webpack --config webpack.bundled.js
[INFO]
[ERROR] Running in production mode
[ERROR] Building vendor bundle.
[ERROR] clean-webpack-plugin: /tmp/graylog2-server/graylog2-server/graylog2-web-interface/build has been removed.
[ERROR] (node:13004) DeprecationWarning: loaderUtils.parseQuery() received a non-string value which can be problematic, see https://github.com/webpack/loader-utils/issues/56
[ERROR] parseQuery() will be replaced with getOptions() in the next major version of loader-utils.
[ERROR] ts-loader: Using typescript@1.8.10 and /tmp/graylog2-server/graylog2-server/graylog2-web-interface/tsconfig.json
[INFO] Hash: 69ab11c1b0b180ffc1a2856a398bec94313be4ef
[INFO] Version: webpack 2.4.1
[INFO] Child vendor:
[INFO]     Time: 16777ms
[INFO]                              Asset    Size  Chunks                    Chunk Names
[INFO]     vendor.8fad0e996714dcc32175.js  938 kB       0  [emitted]  [big]  vendor
[INFO]        [0] dll vendor 12 bytes {0} [built]
[INFO]        [1] ./~/react/react.js 56 bytes {0} [built]
[INFO]        [3] ./~/moment/moment.js 139 kB {0} [built]
[INFO]       [19] ./~/react-dom/index.js 63 bytes {0} [built]
[INFO]      [283] ./~/react-router/lib/index.js 2.38 kB {0} [built]
[INFO]      [336] ./~/react-addons-linked-state-mixin/index.js 55 bytes {0} [built]
[INFO]      [337] ./~/react-addons-pure-render-mixin/index.js 72 bytes {0} [built]
[INFO]      [484] ./~/react-router-bootstrap/lib/index.js 544 bytes {0} [built]
[INFO]      [487] ./~/react-router/lib/IndexRedirect.js 2.59 kB {0} [built]
[INFO]      [582] ./~/reflux/src/index.js 299 bytes {0} [built]
[INFO]      [769] ./~/moment-timezone/index.js 114 bytes {0} [built]
[INFO]      [793] ./~/reflux-core/lib/index.js 2.98 kB {0} [built]
[INFO]      [798] ./~/jquery/dist/jquery.js 248 kB {0} [built]
[INFO]      [819] ./~/react-bootstrap/es/index.js 4.85 kB {0} [built]
[INFO]      [912] ./~/react-bootstrap/es/Radio.js 3.25 kB {0} [built]
[INFO]         + 592 hidden modules
[INFO] Child app:
[INFO]     Hash: 856a398bec94313be4ef
[INFO]     Time: 85560ms
[INFO]                 42.856a398bec94313be4ef.js    7.12 kB      42  [emitted]
[INFO]       f9a25466e5ac752f14dfa013fad9730a.jpg     272 kB          [emitted]  [big]
[INFO]       912ec66d7572ff821749319396470bde.svg     444 kB          [emitted]  [big]
[INFO]       b06871f281fee6b241d60582ae9369b9.ttf     166 kB          [emitted]
[INFO]     af7ae505a9eed503f8b8e6982036873e.woff2    77.2 kB          [emitted]
[INFO]      fee66e712a8a08eef5805a46892932ad.woff      98 kB          [emitted]
[INFO]       d2a705b59e370eaa5d145962f3b1ade1.ttf    52.5 kB          [emitted]
[INFO]      811c8baeca3bb3329488f729979c1fbc.woff    31.8 kB          [emitted]
[INFO]     48aa7ad98beedc63d82925f45fd8e72c.woff2    24.9 kB          [emitted]
[INFO]       b87efff09ad1fd0e8da7f17ce94c4a83.ttf      54 kB          [emitted]
[INFO]      6f05808b4f6a11d3feb1716291c7c038.woff    31.5 kB          [emitted]
[INFO]     313824e85557a721d326424b6eb63fec.woff2    24.4 kB          [emitted]
[INFO]       47cf698e57af0651962238787bea4d2f.ttf    58.6 kB          [emitted]
[INFO]      90b8cd144632dbd7c51c77336b7f5171.woff    34.4 kB          [emitted]
[INFO]     5f80e2b1fe2352fbe3f757c44ab1d590.woff2    26.8 kB          [emitted]
[INFO]       a4e0d32f8d8cb67da4af27c3f948600d.ttf    55.8 kB          [emitted]
[INFO]      6794db0115fe57ff032c2bc4d2fec757.woff    32.3 kB          [emitted]
[INFO]     0f5ecd4c02213b058c52b19a729b2308.woff2    25.1 kB          [emitted]
[INFO]       41274fc221d9fe727256b3f302904a4e.ttf    59.8 kB          [emitted]
[INFO]      cb00b819da6093c52289da36f470549a.woff    34.8 kB          [emitted]
[INFO]     51d4b21e8b8a03b7b5b6fb3681edbabf.woff2    26.9 kB          [emitted]
[INFO]       bf2f6b57cd6438b1e1ca22dd53c319c0.ttf    57.6 kB          [emitted]
[INFO]      576f55c34a35e2d1e8d46dc916dd53de.woff      35 kB          [emitted]
[INFO]     fbf7f082bb8abfeef11c89c77452f796.woff2    27.4 kB          [emitted]
[INFO]       25ad8d1b471db8cc26d864db84a86bd5.ttf    51.6 kB          [emitted]
[INFO]      9a0cfeda5ce5de1674106cd0a66ed55e.woff    30.7 kB          [emitted]
[INFO]     aac07fc6db99e7eb977e36c5b2571716.woff2    23.9 kB          [emitted]
[INFO]       161f7fcb431023d65bbd20417b321328.ttf    56.4 kB          [emitted]
[INFO]      03fa0fb46f93a7cd5fbac457f20228e2.woff    33.7 kB          [emitted]
[INFO]     3b472a011c149d4e3e20899165f9d836.woff2    26.3 kB          [emitted]
[INFO]       483351b66d7f49ef56b83ecb00dd3712.ttf    53.3 kB          [emitted]
[INFO]      299b3be898e809232985246037e615b9.woff    32.1 kB          [emitted]
[INFO]     86dd4197bc664e69cc2dcba53bd2e6bc.woff2      25 kB          [emitted]
[INFO]       9e4f913fb70d77b2898dd935c62b626a.ttf    58.7 kB          [emitted]
[INFO]      09c3b5a4acf6c0c8acdb419be166b4c8.woff    35.4 kB          [emitted]
[INFO]     1e7892227286bddc889ed66c71863ce9.woff2    27.8 kB          [emitted]
[INFO]       31a71554a7917f4d60fb34b775a158da.jpg     261 kB          [emitted]  [big]
[INFO]                  0.856a398bec94313be4ef.js  287 bytes       0  [emitted]         LoginPage
[INFO]                  1.856a398bec94313be4ef.js  286 bytes       1  [emitted]         LoggedInPage
[INFO]                  2.856a398bec94313be4ef.js  287 bytes       2  [emitted]         LoadingPage
[INFO]                  3.856a398bec94313be4ef.js     473 kB       3  [emitted]  [big]
[INFO]                  4.856a398bec94313be4ef.js    61.2 kB       4  [emitted]
[INFO]                  5.856a398bec94313be4ef.js    50.8 kB       5  [emitted]
[INFO]                  6.856a398bec94313be4ef.js    52.3 kB       6  [emitted]
[INFO]                  7.856a398bec94313be4ef.js      52 kB       7  [emitted]
[INFO]                  8.856a398bec94313be4ef.js    49.3 kB       8  [emitted]
[INFO]                  9.856a398bec94313be4ef.js    49.5 kB       9  [emitted]
[INFO]                 10.856a398bec94313be4ef.js    49.4 kB      10  [emitted]
[INFO]                 11.856a398bec94313be4ef.js    66.9 kB      11  [emitted]
[INFO]                 12.856a398bec94313be4ef.js    66.7 kB      12  [emitted]
[INFO]                 13.856a398bec94313be4ef.js    36.7 kB      13  [emitted]
[INFO]                 14.856a398bec94313be4ef.js    37.7 kB      14  [emitted]
[INFO]                 15.856a398bec94313be4ef.js    36.6 kB      15  [emitted]
[INFO]                 16.856a398bec94313be4ef.js    34.2 kB      16  [emitted]
[INFO]                 17.856a398bec94313be4ef.js    40.3 kB      17  [emitted]
[INFO]                 18.856a398bec94313be4ef.js    36.6 kB      18  [emitted]
[INFO]                 19.856a398bec94313be4ef.js    35.1 kB      19  [emitted]
[INFO]                 20.856a398bec94313be4ef.js      30 kB      20  [emitted]
[INFO]                 21.856a398bec94313be4ef.js      44 kB      21  [emitted]
[INFO]                 22.856a398bec94313be4ef.js      24 kB      22  [emitted]
[INFO]                 23.856a398bec94313be4ef.js    31.1 kB      23  [emitted]
[INFO]                 24.856a398bec94313be4ef.js    30.3 kB      24  [emitted]
[INFO]                 25.856a398bec94313be4ef.js    21.5 kB      25  [emitted]
[INFO]                 26.856a398bec94313be4ef.js    32.2 kB      26  [emitted]
[INFO]                 27.856a398bec94313be4ef.js    30.3 kB      27  [emitted]
[INFO]                 28.856a398bec94313be4ef.js    23.9 kB      28  [emitted]
[INFO]                 29.856a398bec94313be4ef.js      30 kB      29  [emitted]
[INFO]                 30.856a398bec94313be4ef.js    30.3 kB      30  [emitted]
[INFO]                 31.856a398bec94313be4ef.js    13.2 kB      31  [emitted]
[INFO]                 32.856a398bec94313be4ef.js    14.3 kB      32  [emitted]
[INFO]                 33.856a398bec94313be4ef.js    9.19 kB      33  [emitted]
[INFO]                 34.856a398bec94313be4ef.js    18.2 kB      34  [emitted]
[INFO]                 35.856a398bec94313be4ef.js    13.4 kB      35  [emitted]
[INFO]                 36.856a398bec94313be4ef.js    13.5 kB      36  [emitted]
[INFO]                 37.856a398bec94313be4ef.js    11.2 kB      37  [emitted]
[INFO]                 38.856a398bec94313be4ef.js    19.1 kB      38  [emitted]
[INFO]                 39.856a398bec94313be4ef.js    11.7 kB      39  [emitted]
[INFO]                 40.856a398bec94313be4ef.js    3.79 kB      40  [emitted]
[INFO]                 41.856a398bec94313be4ef.js    6.99 kB      41  [emitted]
[INFO]       674f50d287a8c48dc19ba404d20fe713.eot     166 kB          [emitted]
[INFO]                 43.856a398bec94313be4ef.js    6.58 kB      43  [emitted]
[INFO]                 44.856a398bec94313be4ef.js    2.17 kB  44, 55  [emitted]
[INFO]                 45.856a398bec94313be4ef.js    6.81 kB      45  [emitted]
[INFO]                 46.856a398bec94313be4ef.js    10.6 kB      46  [emitted]
[INFO]                 47.856a398bec94313be4ef.js    2.78 kB      47  [emitted]
[INFO]                 48.856a398bec94313be4ef.js    3.07 kB      48  [emitted]
[INFO]                 49.856a398bec94313be4ef.js     1.7 kB      49  [emitted]
[INFO]                 50.856a398bec94313be4ef.js    1.22 kB      50  [emitted]
[INFO]                 51.856a398bec94313be4ef.js    1.73 kB      51  [emitted]
[INFO]                 52.856a398bec94313be4ef.js    1.85 kB      52  [emitted]
[INFO]                 53.856a398bec94313be4ef.js    4.89 kB      53  [emitted]
[INFO]                 54.856a398bec94313be4ef.js  966 bytes      54  [emitted]
[INFO]                 55.856a398bec94313be4ef.js    1.14 kB      55  [emitted]
[INFO]                 56.856a398bec94313be4ef.js  630 bytes      56  [emitted]
[INFO]                app.856a398bec94313be4ef.js    1.56 MB      57  [emitted]  [big]  app
[INFO]           polyfill.856a398bec94313be4ef.js    88.9 kB      58  [emitted]         polyfill
[INFO]              0.856a398bec94313be4ef.js.map    2.43 kB       0  [emitted]         LoginPage
[INFO]              1.856a398bec94313be4ef.js.map    2.43 kB       1  [emitted]         LoggedInPage
[INFO]              2.856a398bec94313be4ef.js.map    2.43 kB       2  [emitted]         LoadingPage
[INFO]              3.856a398bec94313be4ef.js.map    2.35 MB       3  [emitted]
[INFO]              4.856a398bec94313be4ef.js.map     264 kB       4  [emitted]
[INFO]              5.856a398bec94313be4ef.js.map     220 kB       5  [emitted]
[INFO]              6.856a398bec94313be4ef.js.map     227 kB       6  [emitted]
[INFO]              7.856a398bec94313be4ef.js.map     226 kB       7  [emitted]
[INFO]              8.856a398bec94313be4ef.js.map     217 kB       8  [emitted]
[INFO]              9.856a398bec94313be4ef.js.map     218 kB       9  [emitted]
[INFO]             10.856a398bec94313be4ef.js.map     217 kB      10  [emitted]
[INFO]             11.856a398bec94313be4ef.js.map     278 kB      11  [emitted]
[INFO]             12.856a398bec94313be4ef.js.map     277 kB      12  [emitted]
[INFO]             13.856a398bec94313be4ef.js.map     161 kB      13  [emitted]
[INFO]             14.856a398bec94313be4ef.js.map     165 kB      14  [emitted]
[INFO]             15.856a398bec94313be4ef.js.map     160 kB      15  [emitted]
[INFO]             16.856a398bec94313be4ef.js.map     136 kB      16  [emitted]
[INFO]             17.856a398bec94313be4ef.js.map     200 kB      17  [emitted]
[INFO]             18.856a398bec94313be4ef.js.map     158 kB      18  [emitted]
[INFO]             19.856a398bec94313be4ef.js.map     150 kB      19  [emitted]
[INFO]             20.856a398bec94313be4ef.js.map     132 kB      20  [emitted]
[INFO]             21.856a398bec94313be4ef.js.map     183 kB      21  [emitted]
[INFO]             22.856a398bec94313be4ef.js.map     109 kB      22  [emitted]
[INFO]             23.856a398bec94313be4ef.js.map     134 kB      23  [emitted]
[INFO]             24.856a398bec94313be4ef.js.map     131 kB      24  [emitted]
[INFO]             25.856a398bec94313be4ef.js.map    96.3 kB      25  [emitted]
[INFO]             26.856a398bec94313be4ef.js.map     137 kB      26  [emitted]
[INFO]             27.856a398bec94313be4ef.js.map     161 kB      27  [emitted]
[INFO]             28.856a398bec94313be4ef.js.map     106 kB      28  [emitted]
[INFO]             29.856a398bec94313be4ef.js.map     132 kB      29  [emitted]
[INFO]             30.856a398bec94313be4ef.js.map     205 kB      30  [emitted]
[INFO]             31.856a398bec94313be4ef.js.map    57.2 kB      31  [emitted]
[INFO]             32.856a398bec94313be4ef.js.map    61.6 kB      32  [emitted]
[INFO]             33.856a398bec94313be4ef.js.map    39.3 kB      33  [emitted]
[INFO]             34.856a398bec94313be4ef.js.map    80.6 kB      34  [emitted]
[INFO]             35.856a398bec94313be4ef.js.map    58.4 kB      35  [emitted]
[INFO]             36.856a398bec94313be4ef.js.map    58.6 kB      36  [emitted]
[INFO]             37.856a398bec94313be4ef.js.map    45.4 kB      37  [emitted]
[INFO]             38.856a398bec94313be4ef.js.map    85.8 kB      38  [emitted]
[INFO]             39.856a398bec94313be4ef.js.map    52.9 kB      39  [emitted]
[INFO]             40.856a398bec94313be4ef.js.map    18.7 kB      40  [emitted]
[INFO]             41.856a398bec94313be4ef.js.map    32.4 kB      41  [emitted]
[INFO]             42.856a398bec94313be4ef.js.map    32.3 kB      42  [emitted]
[INFO]             43.856a398bec94313be4ef.js.map    34.7 kB      43  [emitted]
[INFO]             44.856a398bec94313be4ef.js.map    9.89 kB  44, 55  [emitted]
[INFO]             45.856a398bec94313be4ef.js.map      31 kB      45  [emitted]
[INFO]             46.856a398bec94313be4ef.js.map    46.3 kB      46  [emitted]
[INFO]             47.856a398bec94313be4ef.js.map      13 kB      47  [emitted]
[INFO]             48.856a398bec94313be4ef.js.map    15.3 kB      48  [emitted]
[INFO]             49.856a398bec94313be4ef.js.map     7.9 kB      49  [emitted]
[INFO]             50.856a398bec94313be4ef.js.map    5.59 kB      50  [emitted]
