Still working on graylog
This is a continuation of these posts:
So recently the logs were giving message related to out of memory so I tried upping both the Elasticsearch and the Graylog heap memory settings to 4GB. I rebooted the server this morning, but the Grayog web admin page is still unavailable. Configuration is in the links above.
Graylog server logs from this morning:
2022-05-04T03:30:56.753-04:00 INFO  [AbstractRotationStrategy] Deflector index <Default index set> (index set <graylog_270>) should be rotated, Pointing deflector to new index now!
2022-05-04T03:30:56.755-04:00 INFO  [MongoIndexSet] Cycling from <graylog_270> to <graylog_271>.
2022-05-04T03:30:56.755-04:00 INFO  [MongoIndexSet] Creating target index <graylog_271>.
2022-05-04T03:30:56.903-04:00 INFO  [Indices] Successfully created index template graylog-internal
2022-05-04T03:30:57.156-04:00 INFO  [MongoIndexSet] Waiting for allocation of index <graylog_271>.
2022-05-04T03:30:57.248-04:00 INFO  [MongoIndexSet] Index <graylog_271> has been successfully allocated.
2022-05-04T03:30:57.248-04:00 INFO  [MongoIndexSet] Pointing index alias <graylog_deflector> to new index <graylog_271>.
2022-05-04T03:30:57.286-04:00 INFO  [SystemJobManager] Submitted SystemJob <23742440-cb7c-11ec-86a9-0050568bf8e7> [org.graylog2.indexer.indices.jobs.SetIndexReadOnlyAndCalculateRangeJob]
2022-05-04T03:30:57.286-04:00 INFO  [MongoIndexSet] Successfully pointed index alias <graylog_deflector> to index <graylog_271>.
2022-05-04T03:31:27.309-04:00 INFO  [SetIndexReadOnlyJob] Flushing old index <graylog_270>.
2022-05-04T03:31:27.630-04:00 INFO  [SetIndexReadOnlyJob] Setting old index <graylog_270> to read-only.
2022-05-04T03:31:27.656-04:00 INFO  [SystemJobManager] Submitted SystemJob <358e8a80-cb7c-11ec-86a9-0050568bf8e7> [org.graylog2.indexer.indices.jobs.OptimizeIndexJob]
2022-05-04T03:31:27.671-04:00 INFO  [CreateNewSingleIndexRangeJob] Calculating ranges for index graylog_270.
2022-05-04T03:31:27.672-04:00 INFO  [OptimizeIndexJob] Optimizing index <graylog_270>.
2022-05-04T03:31:29.654-04:00 INFO  [MongoIndexRangeService] Calculated range of [graylog_270] in [1982ms].
2022-05-04T03:31:29.670-04:00 INFO  [CreateNewSingleIndexRangeJob] Created ranges for index graylog_270.
2022-05-04T03:31:29.681-04:00 INFO  [SystemJobManager] SystemJob <23742440-cb7c-11ec-86a9-0050568bf8e7> [org.graylog2.indexer.indices.jobs.SetIndexReadOnlyAndCalculateRangeJob] finished in 2394ms.
2022-05-04T03:33:44.969-04:00 INFO  [SystemJobManager] SystemJob <358e8a80-cb7c-11ec-86a9-0050568bf8e7> [org.graylog2.indexer.indices.jobs.OptimizeIndexJob] finished in 137312ms.
2022-05-04T03:35:26.814-04:00 INFO  [AbstractIndexCountBasedRetentionStrategy] Number of indices (21) higher than limit (20). Running retention for 1 indices.
2022-05-04T03:35:26.988-04:00 INFO  [AbstractIndexCountBasedRetentionStrategy] Running retention strategy [org.graylog2.indexer.retention.strategies.DeletionRetentionStrategy] for index <graylog_251>
2022-05-04T03:35:27.246-04:00 INFO  [DeletionRetentionStrategy] Finished index retention strategy [delete] for index <graylog_251> in 247ms.
