Web interface does not open
Hi, I’m new here, I installed ubuntu server 18, all packages updated, I followed this manual for installation http://docs.graylog.org/en/3.0/pages/installation/os/ubuntu.html?highlight=ubuntu, all installation worked without problem, I made the settings of the files
server.conf
# GRAYLOG CONFIGURATION FILE
is_master = true
password_secret =8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
#root_username = admin
root_password_sha2 =8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
# Default is empty
#root_email = ""
#root_timezone = UTC
# HTTP settings
http_bind_address = 192.168.3.20:9000
#http_publish_uri = http://$http_bind_address/
#### External Graylog URI
#http_external_uri =
#http_enable_cors = false
#http_enable_gzip = false
#http_max_header_size = 8192
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_subject_prefix = [graylog]
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = true
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
elasticsearch.yml
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: graylog
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
#node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
#path.data: /path/to/data
# Path to log files:
#path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
#network.host: 192.168.0.1
# Set a custom port for HTTP:
http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.zen.ping.unicast.hosts: ["host1", "host2"]
# Prevent the "split brain" by configuring the majority of nodes (total number of master-eligible nodes / 2 + 1):
#discovery.zen.minimum_master_nodes: 3
# For more information, consult the zen discovery module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
status
  "cluster_name" : "graylog",
  "status" : "green",
  "timed_out" : false,
  "number_of_nodes" : 1,
  "number_of_data_nodes" : 1,
  "active_primary_shards" : 4,
  "active_shards" : 4,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
but so far I can not access the web interface, I do not know what I could have done wrong, if someone can give me some tips on what to do to solve it.
Att.
what does your Graylog server.log tell you? is Graylog running and starting?
I restart the service normally, no error messages, follow the last lines of the log
2019-01-07T14:32:09.889Z INFO  [LogManager] Loading logs.
2019-01-07T14:32:09.959Z INFO  [LogManager] Logs loading complete.
2019-01-07T14:32:09.960Z INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2019-01-07T14:32:09.981Z INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2019-01-07T14:32:10.010Z INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2019-01-07T14:32:10.086Z INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2019-01-07T14:32:10.134Z INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:9}] to localhost:27017
2019-01-07T14:32:10.145Z INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 6, 9]}, minWireVersion=0, maxWireVersion=6, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=6824341}
2019-01-07T14:32:10.173Z INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:10}] to localhost:27017
2019-01-07T14:32:10.722Z INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2019-01-07T14:32:10.724Z INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2019-01-07T14:32:10.814Z INFO  [JestClientFactory] Using custom ObjectMapper instance
2019-01-07T14:32:10.816Z INFO  [JestClientFactory] Node Discovery disabled...
2019-01-07T14:32:10.816Z INFO  [JestClientFactory] Idle connection reaping disabled...
2019-01-07T14:32:11.063Z INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2019-01-07T14:32:11.295Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-01-07T14:32:11.310Z INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2019-01-07T14:32:11.396Z INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:11}] to localhost:27017
2019-01-07T14:32:11.439Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-01-07T14:32:11.491Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-01-07T14:32:11.533Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-01-07T14:32:11.575Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-01-07T14:32:12.621Z INFO  [ServerBootstrap] Graylog server 3.0.0-beta.1+e94dc5a starting up
2019-01-07T14:32:12.622Z INFO  [ServerBootstrap] JRE: Oracle Corporation 1.8.0_191 on Linux 4.15.0-43-generic
2019-01-07T14:32:12.622Z INFO  [ServerBootstrap] Deployment: deb
2019-01-07T14:32:12.623Z INFO  [ServerBootstrap] OS: Ubuntu 18.04.1 LTS (bionic)
2019-01-07T14:32:12.623Z INFO  [ServerBootstrap] Arch: amd64
2019-01-07T14:32:12.872Z INFO  [PeriodicalsService] Starting 27 periodicals ...
2019-01-07T14:32:12.873Z INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2019-01-07T14:32:12.876Z INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2019-01-07T14:32:12.877Z INFO  [Periodicals] Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [60s].