[INFO]             51.856a398bec94313be4ef.js.map    8.82 kB      51  [emitted]
[INFO]             52.856a398bec94313be4ef.js.map    9.26 kB      52  [emitted]
[INFO]             53.856a398bec94313be4ef.js.map    25.1 kB      53  [emitted]
[INFO]             54.856a398bec94313be4ef.js.map    4.28 kB      54  [emitted]
[INFO]             55.856a398bec94313be4ef.js.map    5.29 kB      55  [emitted]
[INFO]             56.856a398bec94313be4ef.js.map    3.35 kB      56  [emitted]
[INFO]            app.856a398bec94313be4ef.js.map    9.33 MB      57  [emitted]         app
[INFO]       polyfill.856a398bec94313be4ef.js.map     699 kB      58  [emitted]         polyfill
[INFO]                                favicon.png    1.62 kB          [emitted]
[INFO]                                 index.html  429 bytes          [emitted]
[INFO]                                module.json  259 bytes          [emitted]
[INFO]        [1] delegated ./node_modules/reflux/src/index.js from dll-reference __vendor 42 bytes {57} [not cacheable] [built]
[INFO]        [2] delegated ./node_modules/react/react.js from dll-reference __vendor 42 bytes {57} [not cacheable] [built]
[INFO]       [34] delegated ./node_modules/react-dom/index.js from dll-reference __vendor 42 bytes {57} [not cacheable] [built]
[INFO]       [76] ./~/bluebird/js/browser/bluebird.js 179 kB {57} [built]
[INFO]      [254] ./src/routing/AppFacade.jsx 2.59 kB {57} [built]
[INFO]      [255] ./src/webpack-entry.js 703 bytes {57} [built]
[INFO]      [256] ./~/babel-polyfill/lib/index.js 833 bytes {58} [built]
[INFO]      [257] ./~/react-hot-loader/index.js 41 bytes {57} [built]
[INFO]      [354] ./src/index.jsx 1.51 kB {57} [built]
[INFO]      [819] ./~/react-proxy-loader?name=LoginPage!./src/pages/LoginPage.jsx 614 bytes {57} [built]
[INFO]      [833] ./~/toastr/toastr.less 925 bytes {57} [built]
[INFO]      [834] ./public/stylesheets/bootstrap-submenus.less 1.07 kB {57} [built]
[INFO]      [835] ./public/stylesheets/graylog2.less 1.04 kB {57} [built]
[INFO]      [836] ./~/bootstrap/less/bootstrap.less 985 bytes {57} [built]
[INFO]      [871] multi babel-polyfill 28 bytes {58} [built]
[INFO]         + 1489 hidden modules
[INFO]
[INFO]     ERROR in ./~/graylog-web-plugin/plugin.js
[INFO]     Module not found: Error: Can't resolve './lib/PluginManifest' in '/tmp/graylog2-server/graylog2-server/graylog2-web-interface/node_modules/graylog-web-plugin'
[INFO]      @ ./~/graylog-web-plugin/plugin.js 2:18-49
[INFO]      @ ./src/routing/AppRouter.jsx
[INFO]      @ ./~/babel-loader/lib?{"cacheDirectory":"cache","extends":"/tmp/graylog2-server/graylog2-server/graylog2-web-interface/.babelrc"}!./src/pages/LoggedInPage.jsx
[INFO]      @ ./~/react-proxy-loader!./~/babel-loader/lib?{"cacheDirectory":"cache","extends":"/tmp/graylog2-server/graylog2-server/graylog2-web-interface/.babelrc"}!./src/pages/LoggedInPage.jsx
[INFO]      @ ./~/react-proxy-loader?name=LoggedInPage!./src/pages/LoggedInPage.jsx
[INFO]      @ ./src/routing/AppFacade.jsx
[INFO]      @ ./src/index.jsx
[INFO]
[INFO]     Module not found: Error: Can't resolve './lib/PluginStore' in '/tmp/graylog2-server/graylog2-server/graylog2-web-interface/node_modules/graylog-web-plugin'
[INFO]      @ ./~/graylog-web-plugin/plugin.js 3:15-43
[INFO]     Child html-webpack-plugin for "index.html":
[INFO]            [0] ./~/lodash/lodash.js 540 kB {0} [built]
[INFO]            [1] ./~/html-webpack-plugin/lib/loader.js!./templates/index.html.template 1.71 kB {0} [built]
[INFO]            [2] (webpack)/buildin/global.js 509 bytes {0} [built]
[INFO]            [3] (webpack)/buildin/module.js 517 bytes {0} [built]
[INFO]     Child html-webpack-plugin for "module.json":
[INFO]            [1] ./~/html-webpack-plugin/lib/loader.js!./templates/module.json.template 541 bytes {0} [built]
[ERROR]
[ERROR] npm ERR! Linux 4.4.0-71-generic
[ERROR] npm ERR! argv "/tmp/graylog2-server/graylog2-server/graylog2-web-interface/node/node" "/tmp/graylog2-server/graylog2-server/graylog2-web-interface/node/node_modules/npm/bin/npm-cli.js" "run" "build"
[ERROR] npm ERR! node v6.9.2
[ERROR] npm ERR! npm  v4.0.3
[ERROR] npm ERR! code ELIFECYCLE
[ERROR] npm ERR! graylog-web-interface@2.3.0-SNAPSHOT build: `disable_plugins=true webpack --config webpack.bundled.js`
[ERROR] npm ERR! Exit status 2
[ERROR] npm ERR!
[ERROR] npm ERR! Failed at the graylog-web-interface@2.3.0-SNAPSHOT build script 'disable_plugins=true webpack --config webpack.bundled.js'.
[ERROR] npm ERR! Make sure you have the latest version of node.js and npm installed.
[ERROR] npm ERR! If you do, this is most likely a problem with the graylog-web-interface package,
[ERROR] npm ERR! not with npm itself.
[ERROR] npm ERR! Tell the author that this fails on your system:
[ERROR] npm ERR!     disable_plugins=true webpack --config webpack.bundled.js
[ERROR] npm ERR! You can get information on how to open an issue for this project with:
[ERROR] npm ERR!     npm bugs graylog-web-interface
[ERROR] npm ERR! Or if that isn't available, you can get their info via:
[ERROR] npm ERR!     npm owner ls graylog-web-interface
[ERROR] npm ERR! There is likely additional logging output above.
[ERROR]
[ERROR] npm ERR! Please include the following file with any support request:
[ERROR] npm ERR!     /tmp/graylog2-server/graylog2-server/graylog2-web-interface/npm-debug.log
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] Graylog Parent POM ................................. SUCCESS [  0.995 s]
[INFO] Graylog Project Parent POM ......................... SUCCESS [  1.045 s]
[INFO] AutoValue JavaBean extension ....................... SUCCESS [  1.795 s]
[INFO] Graylog ............................................ FAILURE [02:00 min]
[INFO] integration-tests .................................. SKIPPED
[INFO] Graylog Plugin Parent POM .......................... SKIPPED
[INFO] Graylog Plugin with Web support Parent POM ......... SKIPPED
[INFO] graylog-plugin-archetype ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 02:04 min
[INFO] Finished at: 2017-05-01T20:52:49+00:00
[INFO] Final Memory: 39M/360M
[ERROR] Failed to execute goal com.github.eirslett:frontend-maven-plugin:1.4:npm (npm run build) on project graylog2-server: Failed to run task: 'npm run build' failed. org.apache.commons.exec.ExecuteException: Process exited with an error: 1 (Exit value: 1) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.github.eirslett:frontend-maven-plugin:1.4:npm (npm run build) on project graylog2-server: Failed to run task
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
    at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
    at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
    at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
    at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
    at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
    at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
    at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
    at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
    at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
    at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoFailureException: Failed to run task
    at com.github.eirslett.maven.plugins.frontend.mojo.AbstractFrontendMojo.execute(AbstractFrontendMojo.java:121)
    at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
    ... 20 more
Caused by: com.github.eirslett.maven.plugins.frontend.lib.TaskRunnerException: 'npm run build' failed.
    at com.github.eirslett.maven.plugins.frontend.lib.NodeTaskExecutor.execute(NodeTaskExecutor.java:63)
    at com.github.eirslett.maven.plugins.frontend.mojo.NpmMojo.execute(NpmMojo.java:62)
    at com.github.eirslett.maven.plugins.frontend.mojo.AbstractFrontendMojo.execute(AbstractFrontendMojo.java:115)
    ... 22 more
Caused by: com.github.eirslett.maven.plugins.frontend.lib.ProcessExecutionException: org.apache.commons.exec.ExecuteException: Process exited with an error: 1 (Exit value: 1)
    at com.github.eirslett.maven.plugins.frontend.lib.ProcessExecutor.execute(ProcessExecutor.java:82)
    at com.github.eirslett.maven.plugins.frontend.lib.ProcessExecutor.executeAndRedirectOutput(ProcessExecutor.java:64)
    at com.github.eirslett.maven.plugins.frontend.lib.NodeExecutor.executeAndRedirectOutput(NodeExecutor.java:29)
    at com.github.eirslett.maven.plugins.frontend.lib.NodeTaskExecutor.execute(NodeTaskExecutor.java:58)
    ... 24 more
Caused by: org.apache.commons.exec.ExecuteException: Process exited with an error: 1 (Exit value: 1)
    at org.apache.commons.exec.DefaultExecutor.executeInternal(DefaultExecutor.java:404)
    at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:166)
    at com.github.eirslett.maven.plugins.frontend.lib.ProcessExecutor.execute(ProcessExecutor.java:74)
    ... 27 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :graylog2-server
Please post the complete output of mvn clean install (no need to run Maven in debug mode).
Below is a fresh checkout. It looks still failed in npm side.
Do we have specific requirement about npm package?
root@graylog:/home/ubuntu/graylog2-server# mvn clean install
[INFO] Scanning for projects...
[INFO] Reactor Build Order:
[INFO]
[INFO] Graylog
[INFO]
[INFO] Building Graylog Parent POM 2.3.0-SNAPSHOT
[INFO]
[INFO] --- maven-install-plugin:2.5.2:install (default-install) @ graylog-parent ---
[INFO] Installing /home/ubuntu/graylog2-server/pom.xml to /root/.m2/repository/org/graylog/graylog-parent/2.3.0-SNAPSHOT/graylog-parent-2.3.0-SNAPSHOT.pom
[INFO]
[INFO] Building Graylog Project Parent POM 2.3.0-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:3.0.0:clean (default-clean) @ graylog-project-parent ---
[INFO]
[INFO] --- forbiddenapis:2.2:check (forbidden-apis-src) @ graylog-project-parent ---
[INFO] Skipping execution for packaging "pom"
[INFO]
[INFO] --- forbiddenapis:2.2:testCheck (forbidden-apis-test) @ graylog-project-parent ---
[INFO]
[INFO] --- license-maven-plugin:2.11:check (default) @ graylog-project-parent ---
[INFO] Checking licenses...
[INFO]
[INFO] --- maven-install-plugin:2.5.2:install (default-install) @ graylog-project-parent ---
[INFO] Installing /home/ubuntu/graylog2-server/graylog-project-parent/pom.xml to /root/.m2/repository/org/graylog/graylog-project-parent/2.3.0-SNAPSHOT/graylog-project-parent-2.3.0-SNAPSHOT.pom
[INFO]
[INFO] Building AutoValue JavaBean extension 2.3.0-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:3.0.0:clean (default-clean) @ auto-value-javabean ---
[INFO] Deleting /home/ubuntu/graylog2-server/auto-value-javabean/target
[INFO]
[INFO] --- maven-resources-plugin:3.0.2:resources (default-resources) @ auto-value-javabean ---
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.6.1:compile (default-compile) @ auto-value-javabean ---
[INFO] Compiling 2 source files to /home/ubuntu/graylog2-server/auto-value-javabean/target/classes
warning: An exception occurred while looking for AutoValue extensions. No extensions will function. This may be due to a corrupt jar file in the compiler's classpath. Exception: java.util.ServiceConfigurationError: com.google.auto.value.extension.AutoValueExtension: Provider org.graylog.autovalue.WithBeanGetterExtension not found
1 warning
[INFO]
[INFO] --- forbiddenapis:2.2:check (forbidden-apis-src) @ auto-value-javabean ---
[INFO] Skipping forbidden-apis checks.
[INFO]
[INFO] --- maven-resources-plugin:3.0.2:testResources (default-testResources) @ auto-value-javabean ---
[INFO] skip non existing resourceDirectory /home/ubuntu/graylog2-server/auto-value-javabean/src/test/resources
[INFO]
[INFO] --- maven-compiler-plugin:3.6.1:testCompile (default-testCompile) @ auto-value-javabean ---
[INFO] No sources to compile
[INFO]
[INFO] --- forbiddenapis:2.2:testCheck (forbidden-apis-test) @ auto-value-javabean ---
[INFO]
[INFO] --- maven-surefire-plugin:2.19.1:test (default-test) @ auto-value-javabean ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:3.0.2:jar (default-jar) @ auto-value-javabean ---
[INFO] Building jar: /home/ubuntu/graylog2-server/auto-value-javabean/target/auto-value-javabean-2.3.0-SNAPSHOT.jar
[INFO]
[INFO] --- license-maven-plugin:2.11:check (default) @ auto-value-javabean ---
[INFO]
[INFO] --- maven-install-plugin:2.5.2:install (default-install) @ auto-value-javabean ---
[INFO] Installing /home/ubuntu/graylog2-server/auto-value-javabean/target/auto-value-javabean-2.3.0-SNAPSHOT.jar to /root/.m2/repository/org/graylog/autovalue/auto-value-javabean/2.3.0-SNAPSHOT/auto-value-javabean-2.3.0-SNAPSHOT.jar
[INFO] Installing /home/ubuntu/graylog2-server/auto-value-javabean/pom.xml to /root/.m2/repository/org/graylog/autovalue/auto-value-javabean/2.3.0-SNAPSHOT/auto-value-javabean-2.3.0-SNAPSHOT.pom
[INFO]
[INFO] Building Graylog 2.3.0-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:3.0.0:clean (default-clean) @ graylog2-server ---
[INFO] Deleting /home/ubuntu/graylog2-server/graylog2-web-interface (includes = [build/**/*, node_modules/**/*], excludes = [])
[INFO]
[INFO] --- buildnumber-maven-plugin:1.4:create (default) @ graylog2-server ---
[INFO] Executing: /bin/sh -c cd '/home/ubuntu/graylog2-server/graylog2-server' && 'git' 'rev-parse' '--verify' 'HEAD'
[INFO] Working directory: /home/ubuntu/graylog2-server/graylog2-server
[INFO] Storing buildNumber: 515c5cd69ed8e5103ce6227cf2d6f89de02a909b at timestamp: 1493734012484
[INFO] Storing buildScmBranch: master
[INFO]
[INFO] --- build-helper-maven-plugin:1.12:parse-version (parse-version) @ graylog2-server ---
[INFO]
[INFO] --- frontend-maven-plugin:1.3:install-node-and-npm (install node and npm) @ graylog2-server ---
[INFO] Node v6.9.2 is already installed.
[INFO] NPM 4.0.3 is already installed.
[INFO]
[INFO] --- frontend-maven-plugin:1.3:npm (npm install) @ graylog2-server ---
[INFO] Running 'npm install' in /home/ubuntu/graylog2-server/graylog2-web-interface
[WARNING] npm WARN prepublish-on-install As of npm@5, `prepublish` scripts will run only for `npm publish`.