2022-05-04T05:32:08.405-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0x961dbf2e, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:54339]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:32:38.492-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xccfc57da, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:55002]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:34:50.296-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xa6b916d7, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:57524]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:36:02.334-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0x0a4f1e4f, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:60046]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:36:20.296-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0x3799f3a2, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:63765]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:36:46.379-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xcd043d3e, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:49783]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:38:23.485-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xaa71240f, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:52629]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:39:37.171-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xa2726f67, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:56902]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:40:25.328-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0x9e7387bd, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:57839]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:40:31.344-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xe3cc594e, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:57875]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:40:42.563-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0x5eda44fd, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:57949]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:40:48.578-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xe5bcc0e8, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:57991]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:41:41.109-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xf9d10a6e, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:58702]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:42:12.642-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xdaf77839, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:59094]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T05:42:20.791-04:00 ERROR [AbstractTcpTransport] Error in Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] (channel [id: 0xda39ad9e, L:/<graylogserverIP>:1514 ! R:/<ScannerIP2>:59145]) (cause io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer)
2022-05-04T08:49:24.268-04:00 INFO  [Server] SIGNAL received. Shutting down.
2022-05-04T08:50:21.822-04:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 3.0.2 [org.graylog.aws.AWSPlugin]
2022-05-04T08:50:21.844-04:00 INFO  [CmdLineTool] Loaded plugin: Collector 3.0.2 [org.graylog.plugins.collector.CollectorPlugin]
2022-05-04T08:50:21.845-04:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 3.0.2 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-05-04T08:50:22.639-04:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms4g -Xmx4g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.truststore=/SSCLant/certs/cacerts.jks -Dlog4j2.formatMsgNoLookups=true -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2022-05-04T08:50:23.187-04:00 INFO  [Version] HV000001: Hibernate Validator 5.1.3.Final
2022-05-04T08:50:26.433-04:00 INFO  [InputBufferImpl] Message journal is enabled.
2022-05-04T08:50:26.481-04:00 INFO  [NodeId] Node ID: 9e804424-96fe-42c8-a79a-051fc7fb0963
2022-05-04T08:50:26.828-04:00 INFO  [LogManager] Loading logs.
2022-05-04T08:50:26.925-04:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000005922176614.index, deleting and rebuilding index...
2022-05-04T08:50:27.426-04:00 INFO  [LogManager] Logs loading complete.
2022-05-04T08:50:27.432-04:00 INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-05-04T08:50:27.481-04:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2022-05-04T08:50:27.532-04:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-05-04T08:50:27.621-04:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-05-04T08:50:27.954-04:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:1}] to localhost:27017
2022-05-04T08:50:27.969-04:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 9]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=12950285}
2022-05-04T08:50:28.098-04:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:2}] to localhost:27017
2022-05-04T08:50:29.056-04:00 INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2022-05-04T08:50:29.057-04:00 INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2022-05-04T08:50:29.314-04:00 INFO  [JestClientFactory] Using custom ObjectMapper instance
2022-05-04T08:50:29.315-04:00 INFO  [JestClientFactory] Node Discovery disabled...
2022-05-04T08:50:29.315-04:00 INFO  [JestClientFactory] Idle connection reaping disabled...
2022-05-04T08:50:29.558-04:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-05-04T08:50:32.763-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-05-04T08:50:32.807-04:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-05-04T08:50:32.906-04:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:3}] to localhost:27017
2022-05-04T08:50:34.497-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-05-04T08:50:36.228-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-05-04T08:50:38.074-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-05-04T08:50:39.597-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-05-04T08:50:40.324-04:00 INFO  [ServerBootstrap] Graylog server 3.0.2+1686930 starting up
2022-05-04T08:50:40.324-04:00 INFO  [ServerBootstrap] JRE: Red Hat, Inc. 1.8.0_282 on Linux 3.10.0-1160.15.2.el7.x86_64
2022-05-04T08:50:40.324-04:00 INFO  [ServerBootstrap] Deployment: rpm
2022-05-04T08:50:40.324-04:00 INFO  [ServerBootstrap] OS: CentOS Linux 7 (Core) (centos)
2022-05-04T08:50:40.325-04:00 INFO  [ServerBootstrap] Arch: amd64
2022-05-04T08:50:40.385-04:00 INFO  [PeriodicalsService] Starting 27 periodicals ...
