Hi there,
I was warned by an Active Directory administrator that in 03/2020, Microsoft will push a security update that will enforce new settings for LDAP access on Domain Controllers. We are using LDAP access on our AD DC as a source of Graylog users / groups.
The reference article at MS is : https://support.microsoft.com/en-us/help/4520412/2020-ldap-channel-binding-and-ldap-signing-requirement-for-windows
Will Graylog be able to to still connect to AD when the security settings will be enforced? As I’m currently using unencrypted trafic, I will first configure the use of SSL but will it be enough ?
he @sebpon
you might want to create a feature request over at github.
If the lib that is used for this part of Graylog supports this - Graylog will do it too, if not this will not work.