[WARNING] npm WARN prepublish-on-install (In npm@4 and previous versions, it also runs for `npm install`.)
[WARNING] npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information.
[WARNING] npm WARN lifecycle graylog-web-plugin@2.2.0-SNAPSHOT~prepublish: cannot run in wd %s %s (wd=%s) graylog-web-plugin@2.2.0-SNAPSHOT npm i --only=dev --ignore-scripts && npm run compile /home/ubuntu/graylog2-server/graylog2-web-interface/packages/graylog-web-plugin
[WARNING] npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
[WARNING] npm WARN deprecated to-iso-string@0.0.2: to-iso-string has been deprecated, use @segment/to-iso-string instead.
[WARNING] npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
[INFO]
[INFO] > phantomjs-prebuilt@2.1.14 install /home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/phantomjs-prebuilt
[INFO] > node install.js
[INFO]
[INFO] PhantomJS not found on PATH
[INFO] Downloading https://github.com/Medium/phantomjs/releases/download/v2.1.1/phantomjs-2.1.1-linux-x86_64.tar.bz2
[INFO] Saving to /tmp/phantomjs/phantomjs-2.1.1-linux-x86_64.tar.bz2
[INFO] Receiving...
[INFO]
[INFO] Received 22866K total.
[INFO] Extracting tar contents (via spawned process)
[INFO] Removing /home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/phantomjs-prebuilt/lib/phantom
[INFO] Copying extracted folder /tmp/phantomjs/phantomjs-2.1.1-linux-x86_64.tar.bz2-extract-1493734117208/phantomjs-2.1.1-linux-x86_64 -> /home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/phantomjs-prebuilt/lib/phantom
[INFO] Writing location.js file
[INFO] Done. Phantomjs binary available at /home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs
[INFO]
[INFO] > history@1.17.0 postinstall /home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/history
[INFO] > node ./npm-scripts/postinstall.js
[INFO]
[INFO]
[INFO] > react-router@1.0.3 postinstall /home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/react-router
[INFO]
[INFO] graylog-web-interface@2.3.0-SNAPSHOT /home/ubuntu/graylog2-server/graylog2-web-interface
[INFO] β”œβ”€β”¬ babel-core@6.24.1
[INFO] β”‚ β”œβ”€β”¬ babel-code-frame@6.22.0
[INFO] β”‚ β”‚ └── js-tokens@3.0.1
[INFO] β”‚ β”œβ”€β”¬ babel-generator@6.24.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ detect-indent@4.0.0
[INFO] β”‚ β”‚ β”‚ └─┬ repeating@2.0.1
[INFO] β”‚ β”‚ β”‚   └── is-finite@1.0.2
[INFO] β”‚ β”‚ β”œβ”€β”€ jsesc@1.3.0
[INFO] β”‚ β”‚ └── trim-right@1.0.1
[INFO] β”‚ β”œβ”€β”€ babel-helpers@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-messages@6.23.0
[INFO] β”‚ β”œβ”€β”¬ babel-register@6.24.1
[INFO] β”‚ β”‚ β”œβ”€β”€ home-or-tmp@2.0.0
[INFO] β”‚ β”‚ └── source-map-support@0.4.15
[INFO] β”‚ β”œβ”€β”€ babel-runtime@6.23.0
[INFO] β”‚ β”œβ”€β”€ babel-template@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-traverse@6.24.1
[INFO] β”‚ β”œβ”€β”¬ babel-types@6.24.1
[INFO] β”‚ β”‚ └── to-fast-properties@1.0.3
[INFO] β”‚ β”œβ”€β”€ babylon@6.17.0
[INFO] β”‚ β”œβ”€β”€ convert-source-map@1.5.0
[INFO] β”‚ β”œβ”€β”¬ debug@2.6.6
[INFO] β”‚ β”‚ └── ms@0.7.3
[INFO] β”‚ β”œβ”€β”€ json5@0.5.1
[INFO] β”‚ β”œβ”€β”¬ minimatch@3.0.3
[INFO] β”‚ β”‚ └─┬ brace-expansion@1.1.7
[INFO] β”‚ β”‚   β”œβ”€β”€ balanced-match@0.4.2
[INFO] β”‚ β”‚   └── concat-map@0.0.1
[INFO] β”‚ β”œβ”€β”€ path-is-absolute@1.0.1
[INFO] β”‚ β”œβ”€β”€ private@0.1.7
[INFO] β”‚ β”œβ”€β”€ slash@1.0.0
[INFO] β”‚ └── source-map@0.5.6
[INFO] β”œβ”€β”¬ babel-loader@6.4.1
[INFO] β”‚ β”œβ”€β”¬ find-cache-dir@0.1.1
[INFO] β”‚ β”‚ β”œβ”€β”€ commondir@1.0.1
[INFO] β”‚ β”‚ └─┬ pkg-dir@1.0.0
[INFO] β”‚ β”‚   └─┬ find-up@1.1.2
[INFO] β”‚ β”‚     └── path-exists@2.1.0
[INFO] β”‚ β”œβ”€β”¬ loader-utils@0.2.17
[INFO] β”‚ β”‚ β”œβ”€β”€ big.js@3.1.3
[INFO] β”‚ β”‚ └── emojis-list@2.1.0
[INFO] β”‚ β”œβ”€β”¬ mkdirp@0.5.1
[INFO] β”‚ β”‚ └── minimist@0.0.8
[INFO] β”‚ └── object-assign@4.1.1
[INFO] β”œβ”€β”€ babel-plugin-add-module-exports@0.2.1
before the β€œmvn clean install”, I ran the β€œnpm i” in the directory β€œ/home/ubuntu/graylog2-server/graylog2-web-interface”
[INFO] β”œβ”€β”¬ babel-polyfill@6.23.0
[INFO] β”‚ β”œβ”€β”€ core-js@2.4.1
[INFO] β”‚ └── regenerator-runtime@0.10.5
[INFO] β”œβ”€β”¬ babel-preset-es2015@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-check-es2015-constants@6.22.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-arrow-functions@6.22.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-block-scoped-functions@6.22.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-block-scoping@6.24.1
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-es2015-classes@6.24.1
[INFO] β”‚ β”‚ β”œβ”€β”€ babel-helper-define-map@6.24.1
[INFO] β”‚ β”‚ β”œβ”€β”€ babel-helper-function-name@6.24.1
[INFO] β”‚ β”‚ β”œβ”€β”€ babel-helper-optimise-call-expression@6.24.1
[INFO] β”‚ β”‚ └── babel-helper-replace-supers@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-computed-properties@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-destructuring@6.23.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-duplicate-keys@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-for-of@6.23.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-function-name@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-literals@6.22.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-modules-amd@6.24.1
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-es2015-modules-commonjs@6.24.1
[INFO] β”‚ β”‚ └── babel-plugin-transform-strict-mode@6.24.1
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-es2015-modules-systemjs@6.24.1
[INFO] β”‚ β”‚ └── babel-helper-hoist-variables@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-modules-umd@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-object-super@6.24.1
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-es2015-parameters@6.24.1
[INFO] β”‚ β”‚ β”œβ”€β”€ babel-helper-call-delegate@6.24.1
[INFO] β”‚ β”‚ └── babel-helper-get-function-arity@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-shorthand-properties@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-spread@6.22.0
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-es2015-sticky-regex@6.24.1
[INFO] β”‚ β”‚ └── babel-helper-regex@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-template-literals@6.22.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-es2015-typeof-symbol@6.23.0
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-es2015-unicode-regex@6.24.1
[INFO] β”‚ β”‚ └─┬ regexpu-core@2.0.0
[INFO] β”‚ β”‚   β”œβ”€β”€ regenerate@1.3.2
[INFO] β”‚ β”‚   β”œβ”€β”€ regjsgen@0.2.0
[INFO] β”‚ β”‚   └─┬ regjsparser@0.1.5
[INFO] β”‚ β”‚     └── jsesc@0.5.0
[INFO] β”‚ └─┬ babel-plugin-transform-regenerator@6.24.1
[INFO] β”‚   └── regenerator-transform@0.9.11
[INFO] β”œβ”€β”¬ babel-preset-react@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-syntax-jsx@6.18.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-react-display-name@6.23.0
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-react-jsx@6.24.1
[INFO] β”‚ β”‚ └── babel-helper-builder-react-jsx@6.24.1
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-react-jsx-self@6.22.0
[INFO] β”‚ β”œβ”€β”€ babel-plugin-transform-react-jsx-source@6.22.0
[INFO] β”‚ └─┬ babel-preset-flow@6.23.0
[INFO] β”‚   └─┬ babel-plugin-transform-flow-strip-types@6.22.0
[INFO] β”‚     └── babel-plugin-syntax-flow@6.18.0
[INFO] β”œβ”€β”¬ babel-preset-stage-0@6.24.1
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-do-expressions@6.22.0
[INFO] β”‚ β”‚ └── babel-plugin-syntax-do-expressions@6.13.0
[INFO] β”‚ β”œβ”€β”¬ babel-plugin-transform-function-bind@6.22.0
[INFO] β”‚ β”‚ └── babel-plugin-syntax-function-bind@6.13.0
[INFO] β”‚ └─┬ babel-preset-stage-1@6.24.1
[INFO] β”‚   β”œβ”€β”¬ babel-plugin-transform-class-constructor-call@6.24.1
[INFO] β”‚   β”‚ └── babel-plugin-syntax-class-constructor-call@6.18.0
[INFO] β”‚   β”œβ”€β”¬ babel-plugin-transform-export-extensions@6.22.0
[INFO] β”‚   β”‚ └── babel-plugin-syntax-export-extensions@6.13.0
[INFO] β”‚   └─┬ babel-preset-stage-2@6.24.1
[INFO] β”‚     β”œβ”€β”€ babel-plugin-syntax-dynamic-import@6.18.0
[INFO] β”‚     β”œβ”€β”¬ babel-plugin-transform-class-properties@6.24.1
[INFO] β”‚     β”‚ └── babel-plugin-syntax-class-properties@6.13.0
[INFO] β”‚     β”œβ”€β”¬ babel-plugin-transform-decorators@6.24.1
[INFO] β”‚     β”‚ β”œβ”€β”¬ babel-helper-explode-class@6.24.1
[INFO] β”‚     β”‚ β”‚ └── babel-helper-bindify-decorators@6.24.1
[INFO] β”‚     β”‚ └── babel-plugin-syntax-decorators@6.13.0
[INFO] β”‚     └─┬ babel-preset-stage-3@6.24.1
[INFO] β”‚       β”œβ”€β”€ babel-plugin-syntax-trailing-function-commas@6.22.0
[INFO] β”‚       β”œβ”€β”¬ babel-plugin-transform-async-generator-functions@6.24.1
[INFO] β”‚       β”‚ β”œβ”€β”€ babel-helper-remap-async-to-generator@6.24.1
[INFO] β”‚       β”‚ └── babel-plugin-syntax-async-generators@6.13.0
[INFO] β”‚       β”œβ”€β”¬ babel-plugin-transform-async-to-generator@6.24.1
[INFO] β”‚       β”‚ └── babel-plugin-syntax-async-functions@6.13.0
[INFO] β”‚       β”œβ”€β”¬ babel-plugin-transform-exponentiation-operator@6.24.1
[INFO] β”‚       β”‚ β”œβ”€β”¬ babel-helper-builder-binary-assignment-operator-visitor@6.24.1
[INFO] β”‚       β”‚ β”‚ └── babel-helper-explode-assignable-expression@6.24.1
[INFO] β”‚       β”‚ └── babel-plugin-syntax-exponentiation-operator@6.13.0
[INFO] β”‚       └─┬ babel-plugin-transform-object-rest-spread@6.23.0
[INFO] β”‚         └── babel-plugin-syntax-object-rest-spread@6.13.0
[INFO] β”œβ”€β”€ bluebird@3.5.0
[INFO] β”œβ”€β”€ bootstrap@3.3.7
[INFO] β”œβ”€β”€ c3@0.4.11
[INFO] β”œβ”€β”€ classnames@2.2.5
[INFO] β”œβ”€β”¬ clean-webpack-plugin@0.1.16
[INFO] β”‚ └── rimraf@2.5.4
[INFO] β”œβ”€β”¬ clipboard@1.6.1
[INFO] β”‚ β”œβ”€β”¬ good-listener@1.2.2
[INFO] β”‚ β”‚ └── delegate@3.1.2
[INFO] β”‚ β”œβ”€β”€ select@1.1.2
[INFO] β”‚ └── tiny-emitter@1.2.0
[INFO] β”œβ”€β”€ crossfilter@1.3.12
[INFO] β”œβ”€β”¬ css-loader@0.26.4
[INFO] β”‚ β”œβ”€β”¬ css-selector-tokenizer@0.7.0
[INFO] β”‚ β”‚ β”œβ”€β”€ cssesc@0.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ fastparse@1.1.1
[INFO] β”‚ β”‚ └── regexpu-core@1.0.0
[INFO] β”‚ β”œβ”€β”¬ cssnano@3.10.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ autoprefixer@6.7.7
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ browserslist@1.7.7
[INFO] β”‚ β”‚ β”‚ β”‚ └── electron-to-chromium@1.3.9
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ caniuse-db@1.0.30000664
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ normalize-range@0.1.2
[INFO] β”‚ β”‚ β”‚ └── num2fraction@1.2.2
[INFO] β”‚ β”‚ β”œβ”€β”€ decamelize@1.2.0
[INFO] β”‚ β”‚ β”œβ”€β”€ defined@1.0.0
[INFO] β”‚ β”‚ β”œβ”€β”€ has@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-calc@5.3.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ postcss-message-helpers@2.0.0
[INFO] β”‚ β”‚ β”‚ └─┬ reduce-css-calc@1.3.0
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ math-expression-evaluator@1.2.17