2022-05-04T08:50:40.386-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2022-05-04T08:50:40.402-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2022-05-04T08:50:40.403-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [60s].
2022-05-04T08:50:40.416-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2022-05-04T08:50:40.418-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2022-05-04T08:50:40.426-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2022-05-04T08:50:40.427-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2022-05-04T08:50:40.428-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2022-05-04T08:50:40.428-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2022-05-04T08:50:40.446-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2022-05-04T08:50:40.446-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2022-05-04T08:50:40.447-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2022-05-04T08:50:40.448-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2022-05-04T08:50:40.449-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2022-05-04T08:50:40.449-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2022-05-04T08:50:40.449-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2022-05-04T08:50:40.454-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2022-05-04T08:50:40.471-04:00 INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2022-05-04T08:50:40.532-04:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:4}] to localhost:27017
2022-05-04T08:50:40.541-04:00 INFO  [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2022-05-04T08:50:40.541-04:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:5}] to localhost:27017
2022-05-04T08:50:40.541-04:00 INFO  [connection] Opened connection [connectionId{localValue:7, serverValue:7}] to localhost:27017
2022-05-04T08:50:40.541-04:00 INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:6}] to localhost:27017
2022-05-04T08:50:40.579-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2022-05-04T08:50:40.579-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2022-05-04T08:50:40.591-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2022-05-04T08:50:40.643-04:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (Could not connect to http://127.0.0.1:9200)
2022-05-04T08:50:40.643-04:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2022-05-04T08:50:40.649-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2022-05-04T08:50:40.661-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2022-05-04T08:50:40.661-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2022-05-04T08:50:40.662-04:00 INFO  [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2022-05-04T08:50:40.662-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2022-05-04T08:50:40.665-04:00 INFO  [IndexFieldTypePollerPeriodical] Cluster not connected yet, delaying index field type initialization until it is reachable.
2022-05-04T08:50:40.666-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2022-05-04T08:50:40.667-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2022-05-04T08:50:40.857-04:00 INFO  [V20161130141500_DefaultStreamRecalcIndexRanges] Cluster not connected yet, delaying migration until it is reachable.
2022-05-04T08:50:41.005-04:00 INFO  [JerseyService] Enabling CORS for HTTP endpoint
2022-05-04T08:50:55.468-04:00 INFO  [IndexRangesCleanupPeriodical] Skipping index range cleanup because the Elasticsearch cluster is unreachable or unhealthy
2022-05-04T08:51:05.742-04:00 INFO  [NetworkListener] Started listener bound to [<graylogserverFQDN>:9000]
2022-05-04T08:51:05.744-04:00 INFO  [HttpServer] [HttpServer] Started.
2022-05-04T08:51:05.744-04:00 INFO  [JerseyService] Started REST API at <<graylogserverFQDN>:9000>
2022-05-04T08:51:05.756-04:00 INFO  [ServiceManagerListener] Services are healthy
2022-05-04T08:51:05.757-04:00 INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2022-05-04T08:51:05.759-04:00 INFO  [ServerBootstrap] Services started, startup times in ms: {ConfigurationEtagService [RUNNING]=78, OutputSetupService [RUNNING]=80, EtagService [RUNNING]=80, JournalReader [RUNNING]=83, GracefulShutdownService [RUNNING]=84, InputSetupService [RUNNING]=87, BufferSynchronizerService [RUNNING]=167, KafkaJournal [RUNNING]=202, PeriodicalsService [RUNNING]=333, LookupTableService [RUNNING]=334, StreamCacheService [RUNNING]=376, JerseyService [RUNNING]=25379}
2022-05-04T08:51:05.900-04:00 INFO  [ServerBootstrap] Graylog server up and running.