2019-01-07T14:32:12.878Z INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2019-01-07T14:32:12.880Z INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2019-01-07T14:32:12.883Z INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2019-01-07T14:32:12.883Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2019-01-07T14:32:12.892Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2019-01-07T14:32:12.896Z INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2019-01-07T14:32:12.909Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2019-01-07T14:32:12.912Z INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2019-01-07T14:32:12.913Z INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:12}] to localhost:27017
2019-01-07T14:32:12.926Z INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2019-01-07T14:32:12.929Z INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2019-01-07T14:32:12.946Z INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:13}] to localhost:27017
2019-01-07T14:32:12.963Z INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2019-01-07T14:32:12.967Z INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2019-01-07T14:32:12.980Z INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2019-01-07T14:32:12.984Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2019-01-07T14:32:12.995Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2019-01-07T14:32:13.040Z INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2019-01-07T14:32:13.040Z INFO  [Periodicals] Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2019-01-07T14:32:13.040Z INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2019-01-07T14:32:13.062Z INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:14}] to localhost:27017
2019-01-07T14:32:13.063Z INFO  [connection] Opened connection [connectionId{localValue:7, serverValue:15}] to localhost:27017
2019-01-07T14:32:13.077Z INFO  [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2019-01-07T14:32:13.096Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2019-01-07T14:32:13.128Z INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2019-01-07T14:32:13.133Z INFO  [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2019-01-07T14:32:13.133Z INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2019-01-07T14:32:13.134Z INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2019-01-07T14:32:13.134Z INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2019-01-07T14:32:13.589Z INFO  [JerseyService] Enabling CORS for HTTP endpoint
2019-01-07T14:32:35.870Z INFO  [NetworkListener] Started listener bound to [192.168.3.20:9000]
2019-01-07T14:32:35.872Z INFO  [HttpServer] [HttpServer] Started.
2019-01-07T14:32:35.872Z INFO  [JerseyService] Started REST API at <192.168.3.20:9000>
2019-01-07T14:32:35.873Z INFO  [ServiceManagerListener] Services are healthy
2019-01-07T14:32:35.873Z INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2019-01-07T14:32:35.874Z INFO  [ServerBootstrap] Services started, startup times in ms: {OutputSetupService [RUNNING]=39, BufferSynchronizerService [RUNNING]=41, KafkaJournal [RUNNING]=50, InputSetupService [RUNNING]=171, EtagService [RUNNING]=209, ConfigurationEtagService [RUNNING]=210, StreamCacheService [RUNNING]=212, JournalReader [RUNNING]=214, LookupTableService [RUNNING]=252, PeriodicalsService [RUNNING]=319, JerseyService [RUNNING]=23034}
2019-01-07T14:32:35.881Z INFO  [ServerBootstrap] Graylog server up and running.
ps: I do not speak English, I’m using google translate, if my writing is consufas I can try to improve
Att.
according to your logfile you should be able to connect to:
http://192.168.3.20:9000
to get your Graylog Interface - you might want to describe what kind of error you get when you try to connect.
I try at http://192.168.3.20:9000/ and https://192.168.3.20:9000/
lowered I will post the print of the screens of the two attempts
http
https
Att.
HTTPS will only be available if you tell Graylog to run with TLS enabled and if you set up the required certificates.
The HTTP daemon is apparently up and running, else you wouldn’t get the Graylog screen with error. So part of Graylog is in fact running correctly. That’s good news :slight_smile:
Now, if you look at the error message, it clearly tells you what is wrong. You have not correctly configured the URL for the Graylog API. Graylog is looking for it at http://%2FAPI%2F. That’s not correct :wink:
The good thing is that the API does get started at the correct URL, from your error log:
Good morning, I do not know if I changed anything, but I looked at the configuration files and they are as I had previously sent, but today I got here and I called the server and it was working, I have no idea what it worked for, but it seems that everything is ok now, thank you for attention.
Att.