[INFO] β”‚ β”‚ β”‚   └── reduce-function-call@1.0.2
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-colormin@2.2.2
[INFO] β”‚ β”‚ β”‚ └─┬ colormin@1.1.2
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”¬ color@0.11.4
[INFO] β”‚ β”‚ β”‚   β”‚ β”œβ”€β”€ clone@1.0.2
[INFO] β”‚ β”‚ β”‚   β”‚ β”œβ”€β”¬ color-convert@1.9.0
[INFO] β”‚ β”‚ β”‚   β”‚ β”‚ └── color-name@1.1.2
[INFO] β”‚ β”‚ β”‚   β”‚ └── color-string@0.3.0
[INFO] β”‚ β”‚ β”‚   └── css-color-names@0.0.4
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-convert-values@2.6.1
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-discard-comments@2.0.4
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-discard-duplicates@2.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-discard-empty@2.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-discard-overridden@0.1.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-discard-unused@2.2.3
[INFO] β”‚ β”‚ β”‚ └── uniqs@2.0.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-filter-plugins@2.0.2
[INFO] β”‚ β”‚ β”‚ └─┬ uniqid@4.1.1
[INFO] β”‚ β”‚ β”‚   └── macaddress@0.2.8
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-merge-idents@2.1.7
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-merge-longhand@2.0.2
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-merge-rules@2.1.2
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ caniuse-api@1.6.1
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ lodash.memoize@4.1.2
[INFO] β”‚ β”‚ β”‚ β”‚ └── lodash.uniq@4.5.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ postcss-selector-parser@2.2.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ flatten@1.0.2
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ indexes-of@1.0.1
[INFO] β”‚ β”‚ β”‚ β”‚ └── uniq@1.0.1
[INFO] β”‚ β”‚ β”‚ └── vendors@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-minify-font-values@1.0.5
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-minify-gradients@1.0.5
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-minify-params@1.2.2
[INFO] β”‚ β”‚ β”‚ └── alphanum-sort@1.0.2
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-minify-selectors@2.1.1
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-normalize-charset@1.1.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-normalize-url@3.0.8
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ is-absolute-url@2.1.0
[INFO] β”‚ β”‚ β”‚ └─┬ normalize-url@1.9.1
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ prepend-http@1.0.4
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ query-string@4.3.4
[INFO] β”‚ β”‚ β”‚   └─┬ sort-keys@1.1.2
[INFO] β”‚ β”‚ β”‚     └── is-plain-obj@1.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-ordered-values@2.2.3
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-reduce-idents@2.4.0
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-reduce-initial@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-reduce-transforms@1.0.4
[INFO] β”‚ β”‚ β”œβ”€β”¬ postcss-svgo@2.1.6
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ is-svg@2.1.0
[INFO] β”‚ β”‚ β”‚ β”‚ └── html-comment-regex@1.1.1
[INFO] β”‚ β”‚ β”‚ └─┬ svgo@0.7.2
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”¬ coa@1.0.1
[INFO] β”‚ β”‚ β”‚   β”‚ └── q@1.5.0
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”¬ csso@2.3.2
[INFO] β”‚ β”‚ β”‚   β”‚ └── clap@1.1.3
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”¬ js-yaml@3.7.0
[INFO] β”‚ β”‚ β”‚   β”‚ └── esprima@2.7.3
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ sax@1.2.2
[INFO] β”‚ β”‚ β”‚   └── whet.extend@0.9.9
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-unique-selectors@2.0.2
[INFO] β”‚ β”‚ β”œβ”€β”€ postcss-value-parser@3.3.0
[INFO] β”‚ β”‚ └── postcss-zindex@2.2.0
[INFO] β”‚ β”œβ”€β”€ loader-utils@1.1.0
[INFO] β”‚ β”œβ”€β”€ lodash.camelcase@4.3.0
[INFO] β”‚ β”œβ”€β”¬ postcss@5.2.17
[INFO] β”‚ β”‚ β”œβ”€β”€ js-base64@2.1.9
[INFO] β”‚ β”‚ └── supports-color@3.2.3
[INFO] β”‚ β”œβ”€β”€ postcss-modules-extract-imports@1.0.1
[INFO] β”‚ β”œβ”€β”¬ postcss-modules-local-by-default@1.1.1
[INFO] β”‚ β”‚ └─┬ css-selector-tokenizer@0.6.0
[INFO] β”‚ β”œβ”€β”¬ postcss-modules-scope@1.0.2
[INFO] β”‚ β”œβ”€β”¬ postcss-modules-values@1.2.2
[INFO] β”‚ β”‚ └── icss-replace-symbols@1.0.2
[INFO] β”‚ └── source-list-map@0.1.8
[INFO] β”œβ”€β”€ d3@3.5.17
[INFO] β”œβ”€β”€ dc@2.0.0-beta.19
[INFO] β”œβ”€β”€ deep-equal@1.0.1
[INFO] β”œβ”€β”¬ enzyme@2.8.2
[INFO] β”‚ β”œβ”€β”¬ cheerio@0.22.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ css-select@1.2.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ boolbase@1.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ css-what@2.1.0
[INFO] β”‚ β”‚ β”‚ └── nth-check@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ dom-serializer@0.1.0
[INFO] β”‚ β”‚ β”‚ └── domelementtype@1.1.3
[INFO] β”‚ β”‚ β”œβ”€β”€ entities@1.1.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ htmlparser2@3.9.2
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ domelementtype@1.3.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ domhandler@2.3.0
[INFO] β”‚ β”‚ β”‚ └── domutils@1.5.1
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.assignin@4.2.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.bind@4.2.1
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.defaults@4.2.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.filter@4.6.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.flatten@4.4.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.foreach@4.5.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.map@4.6.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.merge@4.6.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.pick@4.4.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.reduce@4.6.0
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.reject@4.6.0
[INFO] β”‚ β”‚ └── lodash.some@4.6.0
[INFO] β”‚ β”œβ”€β”¬ function.prototype.name@1.0.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ define-properties@1.1.2
[INFO] β”‚ β”‚ β”‚ └── foreach@2.0.5
[INFO] β”‚ β”‚ β”œβ”€β”€ function-bind@1.1.0
[INFO] β”‚ β”‚ └── is-callable@1.1.3
[INFO] β”‚ β”œβ”€β”€ is-subset@0.1.1
[INFO] β”‚ β”œβ”€β”€ object-is@1.0.1
[INFO] β”‚ β”œβ”€β”¬ object.assign@4.0.4
[INFO] β”‚ β”‚ └── object-keys@1.0.11
[INFO] β”‚ β”œβ”€β”¬ object.entries@1.0.4
[INFO] β”‚ β”‚ └─┬ es-abstract@1.7.0
[INFO] β”‚ β”‚   β”œβ”€β”¬ es-to-primitive@1.1.1
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”€ is-date-object@1.0.1
[INFO] β”‚ β”‚   β”‚ └── is-symbol@1.0.1
[INFO] β”‚ β”‚   └── is-regex@1.0.4
[INFO] β”‚ β”œβ”€β”€ object.values@1.0.4
[INFO] β”‚ β”œβ”€β”¬ prop-types@15.5.8
[INFO] β”‚ β”‚ └─┬ fbjs@0.8.12
[INFO] β”‚ β”‚   β”œβ”€β”€ core-js@1.2.7
[INFO] β”‚ β”‚   β”œβ”€β”¬ isomorphic-fetch@2.2.1
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”¬ node-fetch@1.6.3
[INFO] β”‚ β”‚   β”‚ β”‚ └── encoding@0.1.12
[INFO] β”‚ β”‚   β”‚ └── whatwg-fetch@2.0.3
[INFO] β”‚ β”‚   └── setimmediate@1.0.5
[INFO] β”‚ └── uuid@2.0.3
[INFO] β”œβ”€β”¬ eslint@3.19.0
[INFO] β”‚ β”œβ”€β”¬ chalk@1.1.3
[INFO] β”‚ β”‚ β”œβ”€β”€ ansi-styles@2.2.1
[INFO] β”‚ β”‚ β”œβ”€β”€ escape-string-regexp@1.0.5
[INFO] β”‚ β”‚ β”œβ”€β”€ has-ansi@2.0.0
[INFO] β”‚ β”‚ └── supports-color@2.0.0
[INFO] β”‚ β”œβ”€β”¬ concat-stream@1.6.0
[INFO] β”‚ β”‚ └── typedarray@0.0.6
[INFO] β”‚ β”œβ”€β”¬ doctrine@2.0.0
[INFO] β”‚ β”‚ └── isarray@1.0.0
[INFO] β”‚ β”œβ”€β”¬ escope@3.6.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ es6-map@0.1.5
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ d@1.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ es5-ext@0.10.15
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ es6-iterator@2.0.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ es6-set@0.1.5
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ es6-symbol@3.1.1
[INFO] β”‚ β”‚ β”‚ └── event-emitter@0.3.5
[INFO] β”‚ β”‚ β”œβ”€β”€ es6-weak-map@2.0.2
[INFO] β”‚ β”‚ └─┬ esrecurse@4.1.0
[INFO] β”‚ β”‚   └── estraverse@4.1.1
[INFO] β”‚ β”œβ”€β”¬ espree@3.4.2
[INFO] β”‚ β”‚ └─┬ acorn-jsx@3.0.1
[INFO] β”‚ β”‚   └── acorn@3.3.0
[INFO] β”‚ β”œβ”€β”€ esquery@1.0.0
[INFO] β”‚ β”œβ”€β”€ estraverse@4.2.0
[INFO] β”‚ β”œβ”€β”€ esutils@2.0.2
[INFO] β”‚ β”œβ”€β”¬ file-entry-cache@2.0.0
[INFO] β”‚ β”‚ └─┬ flat-cache@1.2.2
[INFO] β”‚ β”‚   β”œβ”€β”€ circular-json@0.3.1
[INFO] β”‚ β”‚   β”œβ”€β”¬ del@2.2.2
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”¬ globby@5.0.0
[INFO] β”‚ β”‚   β”‚ β”‚ └─┬ array-union@1.0.2
[INFO] β”‚ β”‚   β”‚ β”‚   └── array-uniq@1.0.3
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”€ is-path-cwd@1.0.0
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”¬ is-path-in-cwd@1.0.0
[INFO] β”‚ β”‚   β”‚ β”‚ └── is-path-inside@1.0.0
[INFO] β”‚ β”‚   β”‚ └── pify@2.3.0
[INFO] β”‚ β”‚   └── write@0.2.1
[INFO] β”‚ β”œβ”€β”€ globals@9.17.0
[INFO] β”‚ β”œβ”€β”€ ignore@3.3.0
[INFO] β”‚ β”œβ”€β”€ imurmurhash@0.1.4
[INFO] β”‚ β”œβ”€β”¬ inquirer@0.12.0
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
[WARNING] npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
[INFO] β”‚ β”‚ β”œβ”€β”€ ansi-escapes@1.4.0
[INFO] β”‚ β”‚ β”œβ”€β”€ ansi-regex@2.1.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ cli-cursor@1.0.2
[INFO] β”‚ β”‚ β”‚ └─┬ restore-cursor@1.0.1
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ exit-hook@1.1.1
[INFO] β”‚ β”‚ β”‚   └── onetime@1.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ cli-width@2.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ figures@1.7.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ readline2@1.0.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ code-point-at@1.1.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ is-fullwidth-code-point@1.0.0
[INFO] β”‚ β”‚ β”‚ β”‚ └── number-is-nan@1.0.1
[INFO] β”‚ β”‚ β”‚ └── mute-stream@0.0.5
[INFO] β”‚ β”‚ β”œβ”€β”€ run-async@0.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ rx-lite@3.1.2
[INFO] β”‚ β”‚ β”œβ”€β”€ string-width@1.0.2
[INFO] β”‚ β”‚ └── through@2.3.8
[INFO] β”‚ β”œβ”€β”¬ is-my-json-valid@2.16.0
[INFO] β”‚ β”‚ β”œβ”€β”€ generate-function@2.0.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ generate-object-property@1.2.0
[INFO] β”‚ β”‚ β”‚ └── is-property@1.0.2
[INFO] β”‚ β”‚ β”œβ”€β”€ jsonpointer@4.0.1
[INFO] β”‚ β”‚ └── xtend@4.0.1
[INFO] β”‚ β”œβ”€β”¬ is-resolvable@1.0.0
[INFO] β”‚ β”‚ └── tryit@1.0.3
[INFO] β”‚ β”œβ”€β”¬ js-yaml@3.8.3
[INFO] β”‚ β”‚ β”œβ”€β”¬ argparse@1.0.9
[INFO] β”‚ β”‚ β”‚ └── sprintf-js@1.0.3
[INFO] β”‚ β”‚ └── esprima@3.1.3
[INFO] β”‚ β”œβ”€β”¬ json-stable-stringify@1.0.1
[INFO] β”‚ β”‚ └── jsonify@0.0.0
[INFO] β”‚ β”œβ”€β”¬ levn@0.3.0
[INFO] β”‚ β”‚ β”œβ”€β”€ prelude-ls@1.1.2
[INFO] β”‚ β”‚ └── type-check@0.3.2
[INFO] β”‚ β”œβ”€β”€ natural-compare@1.4.0
[INFO] β”‚ β”œβ”€β”¬ optionator@0.8.2
[INFO] β”‚ β”‚ β”œβ”€β”€ deep-is@0.1.3
[INFO] β”‚ β”‚ β”œβ”€β”€ fast-levenshtein@2.0.6
