Graylog 3.0 Alpha Fail Compiled
Hello Dear,
does anyone try Graylog 3.0 Alpha version ?
How do i build it ? https://github.com/Graylog2/graylog2-server
I did this command mvn assembly:single
But i got errors
What is the exact command to build it ?
Because i need it if i want to re-build graylog2 also
Thank you guys
I would recommend using https://github.com/Graylog2/graylog-project
how do i create the tarball ?
so, i can dpkg -i in my server
and could i try the graylog v3.0 ?
I wanna see the UI and features
Thank you @jan for your time, best …
Only 3 possible Options. The 4. would be to compile Graylog yourself. The 5. use the OVA Image https://packages.graylog2.org/appliances/ova