[INFO] β”‚ β”‚ └── wordwrap@1.0.0
[INFO] β”‚ β”œβ”€β”€ path-is-inside@1.0.2
[INFO] β”‚ β”œβ”€β”€ pluralize@1.2.1
[INFO] β”‚ β”œβ”€β”€ progress@1.1.8
[INFO] β”‚ β”œβ”€β”¬ require-uncached@1.0.3
[INFO] β”‚ β”‚ β”œβ”€β”¬ caller-path@0.1.0
[INFO] β”‚ β”‚ β”‚ └── callsites@0.2.0
[INFO] β”‚ β”‚ └── resolve-from@1.0.1
[INFO] β”‚ β”œβ”€β”¬ shelljs@0.7.7
[INFO] β”‚ β”‚ └─┬ rechoir@0.6.2
[INFO] β”‚ β”‚   └─┬ resolve@1.3.3
[INFO] β”‚ β”‚     └── path-parse@1.0.5
[INFO] β”‚ β”œβ”€β”€ strip-bom@3.0.0
[INFO] β”‚ β”œβ”€β”€ strip-json-comments@2.0.1
[INFO] β”‚ β”œβ”€β”¬ table@3.8.3
[INFO] β”‚ β”‚ β”œβ”€β”€ slice-ansi@0.0.4
[INFO] β”‚ β”‚ └─┬ string-width@2.0.0
[INFO] β”‚ β”‚   └── is-fullwidth-code-point@2.0.0
[INFO] β”‚ β”œβ”€β”€ text-table@0.2.0
[INFO] β”‚ └─┬ user-home@2.0.0
[INFO] β”‚   └── os-homedir@1.0.2
[INFO] β”œβ”€β”¬ eslint-loader@1.7.1
[INFO] β”‚ β”œβ”€β”€ loader-fs-cache@1.0.1
[INFO] β”‚ β”œβ”€β”€ object-hash@1.1.8
[INFO] β”‚ └── rimraf@2.6.1
[INFO] β”œβ”€β”€ estraverse-fb@1.3.1
[INFO] β”œβ”€β”¬ extract-text-webpack-plugin@2.1.0
[INFO] β”‚ β”œβ”€β”¬ ajv@4.11.8
[INFO] β”‚ β”‚ └── co@4.6.0
[INFO] β”‚ β”œβ”€β”€ async@2.4.0
[INFO] β”‚ └─┬ webpack-sources@0.1.5
[INFO] β”œβ”€β”¬ file-loader@0.10.1
[INFO] β”‚ └── loader-utils@1.1.0
[INFO] β”œβ”€β”€ font-awesome@4.7.0
[INFO] β”œβ”€β”¬ glob@7.1.1
[INFO] β”‚ β”œβ”€β”€ fs.realpath@1.0.0
[INFO] β”‚ β”œβ”€β”¬ inflight@1.0.6
[INFO] β”‚ β”‚ └── wrappy@1.0.2
[INFO] β”‚ β”œβ”€β”€ inherits@2.0.3
[INFO] β”‚ └── once@1.4.0
[INFO] β”œβ”€β”¬ graylog-web-plugin@2.2.0-SNAPSHOT
[INFO] β”‚ β”œβ”€β”¬ babel-eslint@6.1.2
[INFO] β”‚ β”‚ β”œβ”€β”€ lodash.assign@4.2.0
[INFO] β”‚ β”‚ └── lodash.pickby@4.6.0
[INFO] β”‚ β”œβ”€β”¬ eslint-config-graylog@1.1.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ eslint-config-airbnb@14.1.0
[INFO] β”‚ β”‚ β”‚ └── eslint-config-airbnb-base@11.1.3
[INFO] β”‚ β”‚ β”œβ”€β”¬ eslint-import-resolver-webpack@0.8.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ array-find@1.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ find-root@0.1.2
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ is-absolute@0.2.6
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ is-relative@0.2.1
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └─┬ is-unc-path@0.1.2
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚   └── unc-path-regex@0.1.2
[INFO] β”‚ β”‚ β”‚ β”‚ └── is-windows@0.2.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ lodash.get@3.7.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ lodash._baseget@3.7.2
[INFO] β”‚ β”‚ β”‚ β”‚ └── lodash._topath@3.8.1
[INFO] β”‚ β”‚ β”‚ └─┬ node-libs-browser@1.1.1
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ string_decoder@0.10.31
[INFO] β”‚ β”‚ β”‚   └── timers-browserify@1.4.2
[INFO] β”‚ β”‚ β”œβ”€β”¬ eslint-plugin-import@2.2.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ builtin-modules@1.1.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ contains-path@0.1.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ doctrine@1.5.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ eslint-import-resolver-node@0.2.3
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ eslint-module-utils@2.0.0
[INFO] β”‚ β”‚ β”‚ β”‚ └─┬ debug@2.2.0
[INFO] β”‚ β”‚ β”‚ β”‚   └── ms@0.7.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ lodash.cond@4.5.2
[INFO] β”‚ β”‚ β”‚ └── pkg-up@1.0.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ eslint-plugin-jsx-a11y@4.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ aria-query@0.3.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ ast-types-flow@0.0.7
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ damerau-levenshtein@1.0.4
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ emoji-regex@6.4.2
[INFO] β”‚ β”‚ β”‚ └── jsx-ast-utils@1.4.1
[INFO] β”‚ β”‚ └─┬ eslint-plugin-react@6.10.3
[INFO] β”‚ β”‚   β”œβ”€β”€ array.prototype.find@2.0.4
[INFO] β”‚ β”‚   └── doctrine@1.5.0
[INFO] β”‚ β”œβ”€β”¬ html-webpack-plugin@2.28.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ html-minifier@3.4.3
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ camel-case@3.0.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ no-case@2.3.1
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └── lower-case@1.1.4
[INFO] β”‚ β”‚ β”‚ β”‚ └── upper-case@1.1.3
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ clean-css@4.0.12
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ commander@2.9.0
[INFO] β”‚ β”‚ β”‚ β”‚ └── graceful-readlink@1.0.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ he@1.1.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ ncname@1.0.0
[INFO] β”‚ β”‚ β”‚ β”‚ └── xml-char-classes@1.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ param-case@2.1.1
[INFO] β”‚ β”‚ β”‚ └── relateurl@0.2.7
[INFO] β”‚ β”‚ β”œβ”€β”¬ pretty-error@2.1.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ renderkid@2.0.1
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ dom-converter@0.1.4
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └── utila@0.3.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ htmlparser2@3.3.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ domhandler@2.1.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ domutils@1.1.6
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └─┬ readable-stream@1.0.34
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚   β”œβ”€β”€ isarray@0.0.1
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚   └── string_decoder@0.10.31
[INFO] β”‚ β”‚ β”‚ β”‚ └── utila@0.3.3
[INFO] β”‚ β”‚ β”‚ └── utila@0.4.0
[INFO] β”‚ β”‚ └── toposort@1.0.3
[INFO] β”‚ β”œβ”€β”€ jquery@2.1.4
[INFO] β”‚ β”œβ”€β”€ moment@2.14.1
[INFO] β”‚ β”œβ”€β”€ moment-timezone@0.5.7
[INFO] β”‚ β”œβ”€β”¬ react@0.14.9
[INFO] β”‚ β”‚ β”œβ”€β”¬ envify@3.4.1
[INFO] β”‚ β”‚ β”‚ └─┬ jstransform@11.0.3
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ base62@1.1.2
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”¬ commoner@0.10.8
[INFO] β”‚ β”‚ β”‚   β”‚ β”œβ”€β”¬ detective@4.5.0
[INFO] β”‚ β”‚ β”‚   β”‚ β”‚ └── acorn@4.0.11
[INFO] β”‚ β”‚ β”‚   β”‚ β”œβ”€β”€ glob@5.0.15
[INFO] β”‚ β”‚ β”‚   β”‚ β”œβ”€β”€ iconv-lite@0.4.17
[INFO] β”‚ β”‚ β”‚   β”‚ └─┬ recast@0.11.23
[INFO] β”‚ β”‚ β”‚   β”‚   └── ast-types@0.9.6
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ esprima-fb@15001.1.0-dev-harmony-fb
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ object-assign@2.1.1
[INFO] β”‚ β”‚ β”‚   └── source-map@0.4.4
[INFO] β”‚ β”‚ └─┬ fbjs@0.6.1
[INFO] β”‚ β”‚   └── whatwg-fetch@0.9.0
[INFO] β”‚ β”œβ”€β”€ react-addons-linked-state-mixin@0.14.8
[INFO] β”‚ β”œβ”€β”€ react-addons-pure-render-mixin@0.14.8
[INFO] β”‚ β”œβ”€β”€ react-addons-test-utils@0.14.8
[INFO] β”‚ β”œβ”€β”¬ react-bootstrap@0.30.10
[INFO] β”‚ β”‚ β”œβ”€β”€ keycode@2.1.8
[INFO] β”‚ β”‚ β”œβ”€β”€ uncontrollable@4.1.0
[INFO] β”‚ β”‚ └── warning@3.0.0
[INFO] β”‚ β”œβ”€β”€ react-dom@0.14.9
[INFO] β”‚ β”œβ”€β”€ react-router@1.0.3
[INFO] β”‚ β”œβ”€β”€ react-router-bootstrap@0.19.3
[INFO] β”‚ β”œβ”€β”¬ reflux@0.2.13
[INFO] β”‚ β”‚ β”œβ”€β”€ eventemitter3@1.2.0
[INFO] β”‚ β”‚ └── reflux-core@0.2.1
[INFO] β”‚ └─┬ webpack-cleanup-plugin@0.4.2
[INFO] β”‚   β”œβ”€β”€ lodash.union@4.6.0
[INFO] β”‚   └── recursive-readdir-sync@1.0.6
[INFO] β”œβ”€β”¬ history@1.17.0
[INFO] β”‚ β”œβ”€β”¬ invariant@2.2.2
[INFO] β”‚ β”‚ └── loose-envify@1.3.1
[INFO] β”‚ β”œβ”€β”¬ query-string@3.0.3
[INFO] β”‚ β”‚ └── strict-uri-encode@1.1.0
[INFO] β”‚ └── warning@2.1.0
[INFO] β”œβ”€β”€ immutable@3.8.1
[INFO] β”œβ”€β”€ jasmine-core@2.6.1
[INFO] β”œβ”€β”€ javascript-natural-sort@0.7.1
[INFO] β”œβ”€β”€ jquery-ui@1.12.1
[INFO] β”œβ”€β”€ json-loader@0.5.4
[INFO] β”œβ”€β”¬ karma@1.6.0
[INFO] β”‚ β”œβ”€β”¬ body-parser@1.17.1
[INFO] β”‚ β”‚ β”œβ”€β”€ bytes@2.4.0
[INFO] β”‚ β”‚ β”œβ”€β”€ content-type@1.0.2
[INFO] β”‚ β”‚ β”œβ”€β”¬ debug@2.6.1
[INFO] β”‚ β”‚ β”‚ └── ms@0.7.2
[INFO] β”‚ β”‚ β”œβ”€β”€ depd@1.1.0
[INFO] β”‚ β”‚ β”œβ”€β”€ http-errors@1.6.1
[INFO] β”‚ β”‚ β”œβ”€β”€ iconv-lite@0.4.15
[INFO] β”‚ β”‚ β”œβ”€β”¬ on-finished@2.3.0
[INFO] β”‚ β”‚ β”‚ └── ee-first@1.1.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ raw-body@2.2.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ iconv-lite@0.4.15
[INFO] β”‚ β”‚ β”‚ └── unpipe@1.0.0
[INFO] β”‚ β”‚ └─┬ type-is@1.6.15
[INFO] β”‚ β”‚   └── media-typer@0.3.0
[INFO] β”‚ β”œβ”€β”¬ chokidar@1.6.1
[INFO] β”‚ β”‚ β”œβ”€β”€ anymatch@1.3.0
[INFO] β”‚ β”‚ β”œβ”€β”€ async-each@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ glob-parent@2.0.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ is-binary-path@1.0.1
[INFO] β”‚ β”‚ β”‚ └── binary-extensions@1.8.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ is-glob@2.0.1
[INFO] β”‚ β”‚ β”‚ └── is-extglob@1.0.0
[INFO] β”‚ β”‚ └─┬ readdirp@2.1.0
[INFO] β”‚ β”‚   └── set-immediate-shim@1.0.1
[INFO] β”‚ β”œβ”€β”€ colors@1.1.2
[INFO] β”‚ β”œβ”€β”€ combine-lists@1.0.1
[INFO] β”‚ β”œβ”€β”¬ connect@3.6.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ debug@2.6.3
[INFO] β”‚ β”‚ β”œβ”€β”¬ finalhandler@1.0.1
[INFO] β”‚ β”‚ β”‚ └─┬ debug@2.6.3
[INFO] β”‚ β”‚ β”œβ”€β”€ parseurl@1.3.1
[INFO] β”‚ β”‚ └── utils-merge@1.0.0
[INFO] β”‚ β”œβ”€β”€ di@0.0.1
[INFO] β”‚ β”œβ”€β”¬ dom-serialize@2.2.1
[INFO] β”‚ β”‚ β”œβ”€β”€ custom-event@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ ent@2.2.0
[INFO] β”‚ β”‚ └── void-elements@2.0.1
[INFO] β”‚ β”œβ”€β”¬ expand-braces@0.1.2
[INFO] β”‚ β”‚ β”œβ”€β”€ array-slice@0.2.3
[INFO] β”‚ β”‚ β”œβ”€β”€ array-unique@0.2.1
[INFO] β”‚ β”‚ └─┬ braces@0.1.5
[INFO] β”‚ β”‚   └─┬ expand-range@0.1.1
[INFO] β”‚ β”‚     β”œβ”€β”€ is-number@0.1.1
[INFO] β”‚ β”‚     └── repeat-string@0.2.2
[INFO] β”‚ β”œβ”€β”€ graceful-fs@4.1.11
[INFO] β”‚ β”œβ”€β”¬ http-proxy@1.16.2
[INFO] β”‚ β”‚ └── requires-port@1.0.0
[INFO] β”‚ β”œβ”€β”€ isbinaryfile@3.0.2
[INFO] β”‚ β”œβ”€β”€ lodash@3.10.1
[INFO] β”‚ β”œβ”€β”¬ log4js@0.6.38
[INFO] β”‚ β”‚ β”œβ”€β”¬ readable-stream@1.0.34
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ isarray@0.0.1
[INFO] β”‚ β”‚ β”‚ └── string_decoder@0.10.31
[INFO] β”‚ β”‚ └── semver@4.3.6
[INFO] β”‚ β”œβ”€β”€ mime@1.3.4
[INFO] β”‚ β”œβ”€β”¬ optimist@0.6.1
[INFO] β”‚ β”‚ └── wordwrap@0.0.3
[INFO] β”‚ β”œβ”€β”€ qjobs@1.1.5
[INFO] β”‚ β”œβ”€β”€ range-parser@1.2.0
[INFO] β”‚ β”œβ”€β”€ safe-buffer@5.0.1
[INFO] β”‚ β”œβ”€β”¬ socket.io@1.7.3
[INFO] β”‚ β”‚ β”œβ”€β”¬ debug@2.3.3
[INFO] β”‚ β”‚ β”œβ”€β”¬ engine.io@1.8.3
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ base64id@1.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ debug@2.3.3
[INFO] β”‚ β”‚ β”‚ β”‚ └── ms@0.7.2
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ engine.io-parser@1.3.2
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ after@0.8.2
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ arraybuffer.slice@0.0.6
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ base64-arraybuffer@0.1.5
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ blob@0.0.4
[INFO] β”‚ β”‚ β”‚ β”‚ └── wtf-8@1.0.0
[INFO] β”‚ β”‚ β”‚ └─┬ ws@1.1.2
[INFO] β”‚ β”‚ β”‚   β”œβ”€β”€ options@0.0.6
[INFO] β”‚ β”‚ β”‚   └── ultron@1.0.2
[INFO] β”‚ β”‚ β”œβ”€β”¬ has-binary@0.1.7
[INFO] β”‚ β”‚ β”‚ └── isarray@0.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ object-assign@4.1.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ socket.io-adapter@0.5.0
[INFO] β”‚ β”‚ β”‚ └─┬ debug@2.3.3
[INFO] β”‚ β”‚ β”œβ”€β”¬ socket.io-client@1.7.3
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ backo2@1.0.2
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ component-bind@1.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ engine.io-client@1.8.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ component-inherit@0.0.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ debug@2.3.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └── ms@0.7.2
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ has-cors@1.1.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ parsejson@0.0.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ parseqs@0.0.5
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ xmlhttprequest-ssl@1.5.3
[INFO] β”‚ β”‚ β”‚ β”‚ └── yeast@0.1.2
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ indexof@0.0.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ object-component@0.0.3
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ parseuri@0.0.5
[INFO] β”‚ β”‚ β”‚ β”‚ └─┬ better-assert@1.0.2
[INFO] β”‚ β”‚ β”‚ β”‚   └── callsite@1.0.0
[INFO] β”‚ β”‚ β”‚ └── to-array@0.1.4
[INFO] β”‚ β”‚ └─┬ socket.io-parser@2.3.1
[INFO] β”‚ β”‚   β”œβ”€β”€ component-emitter@1.1.2
[INFO] β”‚ β”‚   β”œβ”€β”¬ debug@2.2.0
[INFO] β”‚ β”‚   β”‚ └── ms@0.7.1
[INFO] β”‚ β”‚   └── isarray@0.0.1
[INFO] β”‚ β”œβ”€β”¬ tmp@0.0.31
[INFO] β”‚ β”‚ └── os-tmpdir@1.0.2
[INFO] β”‚ └─┬ useragent@2.1.13
[INFO] β”‚   └── lru-cache@2.2.4
[INFO] β”œβ”€β”¬ karma-chrome-launcher@2.0.0
[INFO] β”‚ β”œβ”€β”¬ fs-access@1.0.1
[INFO] β”‚ β”‚ └── null-check@1.0.0
[INFO] β”‚ └─┬ which@1.2.14
[INFO] β”‚   └── isexe@2.0.0
[INFO] β”œβ”€β”€ karma-html2js-preprocessor@1.1.0
[INFO] β”œβ”€β”€ karma-jasmine@1.1.0
[INFO] β”œβ”€β”€ karma-phantomjs-launcher@1.0.4
[INFO] β”œβ”€β”¬ karma-webpack@2.0.3
[INFO] β”‚ β”œβ”€β”€ async@0.9.2
[INFO] β”‚ β”œβ”€β”¬ source-map@0.1.43
[INFO] β”‚ β”‚ └── amdefine@1.0.1
[INFO] β”‚ └─┬ webpack-dev-middleware@1.10.2
[INFO] β”‚   └── memory-fs@0.4.1
[INFO] β”œβ”€β”¬ less@2.7.2
[INFO] β”‚ β”œβ”€β”¬ errno@0.1.4
[INFO] β”‚ β”‚ └── prr@0.0.0
[INFO] β”‚ β”œβ”€β”€ image-size@0.5.1
[INFO] β”‚ β”œβ”€β”¬ promise@7.1.1
[INFO] β”‚ β”‚ └── asap@2.0.5
[INFO] β”‚ └─┬ request@2.79.0
[INFO] β”‚   β”œβ”€β”€ aws-sign2@0.6.0
[INFO] β”‚   β”œβ”€β”€ aws4@1.6.0
[INFO] β”‚   β”œβ”€β”€ caseless@0.11.0
[INFO] β”‚   β”œβ”€β”¬ combined-stream@1.0.5
[INFO] β”‚   β”‚ └── delayed-stream@1.0.0
[INFO] β”‚   β”œβ”€β”€ forever-agent@0.6.1
[INFO] β”‚   β”œβ”€β”€ har-validator@2.0.6
[INFO] β”‚   β”œβ”€β”¬ hawk@3.1.3
[INFO] β”‚   β”‚ β”œβ”€β”€ boom@2.10.1
[INFO] β”‚   β”‚ β”œβ”€β”€ cryptiles@2.0.5
[INFO] β”‚   β”‚ β”œβ”€β”€ hoek@2.16.3
[INFO] β”‚   β”‚ └── sntp@1.0.9
[INFO] β”‚   β”œβ”€β”¬ http-signature@1.1.1
[INFO] β”‚   β”‚ β”œβ”€β”€ assert-plus@0.2.0
[INFO] β”‚   β”‚ β”œβ”€β”¬ jsprim@1.4.0
[INFO] β”‚   β”‚ β”‚ β”œβ”€β”€ assert-plus@1.0.0
[INFO] β”‚   β”‚ β”‚ β”œβ”€β”€ extsprintf@1.0.2
[INFO] β”‚   β”‚ β”‚ β”œβ”€β”€ json-schema@0.2.3
[INFO] β”‚   β”‚ β”‚ └── verror@1.3.6
[INFO] β”‚   β”‚ └─┬ sshpk@1.13.0
[INFO] β”‚   β”‚   β”œβ”€β”€ asn1@0.2.3
[INFO] β”‚   β”‚   β”œβ”€β”€ assert-plus@1.0.0
[INFO] β”‚   β”‚   β”œβ”€β”€ bcrypt-pbkdf@1.0.1
[INFO] β”‚   β”‚   β”œβ”€β”¬ dashdash@1.14.1
[INFO] β”‚   β”‚   β”‚ └── assert-plus@1.0.0
[INFO] β”‚   β”‚   β”œβ”€β”€ ecc-jsbn@0.1.1
[INFO] β”‚   β”‚   β”œβ”€β”¬ getpass@0.1.7
[INFO] β”‚   β”‚   β”œβ”€β”€ jodid25519@1.0.2
[INFO] β”‚   β”‚   β”œβ”€β”€ jsbn@0.1.1
[INFO] β”‚   β”‚   └── tweetnacl@0.14.5
[INFO] β”‚   β”œβ”€β”€ is-typedarray@1.0.0
[INFO] β”‚   β”œβ”€β”€ isstream@0.1.2
[INFO] β”‚   β”œβ”€β”€ json-stringify-safe@5.0.1
[INFO] β”‚   β”œβ”€β”¬ mime-types@2.1.15
[INFO] β”‚   β”‚ └── mime-db@1.27.0
[INFO] β”‚   β”œβ”€β”€ oauth-sign@0.8.2
[INFO] β”‚   β”œβ”€β”€ qs@6.3.2
[INFO] β”‚   β”œβ”€β”€ stringstream@0.0.5
[INFO] β”‚   β”œβ”€β”€ tough-cookie@2.3.2
[INFO] β”‚   β”œβ”€β”€ tunnel-agent@0.4.3
[INFO] β”‚   └── uuid@3.0.1
[INFO] β”œβ”€β”€ less-loader@2.2.3
[INFO] β”œβ”€β”€ lodash@4.17.4
[INFO] β”œβ”€β”¬ markdown@0.5.0
[INFO] β”‚ └─┬ nopt@2.1.2
[INFO] β”‚   └── abbrev@1.1.0
[INFO] β”œβ”€β”¬ md5@2.2.1
[INFO] β”‚ β”œβ”€β”€ charenc@0.0.2
[INFO] β”‚ β”œβ”€β”€ crypt@0.0.2
[INFO] β”‚ └── is-buffer@1.1.5
[INFO] β”œβ”€β”¬ mocha@2.5.3
[INFO] β”‚ β”œβ”€β”€ commander@2.3.0
[INFO] β”‚ β”œβ”€β”¬ debug@2.2.0
[INFO] β”‚ β”‚ └── ms@0.7.1
[INFO] β”‚ β”œβ”€β”€ diff@1.4.0
[INFO] β”‚ β”œβ”€β”€ escape-string-regexp@1.0.2
[INFO] β”‚ β”œβ”€β”¬ glob@3.2.11
[INFO] β”‚ β”‚ └─┬ minimatch@0.3.0
[INFO] β”‚ β”‚   └── sigmund@1.0.1
[INFO] β”‚ β”œβ”€β”€ growl@1.9.2
[INFO] β”‚ β”œβ”€β”¬ jade@0.26.3
[INFO] β”‚ β”‚ β”œβ”€β”€ commander@0.6.1
[INFO] β”‚ β”‚ └── mkdirp@0.3.0
[INFO] β”‚ β”œβ”€β”€ supports-color@1.2.0
[INFO] β”‚ └── to-iso-string@0.0.2
[INFO] β”œβ”€β”€ moment-duration-format@1.3.0
[INFO] β”œβ”€β”€ numeral@1.5.6
[INFO] β”œβ”€β”€ opensans-npm-webfont@0.0.2
[INFO] β”œβ”€β”¬ phantomjs-prebuilt@2.1.14
[INFO] β”‚ β”œβ”€β”€ es6-promise@4.0.5
[INFO] β”‚ β”œβ”€β”¬ extract-zip@1.5.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ concat-stream@1.5.0
[INFO] β”‚ β”‚ β”‚ └─┬ readable-stream@2.0.6
[INFO] β”‚ β”‚ β”œβ”€β”€ debug@0.7.4
[INFO] β”‚ β”‚ β”œβ”€β”€ mkdirp@0.5.0
[INFO] β”‚ β”‚ └─┬ yauzl@2.4.1
[INFO] β”‚ β”‚   └─┬ fd-slicer@1.0.1
[INFO] β”‚ β”‚     └── pend@1.2.0
[INFO] β”‚ β”œβ”€β”¬ fs-extra@1.0.0
[INFO] β”‚ β”‚ β”œβ”€β”€ jsonfile@2.4.0
[INFO] β”‚ β”‚ └── klaw@1.3.1
[INFO] β”‚ β”œβ”€β”¬ hasha@2.2.0
[INFO] β”‚ β”‚ β”œβ”€β”€ is-stream@1.1.0
[INFO] β”‚ β”‚ └─┬ pinkie-promise@2.0.1
[INFO] β”‚ β”‚   └── pinkie@2.0.4
[INFO] β”‚ β”œβ”€β”€ kew@0.7.0
[INFO] β”‚ └─┬ request-progress@2.0.1
[INFO] β”‚   └── throttleit@1.0.0
[INFO] β”œβ”€β”€ qs@6.4.0
[INFO] β”œβ”€β”€ react-day-picker@5.4.1
[INFO] β”œβ”€β”¬ react-dnd@2.3.0
[INFO] β”‚ β”œβ”€β”€ disposables@1.0.1
[INFO] β”‚ β”œβ”€β”¬ dnd-core@2.3.0
[INFO] β”‚ β”‚ └─┬ redux@3.6.0
[INFO] β”‚ β”‚   β”œβ”€β”€ lodash-es@4.17.4
[INFO] β”‚ β”‚   └── symbol-observable@1.0.4
[INFO] β”‚ └── hoist-non-react-statics@1.2.0
[INFO] β”œβ”€β”€ react-dnd-html5-backend@2.3.0
[INFO] β”œβ”€β”¬ react-grid-layout@0.14.6
[INFO] β”‚ β”œβ”€β”€ lodash.isequal@4.5.0
[INFO] β”‚ β”œβ”€β”€ react-draggable@2.2.6
[INFO] β”‚ └── react-resizable@1.7.0
[INFO] β”œβ”€β”¬ react-hot-loader@3.0.0-beta.6
[INFO] β”‚ β”œβ”€β”¬ global@4.3.2
[INFO] β”‚ β”‚ β”œβ”€β”¬ min-document@2.19.0
[INFO] β”‚ β”‚ β”‚ └── dom-walk@0.1.1
[INFO] β”‚ β”‚ └── process@0.5.2
[INFO] β”‚ β”œβ”€β”€ react-deep-force-update@2.0.1
[INFO] β”‚ β”œβ”€β”€ react-proxy@3.0.0-alpha.1
[INFO] β”‚ β”œβ”€β”¬ redbox-react@1.3.6
[INFO] β”‚ β”‚ └─┬ error-stack-parser@1.3.6
[INFO] β”‚ β”‚   └── stackframe@0.3.1
[INFO] β”‚ └── source-map@0.4.4
[INFO] β”œβ”€β”¬ react-overlays@0.6.12
[INFO] β”‚ β”œβ”€β”€ dom-helpers@3.2.1
[INFO] β”‚ β”œβ”€β”¬ react-prop-types@0.4.0
[INFO] β”‚ └── warning@3.0.0
[INFO] β”œβ”€β”¬ react-proxy-loader@0.3.5
[INFO] β”œβ”€β”¬ react-select@0.8.4
[INFO] β”‚ └── react-input-autosize@0.6.13
[INFO] β”œβ”€β”€ rickshaw@1.6.0
[INFO] β”œβ”€β”¬ script-loader@0.7.0
[INFO] β”‚ └── raw-loader@0.5.1
[INFO] β”œβ”€β”¬ sockjs-client@1.1.4
[INFO] β”‚ β”œβ”€β”¬ eventsource@0.1.6
[INFO] β”‚ β”‚ └─┬ original@1.0.0
[INFO] β”‚ β”‚   └── url-parse@1.0.5
[INFO] β”‚ β”œβ”€β”¬ faye-websocket@0.11.1
[INFO] β”‚ β”‚ └─┬ websocket-driver@0.6.5
[INFO] β”‚ β”‚   └── websocket-extensions@0.1.1
[INFO] β”‚ β”œβ”€β”€ json3@3.3.2
[INFO] β”‚ └─┬ url-parse@1.1.8
[INFO] β”‚   └── querystringify@0.0.4
[INFO] β”œβ”€β”€ string@3.3.3
[INFO] β”œβ”€β”¬ style-loader@0.13.2
[INFO] β”œβ”€β”¬ superagent@3.5.2
[INFO] β”‚ β”œβ”€β”€ component-emitter@1.2.1
[INFO] β”‚ β”œβ”€β”€ cookiejar@2.1.1
[INFO] β”‚ β”œβ”€β”€ extend@3.0.1
[INFO] β”‚ β”œβ”€β”¬ form-data@2.1.4
[INFO] β”‚ β”‚ └── asynckit@0.4.0
[INFO] β”‚ β”œβ”€β”€ formidable@1.1.1
[INFO] β”‚ β”œβ”€β”€ methods@1.1.2
[INFO] β”‚ └─┬ readable-stream@2.2.9
[INFO] β”‚   β”œβ”€β”€ buffer-shims@1.0.0
[INFO] β”‚   β”œβ”€β”€ core-util-is@1.0.2
[INFO] β”‚   β”œβ”€β”€ process-nextick-args@1.0.7
[INFO] β”‚   β”œβ”€β”€ string_decoder@1.0.0
[INFO] β”‚   └── util-deprecate@1.0.2
[INFO] β”œβ”€β”€ superagent-bluebird-promise@4.2.0
[INFO] β”œβ”€β”€ toastr@2.1.2
[INFO] β”œβ”€β”¬ ts-loader@0.8.2
[INFO] β”‚ β”œβ”€β”€ arrify@1.0.1
[INFO] β”‚ β”œβ”€β”¬ enhanced-resolve@0.9.1
[INFO] β”‚ β”‚ β”œβ”€β”€ memory-fs@0.2.0
[INFO] β”‚ β”‚ └── tapable@0.1.10
[INFO] β”‚ β”œβ”€β”€ object-assign@2.1.1
[INFO] β”‚ └── semver@5.3.0
[INFO] β”œβ”€β”€ typeahead.js@0.11.1
[INFO] β”œβ”€β”€ typescript@1.8.10
[INFO] β”œβ”€β”€ ua-parser-js@0.7.12
[INFO] β”œβ”€β”€ urijs@1.18.10
[INFO] β”œβ”€β”¬ url-loader@0.5.8
[INFO] β”œβ”€β”¬ webpack@2.4.1
[INFO] β”‚ β”œβ”€β”€ acorn@5.0.3
[INFO] β”‚ β”œβ”€β”¬ acorn-dynamic-import@2.0.2
[INFO] β”‚ β”‚ └── acorn@4.0.11
[INFO] β”‚ β”œβ”€β”€ ajv-keywords@1.5.1
[INFO] β”‚ β”œβ”€β”€ enhanced-resolve@3.1.0
[INFO] β”‚ β”œβ”€β”€ interpret@1.0.3
[INFO] β”‚ β”œβ”€β”€ loader-runner@2.3.0
[INFO] β”‚ β”œβ”€β”€ memory-fs@0.4.1
[INFO] β”‚ β”œβ”€β”¬ node-libs-browser@2.0.0
[INFO] β”‚ β”‚ β”œβ”€β”€ assert@1.4.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ browserify-zlib@0.1.4
[INFO] β”‚ β”‚ β”‚ └── pako@0.2.9
[INFO] β”‚ β”‚ β”œβ”€β”¬ buffer@4.9.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ base64-js@1.2.0
[INFO] β”‚ β”‚ β”‚ └── ieee754@1.1.8
[INFO] β”‚ β”‚ β”œβ”€β”¬ console-browserify@1.1.0
[INFO] β”‚ β”‚ β”‚ └── date-now@0.1.4
[INFO] β”‚ β”‚ β”œβ”€β”€ constants-browserify@1.0.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ crypto-browserify@3.11.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ browserify-cipher@1.0.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ browserify-aes@1.0.6
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └── buffer-xor@1.0.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ browserify-des@1.0.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └── des.js@1.0.0
[INFO] β”‚ β”‚ β”‚ β”‚ └── evp_bytestokey@1.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ browserify-sign@4.0.4
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ bn.js@4.11.6
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ browserify-rsa@4.0.1
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”¬ elliptic@6.4.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ brorand@1.1.0
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ hash.js@1.0.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ hmac-drbg@1.0.1
[INFO] β”‚ β”‚ β”‚ β”‚ β”‚ └── minimalistic-crypto-utils@1.0.1
[INFO] β”‚ β”‚ β”‚ β”‚ └─┬ parse-asn1@5.1.0
[INFO] β”‚ β”‚ β”‚ β”‚   └── asn1.js@4.9.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ create-ecdh@4.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ create-hash@1.1.2
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ cipher-base@1.0.3
[INFO] β”‚ β”‚ β”‚ β”‚ β”œβ”€β”€ ripemd160@1.0.1
[INFO] β”‚ β”‚ β”‚ β”‚ └── sha.js@2.4.8
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ create-hmac@1.1.4
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”¬ diffie-hellman@5.0.2
[INFO] β”‚ β”‚ β”‚ β”‚ └── miller-rabin@4.0.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ pbkdf2@3.0.9
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ public-encrypt@4.0.0
[INFO] β”‚ β”‚ β”‚ └── randombytes@2.0.3
[INFO] β”‚ β”‚ β”œβ”€β”€ domain-browser@1.1.7
[INFO] β”‚ β”‚ β”œβ”€β”€ events@1.1.1
[INFO] β”‚ β”‚ β”œβ”€β”€ https-browserify@0.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ os-browserify@0.2.1
[INFO] β”‚ β”‚ β”œβ”€β”€ path-browserify@0.0.0
[INFO] β”‚ β”‚ β”œβ”€β”€ process@0.11.10
[INFO] β”‚ β”‚ β”œβ”€β”€ punycode@1.4.1
[INFO] β”‚ β”‚ β”œβ”€β”€ querystring-es3@0.2.1
[INFO] β”‚ β”‚ β”œβ”€β”€ stream-browserify@2.0.1
[INFO] β”‚ β”‚ β”œβ”€β”¬ stream-http@2.7.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ builtin-status-codes@3.0.0
[INFO] β”‚ β”‚ β”‚ └── to-arraybuffer@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ string_decoder@0.10.31
[INFO] β”‚ β”‚ β”œβ”€β”€ timers-browserify@2.0.2
[INFO] β”‚ β”‚ β”œβ”€β”€ tty-browserify@0.0.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ url@0.11.0
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ punycode@1.3.2
[INFO] β”‚ β”‚ β”‚ └── querystring@0.2.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ util@0.10.3
[INFO] β”‚ β”‚ β”‚ └── inherits@2.0.1
[INFO] β”‚ β”‚ └── vm-browserify@0.0.4
[INFO] β”‚ β”œβ”€β”¬ supports-color@3.2.3
[INFO] β”‚ β”‚ └── has-flag@1.0.0
[INFO] β”‚ β”œβ”€β”€ tapable@0.2.6
[INFO] β”‚ β”œβ”€β”¬ uglify-js@2.8.22
[INFO] β”‚ β”‚ β”œβ”€β”€ uglify-to-browserify@1.0.2
[INFO] β”‚ β”‚ └─┬ yargs@3.10.0
[INFO] β”‚ β”‚   β”œβ”€β”€ camelcase@1.2.1
[INFO] β”‚ β”‚   β”œβ”€β”¬ cliui@2.1.0
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”¬ center-align@0.1.3
[INFO] β”‚ β”‚   β”‚ β”‚ β”œβ”€β”¬ align-text@0.1.4
[INFO] β”‚ β”‚   β”‚ β”‚ β”‚ β”œβ”€β”€ longest@1.0.1
[INFO] β”‚ β”‚   β”‚ β”‚ β”‚ └── repeat-string@1.6.1
[INFO] β”‚ β”‚   β”‚ β”‚ └── lazy-cache@1.0.4
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”€ right-align@0.1.3
[INFO] β”‚ β”‚   β”‚ └── wordwrap@0.0.2
[INFO] β”‚ β”‚   └── window-size@0.1.0
[INFO] β”‚ β”œβ”€β”€ watchpack@1.3.1
[INFO] β”‚ β”œβ”€β”¬ webpack-sources@0.2.3
[INFO] β”‚ β”‚ └── source-list-map@1.1.1
[INFO] β”‚ └─┬ yargs@6.6.0
[INFO] β”‚   β”œβ”€β”€ camelcase@3.0.0
[INFO] β”‚   β”œβ”€β”¬ cliui@3.2.0
[INFO] β”‚   β”‚ └── wrap-ansi@2.1.0
[INFO] β”‚   β”œβ”€β”€ get-caller-file@1.0.2
[INFO] β”‚   β”œβ”€β”¬ os-locale@1.4.0
[INFO] β”‚   β”‚ └─┬ lcid@1.0.0
[INFO] β”‚   β”‚   └── invert-kv@1.0.0
[INFO] β”‚   β”œβ”€β”¬ read-pkg-up@1.0.1
[INFO] β”‚   β”‚ └─┬ read-pkg@1.1.0
[INFO] β”‚   β”‚   β”œβ”€β”¬ load-json-file@1.1.0
[INFO] β”‚   β”‚   β”‚ β”œβ”€β”¬ parse-json@2.2.0
[INFO] β”‚   β”‚   β”‚ β”‚ └─┬ error-ex@1.3.1
[INFO] β”‚   β”‚   β”‚ β”‚   └── is-arrayish@0.2.1
[INFO] β”‚   β”‚   β”‚ └─┬ strip-bom@2.0.0
[INFO] β”‚   β”‚   β”‚   └── is-utf8@0.2.1
[INFO] β”‚   β”‚   β”œβ”€β”¬ normalize-package-data@2.3.8
[INFO] β”‚   β”‚   β”‚ β”œβ”€β”€ hosted-git-info@2.4.2
[INFO] β”‚   β”‚   β”‚ β”œβ”€β”€ is-builtin-module@1.0.0
[INFO] β”‚   β”‚   β”‚ └─┬ validate-npm-package-license@3.0.1
[INFO] β”‚   β”‚   β”‚   β”œβ”€β”¬ spdx-correct@1.0.2
[INFO] β”‚   β”‚   β”‚   β”‚ └── spdx-license-ids@1.2.2
[INFO] β”‚   β”‚   β”‚   └── spdx-expression-parse@1.0.4
[INFO] β”‚   β”‚   └── path-type@1.1.0
[INFO] β”‚   β”œβ”€β”€ require-directory@2.1.1
[INFO] β”‚   β”œβ”€β”€ require-main-filename@1.0.1
[INFO] β”‚   β”œβ”€β”€ set-blocking@2.0.0
[INFO] β”‚   β”œβ”€β”€ which-module@1.0.0
[INFO] β”‚   β”œβ”€β”€ y18n@3.2.1
[INFO] β”‚   └─┬ yargs-parser@4.2.1
[INFO] β”‚     └── camelcase@3.0.0
[INFO] β”œβ”€β”¬ webpack-dev-server@2.4.5
[INFO] β”‚ β”œβ”€β”€ ansi-html@0.0.7
[INFO] β”‚ β”œβ”€β”¬ compression@1.6.2
[INFO] β”‚ β”‚ β”œβ”€β”¬ accepts@1.3.3
[INFO] β”‚ β”‚ β”‚ └── negotiator@0.6.1
[INFO] β”‚ β”‚ β”œβ”€β”€ bytes@2.3.0
[INFO] β”‚ β”‚ β”œβ”€β”€ compressible@2.0.10
[INFO] β”‚ β”‚ β”œβ”€β”€ on-headers@1.0.1
[INFO] β”‚ β”‚ └── vary@1.1.1
[INFO] β”‚ β”œβ”€β”€ connect-history-api-fallback@1.3.0
[INFO] β”‚ β”œβ”€β”¬ express@4.15.2
[INFO] β”‚ β”‚ β”œβ”€β”€ array-flatten@1.1.1
[INFO] β”‚ β”‚ β”œβ”€β”€ content-disposition@0.5.2
[INFO] β”‚ β”‚ β”œβ”€β”€ cookie@0.3.1
[INFO] β”‚ β”‚ β”œβ”€β”€ cookie-signature@1.0.6
[INFO] β”‚ β”‚ β”œβ”€β”€ encodeurl@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ escape-html@1.0.3
[INFO] β”‚ β”‚ β”œβ”€β”€ etag@1.8.0
[INFO] β”‚ β”‚ β”œβ”€β”€ fresh@0.5.0
[INFO] β”‚ β”‚ β”œβ”€β”€ merge-descriptors@1.0.1
[INFO] β”‚ β”‚ β”œβ”€β”€ path-to-regexp@0.1.7
[INFO] β”‚ β”‚ β”œβ”€β”¬ proxy-addr@1.1.4
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ forwarded@0.1.0
[INFO] β”‚ β”‚ β”‚ └── ipaddr.js@1.3.0
[INFO] β”‚ β”‚ β”œβ”€β”¬ send@0.15.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ debug@2.6.1
[INFO] β”‚ β”‚ β”‚ β”œβ”€β”€ destroy@1.0.4
[INFO] β”‚ β”‚ β”œβ”€β”€ serve-static@1.12.1
[INFO] β”‚ β”‚ β”œβ”€β”€ setprototypeof@1.0.3
[INFO] β”‚ β”‚ └── statuses@1.3.1
[INFO] β”‚ β”œβ”€β”€ html-entities@1.2.1
[INFO] β”‚ β”œβ”€β”¬ http-proxy-middleware@0.17.4
[INFO] β”‚ β”‚ β”œβ”€β”¬ is-glob@3.1.0
[INFO] β”‚ β”‚ β”‚ └── is-extglob@2.1.1
[INFO] β”‚ β”‚ └─┬ micromatch@2.3.11
[INFO] β”‚ β”‚   β”œβ”€β”¬ arr-diff@2.0.0
[INFO] β”‚ β”‚   β”‚ └── arr-flatten@1.0.3
[INFO] β”‚ β”‚   β”œβ”€β”¬ braces@1.8.5
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”¬ expand-range@1.8.2
[INFO] β”‚ β”‚   β”‚ β”‚ └─┬ fill-range@2.2.3
[INFO] β”‚ β”‚   β”‚ β”‚   β”œβ”€β”€ is-number@2.1.0
[INFO] β”‚ β”‚   β”‚ β”‚   β”œβ”€β”€ isobject@2.1.0
[INFO] β”‚ β”‚   β”‚ β”‚   └── randomatic@1.1.6
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”€ preserve@0.2.0
[INFO] β”‚ β”‚   β”‚ └── repeat-element@1.1.2
[INFO] β”‚ β”‚   β”œβ”€β”¬ expand-brackets@0.1.5
[INFO] β”‚ β”‚   β”‚ └── is-posix-bracket@0.1.1
[INFO] β”‚ β”‚   β”œβ”€β”€ extglob@0.3.2
[INFO] β”‚ β”‚   β”œβ”€β”€ filename-regex@2.0.1
[INFO] β”‚ β”‚   β”œβ”€β”€ kind-of@3.2.0
[INFO] β”‚ β”‚   β”œβ”€β”¬ normalize-path@2.1.1
[INFO] β”‚ β”‚   β”‚ └── remove-trailing-separator@1.0.1
[INFO] β”‚ β”‚   β”œβ”€β”¬ object.omit@2.0.1
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”¬ for-own@0.1.5
[INFO] β”‚ β”‚   β”‚ β”‚ └── for-in@1.0.2
[INFO] β”‚ β”‚   β”‚ └── is-extendable@0.1.1
[INFO] β”‚ β”‚   β”œβ”€β”¬ parse-glob@3.0.4
[INFO] β”‚ β”‚   β”‚ β”œβ”€β”€ glob-base@0.3.0
[INFO] β”‚ β”‚   β”‚ └── is-dotfile@1.0.2
[INFO] β”‚ β”‚   └─┬ regex-cache@0.4.3
[INFO] β”‚ β”‚     β”œβ”€β”€ is-equal-shallow@0.1.3
[INFO] β”‚ β”‚     └── is-primitive@2.0.0
[INFO] β”‚ β”œβ”€β”€ opn@4.0.2
[INFO] β”‚ β”œβ”€β”¬ portfinder@1.0.13
[INFO] β”‚ β”‚ └── async@1.5.2
[INFO] β”‚ β”œβ”€β”¬ serve-index@1.8.0
[INFO] β”‚ β”‚ β”œβ”€β”€ batch@0.5.3
[INFO] β”‚ β”‚ └─┬ http-errors@1.5.1
[INFO] β”‚ β”‚   └── setprototypeof@1.0.2
[INFO] β”‚ β”œβ”€β”¬ sockjs@0.3.18
[INFO] β”‚ β”‚ └── faye-websocket@0.10.0
[INFO] β”‚ β”œβ”€β”€ sockjs-client@1.1.2
[INFO] β”‚ β”œβ”€β”¬ spdy@3.4.4
[INFO] β”‚ β”‚ β”œβ”€β”€ handle-thing@1.2.5
[INFO] β”‚ β”‚ β”œβ”€β”€ http-deceiver@1.2.7
[INFO] β”‚ β”‚ β”œβ”€β”€ select-hose@2.0.0
[INFO] β”‚ β”‚ └─┬ spdy-transport@2.0.18
[INFO] β”‚ β”‚   β”œβ”€β”€ hpack.js@2.1.6
[INFO] β”‚ β”‚   β”œβ”€β”€ obuf@1.1.1
[INFO] β”‚ β”‚   └─┬ wbuf@1.7.2
[INFO] β”‚ β”‚     └── minimalistic-assert@1.0.0
[INFO] β”‚ β”œβ”€β”€ strip-ansi@3.0.1
[INFO] β”‚ β”œβ”€β”€ supports-color@3.2.3
[INFO] β”‚   └── cliui@3.2.0
[INFO] └─┬ webpack-merge@0.20.0
[INFO]   β”œβ”€β”¬ lodash.find@3.2.1
[INFO]   β”‚ β”œβ”€β”¬ lodash._basecallback@3.3.1
[INFO]   β”‚ β”‚ β”œβ”€β”€ lodash._baseisequal@3.0.7
[INFO]   β”‚ β”‚ β”œβ”€β”€ lodash._bindcallback@3.0.1
[INFO]   β”‚ β”‚ └── lodash.pairs@3.0.1
[INFO]   β”‚ β”œβ”€β”€ lodash._baseeach@3.0.4
[INFO]   β”‚ β”œβ”€β”€ lodash._basefind@3.0.0
[INFO]   β”‚ β”œβ”€β”€ lodash._basefindindex@3.6.0
[INFO]   β”‚ β”œβ”€β”€ lodash.isarray@3.0.4
[INFO]   β”‚ └── lodash.keys@3.1.2
[INFO]   β”œβ”€β”€ lodash.isfunction@3.0.8
[INFO]   β”œβ”€β”¬ lodash.isplainobject@3.2.0
[INFO]   β”‚ β”œβ”€β”€ lodash._basefor@3.0.3
[INFO]   β”‚ β”œβ”€β”€ lodash.isarguments@3.1.0
[INFO]   β”‚ └── lodash.keysin@3.0.8
[INFO]   └─┬ lodash.merge@3.3.2
[INFO]     β”œβ”€β”€ lodash._arraycopy@3.0.0
[INFO]     β”œβ”€β”€ lodash._arrayeach@3.0.0
[INFO]     β”œβ”€β”¬ lodash._createassigner@3.1.1
[INFO]     β”‚ β”œβ”€β”€ lodash._isiterateecall@3.0.9
[INFO]     β”‚ └── lodash.restparam@3.6.1
[INFO]     β”œβ”€β”€ lodash._getnative@3.9.1
[INFO]     β”œβ”€β”€ lodash.istypedarray@3.0.6
[INFO]     └─┬ lodash.toplainobject@3.0.0
[INFO]       └── lodash._basecopy@3.0.1
[INFO]
[INFO]
[INFO] --- frontend-maven-plugin:1.3:npm (npm run build) @ graylog2-server ---
[INFO] Running 'npm run build' in /home/ubuntu/graylog2-server/graylog2-web-interface
[INFO]
[INFO] > graylog-web-interface@2.3.0-SNAPSHOT build /home/ubuntu/graylog2-server/graylog2-web-interface
[INFO] > webpack -p --config webpack.vendor.js && webpack
[INFO]
[ERROR] Building vendor bundle.
[ERROR] clean-webpack-plugin: /home/ubuntu/graylog2-server/graylog2-web-interface/build/vendor.*.js has been removed.
[INFO] Hash: 49e33e6bd07cffa69162
[INFO] Version: webpack 2.4.1
[INFO] Time: 12926ms
[INFO]     Asset    Size  Chunks                    Chunk Names
[INFO] vendor.js  857 kB       0  [emitted]  [big]  vendor
[INFO]    [0] dll vendor 12 bytes {0} [built]
[INFO]    [1] ./~/react/react.js 56 bytes {0} [built]
[INFO]    [3] ./~/moment/moment.js 139 kB {0} [built]
[INFO]   [19] ./~/react-dom/index.js 63 bytes {0} [built]
[INFO]  [283] ./~/react-router/lib/index.js 2.38 kB {0} [built]
[INFO]  [336] ./~/react-addons-linked-state-mixin/index.js 55 bytes {0} [built]
[INFO]  [337] ./~/react-addons-pure-render-mixin/index.js 72 bytes {0} [built]
[INFO]  [484] ./~/react-router-bootstrap/lib/index.js 544 bytes {0} [built]
[INFO]  [582] ./~/reflux/src/index.js 299 bytes {0} [built]
[INFO]  [769] ./~/moment-timezone/index.js 114 bytes {0} [built]
[INFO]  [793] ./~/reflux-core/lib/index.js 2.98 kB {0} [built]
[INFO]  [798] ./~/jquery/dist/jquery.js 248 kB {0} [built]
[INFO]  [819] ./~/react-bootstrap/es/index.js 4.85 kB {0} [built]
[INFO]  [915] ./~/react-bootstrap/es/SplitButton.js 2.62 kB {0} [built]
[INFO]  [917] ./~/react-bootstrap/es/Tab.js 1.35 kB {0} [built]
[INFO]     + 584 hidden modules
[ERROR] Running in production mode
[ERROR] (node:15606) DeprecationWarning: loaderUtils.parseQuery() received a non-string value which can be problematic,
[ERROR] parseQuery() will be replaced with getOptions() in the next major version of loader-utils.
[ERROR] ts-loader: Using typescript@1.8.10 and /home/ubuntu/graylog2-server/graylog2-web-interface/tsconfig.json
[INFO] Hash: 46493bae3870c9a4d352
[INFO] Time: 109198ms
[INFO]             39.46493bae3870c9a4d352.js    7.12 kB      39  [emitted]
[INFO]              0.46493bae3870c9a4d352.js  287 bytes       0  [emitted]         LoginPage
[INFO]              1.46493bae3870c9a4d352.js  286 bytes       1  [emitted]         LoggedInPage
[INFO]              2.46493bae3870c9a4d352.js  287 bytes       2  [emitted]         LoadingPage
[INFO]              3.46493bae3870c9a4d352.js     470 kB       3  [emitted]  [big]
[INFO]              4.46493bae3870c9a4d352.js    61.2 kB       4  [emitted]
[INFO]              5.46493bae3870c9a4d352.js    50.8 kB       5  [emitted]
[INFO]              6.46493bae3870c9a4d352.js    52.3 kB       6  [emitted]
[INFO]              7.46493bae3870c9a4d352.js    51.9 kB       7  [emitted]
[INFO]              8.46493bae3870c9a4d352.js    66.9 kB       8  [emitted]
[INFO]              9.46493bae3870c9a4d352.js    66.7 kB       9  [emitted]
[INFO]             10.46493bae3870c9a4d352.js    36.7 kB      10  [emitted]
[INFO]             11.46493bae3870c9a4d352.js    37.7 kB      11  [emitted]
[INFO]             12.46493bae3870c9a4d352.js    36.6 kB      12  [emitted]
[INFO]             13.46493bae3870c9a4d352.js    34.2 kB      13  [emitted]
[INFO]             14.46493bae3870c9a4d352.js    40.3 kB      14  [emitted]
[INFO]             15.46493bae3870c9a4d352.js    36.6 kB      15  [emitted]
[INFO]             16.46493bae3870c9a4d352.js    35.1 kB      16  [emitted]
[INFO]             17.46493bae3870c9a4d352.js      30 kB      17  [emitted]
[INFO]             18.46493bae3870c9a4d352.js      44 kB      18  [emitted]
[INFO]             19.46493bae3870c9a4d352.js      24 kB      19  [emitted]
[INFO]             20.46493bae3870c9a4d352.js    31.1 kB      20  [emitted]
[INFO]             21.46493bae3870c9a4d352.js    30.3 kB      21  [emitted]
[INFO]             22.46493bae3870c9a4d352.js    21.5 kB      22  [emitted]
[INFO]             23.46493bae3870c9a4d352.js    32.2 kB      23  [emitted]
[INFO]             24.46493bae3870c9a4d352.js    30.3 kB      24  [emitted]
[INFO]             25.46493bae3870c9a4d352.js    23.9 kB      25  [emitted]
[INFO]             26.46493bae3870c9a4d352.js      30 kB      26  [emitted]
[INFO]             27.46493bae3870c9a4d352.js    30.3 kB      27  [emitted]
[INFO]             28.46493bae3870c9a4d352.js    13.2 kB      28  [emitted]
[INFO]             29.46493bae3870c9a4d352.js    14.3 kB      29  [emitted]
[INFO]             30.46493bae3870c9a4d352.js    9.19 kB      30  [emitted]
[INFO]             31.46493bae3870c9a4d352.js    18.2 kB      31  [emitted]
[INFO]             32.46493bae3870c9a4d352.js    13.4 kB      32  [emitted]
[INFO]             33.46493bae3870c9a4d352.js    13.5 kB      33  [emitted]
[INFO]             34.46493bae3870c9a4d352.js    11.2 kB      34  [emitted]
[INFO]             35.46493bae3870c9a4d352.js    19.1 kB      35  [emitted]
[INFO]             36.46493bae3870c9a4d352.js    11.7 kB      36  [emitted]
[INFO]             37.46493bae3870c9a4d352.js    3.79 kB      37  [emitted]
[INFO]             38.46493bae3870c9a4d352.js    6.99 kB      38  [emitted]
[INFO]   674f50d287a8c48dc19ba404d20fe713.eot     166 kB          [emitted]
[INFO]             40.46493bae3870c9a4d352.js    6.58 kB      40  [emitted]
[INFO]             41.46493bae3870c9a4d352.js    2.17 kB  41, 52  [emitted]
[INFO]             42.46493bae3870c9a4d352.js    6.81 kB      42  [emitted]
[INFO]             43.46493bae3870c9a4d352.js    10.6 kB      43  [emitted]
[INFO]             44.46493bae3870c9a4d352.js    2.78 kB      44  [emitted]
[INFO]             45.46493bae3870c9a4d352.js    3.07 kB      45  [emitted]
[INFO]             46.46493bae3870c9a4d352.js     1.7 kB      46  [emitted]
[INFO]             47.46493bae3870c9a4d352.js    1.22 kB      47  [emitted]
[INFO]             48.46493bae3870c9a4d352.js    1.73 kB      48  [emitted]
[INFO]             49.46493bae3870c9a4d352.js    1.85 kB      49  [emitted]
[INFO]             50.46493bae3870c9a4d352.js    4.89 kB      50  [emitted]
[INFO]             51.46493bae3870c9a4d352.js  966 bytes      51  [emitted]
[INFO]             52.46493bae3870c9a4d352.js    1.14 kB      52  [emitted]
[INFO]             53.46493bae3870c9a4d352.js  630 bytes      53  [emitted]
[INFO]            app.46493bae3870c9a4d352.js    1.55 MB      54  [emitted]  [big]  app
[INFO]       polyfill.46493bae3870c9a4d352.js    88.9 kB      55  [emitted]         polyfill
[INFO]          0.46493bae3870c9a4d352.js.map    2.41 kB       0  [emitted]         LoginPage
[INFO]          1.46493bae3870c9a4d352.js.map    2.42 kB       1  [emitted]         LoggedInPage
[INFO]          2.46493bae3870c9a4d352.js.map    2.42 kB       2  [emitted]         LoadingPage
[INFO]          3.46493bae3870c9a4d352.js.map    2.33 MB       3  [emitted]
[INFO]          4.46493bae3870c9a4d352.js.map     264 kB       4  [emitted]
[INFO]          5.46493bae3870c9a4d352.js.map     220 kB       5  [emitted]
[INFO]          6.46493bae3870c9a4d352.js.map     227 kB       6  [emitted]
[INFO]          7.46493bae3870c9a4d352.js.map     226 kB       7  [emitted]
[INFO]          8.46493bae3870c9a4d352.js.map     278 kB       8  [emitted]
[INFO]          9.46493bae3870c9a4d352.js.map     277 kB       9  [emitted]
[INFO]         10.46493bae3870c9a4d352.js.map     161 kB      10  [emitted]
[INFO]         11.46493bae3870c9a4d352.js.map     165 kB      11  [emitted]
[INFO]         12.46493bae3870c9a4d352.js.map     160 kB      12  [emitted]
[INFO]         13.46493bae3870c9a4d352.js.map     136 kB      13  [emitted]
[INFO]         14.46493bae3870c9a4d352.js.map     200 kB      14  [emitted]
[INFO]         15.46493bae3870c9a4d352.js.map     158 kB      15  [emitted]
[INFO]         16.46493bae3870c9a4d352.js.map     150 kB      16  [emitted]
[INFO]         17.46493bae3870c9a4d352.js.map     132 kB      17  [emitted]
[INFO]         18.46493bae3870c9a4d352.js.map     183 kB      18  [emitted]
[INFO]         19.46493bae3870c9a4d352.js.map     109 kB      19  [emitted]
[INFO]         20.46493bae3870c9a4d352.js.map     134 kB      20  [emitted]
[INFO]         21.46493bae3870c9a4d352.js.map     131 kB      21  [emitted]
[INFO]         22.46493bae3870c9a4d352.js.map    96.3 kB      22  [emitted]
[INFO]         23.46493bae3870c9a4d352.js.map     137 kB      23  [emitted]
[INFO]         24.46493bae3870c9a4d352.js.map     161 kB      24  [emitted]
[INFO]         25.46493bae3870c9a4d352.js.map     106 kB      25  [emitted]
[INFO]         26.46493bae3870c9a4d352.js.map     132 kB      26  [emitted]
[INFO]         27.46493bae3870c9a4d352.js.map     205 kB      27  [emitted]
[INFO]         28.46493bae3870c9a4d352.js.map    57.2 kB      28  [emitted]
[INFO]         29.46493bae3870c9a4d352.js.map    61.6 kB      29  [emitted]
[INFO]         30.46493bae3870c9a4d352.js.map    39.3 kB      30  [emitted]
[INFO]         31.46493bae3870c9a4d352.js.map    80.6 kB      31  [emitted]
[INFO]         32.46493bae3870c9a4d352.js.map    58.4 kB      32  [emitted]
[INFO]         33.46493bae3870c9a4d352.js.map    58.6 kB      33  [emitted]
[INFO]         34.46493bae3870c9a4d352.js.map    45.4 kB      34  [emitted]
[INFO]         35.46493bae3870c9a4d352.js.map    85.8 kB      35  [emitted]
[INFO]         36.46493bae3870c9a4d352.js.map    52.9 kB      36  [emitted]
[INFO]         37.46493bae3870c9a4d352.js.map    18.7 kB      37  [emitted]
[INFO]         38.46493bae3870c9a4d352.js.map    32.4 kB      38  [emitted]
[INFO]         39.46493bae3870c9a4d352.js.map    32.3 kB      39  [emitted]
[INFO]         40.46493bae3870c9a4d352.js.map    34.7 kB      40  [emitted]
[INFO]         41.46493bae3870c9a4d352.js.map    9.89 kB  41, 52  [emitted]
[INFO]         42.46493bae3870c9a4d352.js.map      31 kB      42  [emitted]
[INFO]         43.46493bae3870c9a4d352.js.map    46.3 kB      43  [emitted]
[INFO]         44.46493bae3870c9a4d352.js.map      13 kB      44  [emitted]
[INFO]         45.46493bae3870c9a4d352.js.map    15.3 kB      45  [emitted]
[INFO]         46.46493bae3870c9a4d352.js.map     7.9 kB      46  [emitted]
[INFO]         47.46493bae3870c9a4d352.js.map    5.59 kB      47  [emitted]
[INFO]         48.46493bae3870c9a4d352.js.map    8.82 kB      48  [emitted]
[INFO]         49.46493bae3870c9a4d352.js.map    9.26 kB      49  [emitted]
[INFO]         50.46493bae3870c9a4d352.js.map    25.1 kB      50  [emitted]
[INFO]         51.46493bae3870c9a4d352.js.map    4.28 kB      51  [emitted]
[INFO]         52.46493bae3870c9a4d352.js.map    5.29 kB      52  [emitted]
[INFO]         53.46493bae3870c9a4d352.js.map    3.35 kB      53  [emitted]
[INFO]        app.46493bae3870c9a4d352.js.map    9.28 MB      54  [emitted]         app
[INFO]   polyfill.46493bae3870c9a4d352.js.map     699 kB      55  [emitted]         polyfill
[INFO]                            favicon.png    1.62 kB          [emitted]
[INFO]                             index.html  404 bytes          [emitted]
[INFO]                            module.json  259 bytes          [emitted]
[INFO]    [1] delegated ./node_modules/reflux/src/index.js from dll-reference __vendor 42 bytes {54} [not cacheable] [built]
[INFO]    [2] delegated ./node_modules/react/react.js from dll-reference __vendor 42 bytes {54} [not cacheable] [built]
[INFO]   [34] delegated ./node_modules/react-dom/index.js from dll-reference __vendor 42 bytes {54} [not cacheable] [built]
[INFO]   [77] ./~/bluebird/js/browser/bluebird.js 179 kB {54} [built]
[INFO]  [253] ./src/routing/AppFacade.jsx 2.59 kB {54} [built]
[INFO]  [254] ./src/webpack-entry.js 703 bytes {54} [built]
[INFO]  [255] ./~/babel-polyfill/lib/index.js 833 bytes {55} [built]
[INFO]  [256] ./~/react-hot-loader/index.js 41 bytes {54} [built]
[INFO]  [350] ./src/index.jsx 1.51 kB {54} [built]
[INFO]  [821] ./~/regenerator-runtime/runtime.js 24.4 kB {55} [built]
[INFO]  [825] ./~/font-awesome/css/font-awesome.css 880 bytes {54} [built]
[INFO]  [826] ./~/toastr/toastr.less 925 bytes {54} [built]
[INFO]  [827] ./public/stylesheets/bootstrap-submenus.less 1.07 kB {54} [built]
[INFO]  [828] ./public/stylesheets/graylog2.less 1.04 kB {54} [built]
[INFO]  [864] multi babel-polyfill 28 bytes {55} [built]
[INFO]     + 1444 hidden modules
[INFO]
[INFO] ERROR in ./~/graylog-web-plugin/plugin.js
[INFO] Module not found: Error: Can't resolve './lib/PluginManifest' in '/home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/graylog-web-plugin'
[INFO]  @ ./~/graylog-web-plugin/plugin.js 2:18-49
[INFO]  @ ./src/routing/AppRouter.jsx
[INFO]  @ ./~/babel-loader/lib?{"cacheDirectory":"cache","extends":"/home/ubuntu/graylog2-server/graylog2-web-interface/.babelrc"}!./src/pages/LoggedInPage.jsx
[INFO]  @ ./~/react-proxy-loader!./~/babel-loader/lib?{"cacheDirectory":"cache","extends":"/home/ubuntu/graylog2-server/graylog2-web-interface/.babelrc"}!./src/pages/LoggedInPage.jsx
[INFO]  @ ./~/react-proxy-loader?name=LoggedInPage!./src/pages/LoggedInPage.jsx
[INFO]  @ ./src/routing/AppFacade.jsx
[INFO]  @ ./src/index.jsx
[INFO]
[INFO] Module not found: Error: Can't resolve './lib/PluginStore' in '/home/ubuntu/graylog2-server/graylog2-web-interface/node_modules/graylog-web-plugin'
[INFO]  @ ./~/graylog-web-plugin/plugin.js 3:15-43
[INFO] Child html-webpack-plugin for "index.html":
[INFO]        [0] ./~/lodash/lodash.js 540 kB {0} [built]
[INFO]        [1] ./~/html-webpack-plugin/lib/loader.js!./templates/index.html.template 1.48 kB {0} [built]
[INFO]        [2] (webpack)/buildin/global.js 509 bytes {0} [built]
[INFO]        [3] (webpack)/buildin/module.js 517 bytes {0} [built]
[INFO] Child html-webpack-plugin for "module.json":
[INFO]        [1] ./~/html-webpack-plugin/lib/loader.js!./templates/module.json.template 541 bytes {0} [built]
[ERROR]
[ERROR] npm ERR! Linux 4.4.0-71-generic
[ERROR] npm ERR! argv "/home/ubuntu/graylog2-server/graylog2-web-interface/node/node" "/home/ubuntu/graylog2-server/graylog2-web-interface/node/node_modules/npm/bin/npm-cli.js" "run" "build"
[ERROR] npm ERR! node v6.9.2
[ERROR] npm ERR! npm  v4.0.3
[ERROR] npm ERR! code ELIFECYCLE
[ERROR] npm ERR! graylog-web-interface@2.3.0-SNAPSHOT build: `webpack -p --config webpack.vendor.js && webpack`
[ERROR] npm ERR! Exit status 2
[ERROR] npm ERR!
[ERROR] npm ERR! Failed at the graylog-web-interface@2.3.0-SNAPSHOT build script 'webpack -p --config webpack.vendor.js && webpack'.
[ERROR] npm ERR! Make sure you have the latest version of node.js and npm installed.
[ERROR] npm ERR! If you do, this is most likely a problem with the graylog-web-interface package,
[ERROR] npm ERR! not with npm itself.
[ERROR] npm ERR! Tell the author that this fails on your system:
[ERROR] npm ERR!     webpack -p --config webpack.vendor.js && webpack
[ERROR] npm ERR! You can get information on how to open an issue for this project with:
[ERROR] npm ERR!     npm bugs graylog-web-interface
[ERROR] npm ERR! Or if that isn't available, you can get their info via:
[ERROR] npm ERR!     npm owner ls graylog-web-interface
[ERROR] npm ERR! There is likely additional logging output above.
[ERROR]
[ERROR] npm ERR! Please include the following file with any support request:
[ERROR] npm ERR!     /home/ubuntu/graylog2-server/graylog2-web-interface/npm-debug.log
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] Graylog Parent POM ................................. SUCCESS [  4.350 s]
[INFO] Graylog Project Parent POM ......................... SUCCESS [  2.056 s]
[INFO] AutoValue JavaBean extension ....................... SUCCESS [  6.704 s]
[INFO] Graylog ............................................ FAILURE [04:15 min]
[INFO] integration-tests .................................. SKIPPED
[INFO] Graylog Plugin Parent POM .......................... SKIPPED
[INFO] Graylog Plugin with Web support Parent POM ......... SKIPPED
[INFO] graylog-plugin-archetype ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 04:30 min
[INFO] Finished at: 2017-05-02T14:11:01+00:00
[INFO] Final Memory: 49M/303M
[ERROR] Failed to execute goal com.github.eirslett:frontend-maven-plugin:1.3:npm (npm run build) on project graylog2-server: Failed to run task: 'npm run build' failed. (error code 1) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :graylog2-server
Please use https://gist.github.com/ for long text snippets instead of splitting it up into multiple posts here.
Additionally, please use triple back-ticks to retain the formatting of text snippets in your posts:
TEXT
This will make it easier to read your text snippets.
Please remove the node_modules and node directories from the ./graylog2-web-interface subdirectory and also your ~/.npm directory.
The Maven build will automatically download and use the appropriate Node.js and npm versions.
Issue is still there …
Is there any dependance in this build?
Stephen
Hey Stephen,
the reason is that your build runs as root. npm refuses to perform script tasks when run as root, which is necessary for the graylog-web-plugin module to be transpiled properly. Please run your build as a non-privileged user.
Kind regards,
D.