2022-05-04T08:51:06.060-04:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5cf1398829fbc65472f9e760] is now STARTING
2022-05-04T08:51:06.082-04:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5cf13c1329fbc65472f9ea2a] is now STARTING
2022-05-04T08:51:06.139-04:00 INFO  [InputStateListener] Input [GELF TCP/5cf13a5629fbc65472f9e843] is now STARTING
2022-05-04T08:51:06.141-04:00 INFO  [InputStateListener] Input [Syslog UDP/5cf13c4629fbc65472f9ea68] is now STARTING
2022-05-04T08:51:06.173-04:00 INFO  [InputStateListener] Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] is now STARTING
2022-05-04T08:51:06.308-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=APC Logs, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x9dbb0a63, L:/0.0.0.0:12201]) should be 262144 but is 425984.
2022-05-04T08:51:06.310-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=FirePOWER, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0xca27645b, L:/0.0.0.0:5140]) should be 262144 but is 425984.
2022-05-04T08:51:06.444-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=Firewall, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0xb9fe2c0d, L:/0.0.0.0:1514]) should be 262144 but is 425984.
2022-05-04T08:51:06.617-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=FirePOWER, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x885ce160, L:/0.0.0.0:5140]) should be 262144 but is 425984.
2022-05-04T08:51:06.617-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=APC Logs, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x0a6ab708, L:/0.0.0.0:12201]) should be 262144 but is 425984.
2022-05-04T08:51:06.809-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=Firewall, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x81e834c8, L:/0.0.0.0:1514]) should be 262144 but is 425984.
2022-05-04T08:51:06.811-04:00 WARN  [AbstractTcpTransport] receiveBufferSize (SO_RCVBUF) for input GELFTCPInput{title=Windows Event Logs, type=org.graylog2.inputs.gelf.tcp.GELFTCPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x9dcccd31, L:/0.0.0.0:12201]) should be 1048576 but is 425984.
2022-05-04T08:51:06.814-04:00 INFO  [InputStateListener] Input [GELF TCP/5cf13a5629fbc65472f9e843] is now RUNNING
2022-05-04T08:51:06.896-04:00 WARN  [AbstractTcpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogTCPInput{title=COC Infrastructure, type=org.graylog2.inputs.syslog.tcp.SyslogTCPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x62c7633f, L:/0.0.0.0:1514]) should be 1048576 but is 425984.
2022-05-04T08:51:06.897-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=FirePOWER, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x54e777c3, L:/0.0.0.0:5140]) should be 262144 but is 425984.
2022-05-04T08:51:06.899-04:00 INFO  [InputStateListener] Input [Syslog TCP/5cf13c2e29fbc65472f9ea4a] is now RUNNING
2022-05-04T08:51:06.922-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=APC Logs, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x96babe6d, L:/0.0.0.0:12201]) should be 262144 but is 425984.
2022-05-04T08:51:06.925-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=Firewall, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0xf426d4d2, L:/0.0.0.0:1514]) should be 262144 but is 425984.
2022-05-04T08:51:06.973-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=FirePOWER, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x5c907757, L:/0.0.0.0:5140]) should be 262144 but is 425984.
2022-05-04T08:51:06.978-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=Firewall, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0x5ccdc445, L:/0.0.0.0:1514]) should be 262144 but is 425984.
2022-05-04T08:51:06.979-04:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=APC Logs, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=9e804424-96fe-42c8-a79a-051fc7fb0963} (channel [id: 0xbedaf1ce, L:/0.0.0.0:12201]) should be 262144 but is 425984.
2022-05-04T08:51:06.999-04:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5cf13c1329fbc65472f9ea2a] is now RUNNING
2022-05-04T08:51:07.003-04:00 INFO  [InputStateListener] Input [Syslog UDP/5cf13c4629fbc65472f9ea68] is now RUNNING
2022-05-04T08:51:07.004-04:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5cf1398829fbc65472f9e760] is now RUNNING
So at this point, just trying to get the graylog web admin page up and running.
You have a lot going on, I realize your fairly new to this software. What I can do is break it down from the logs that are shown above.
This error below shows that something is wrong with your INPUT “Syslog.TCP/5cf13c2e29fbc65472f9ea4a”.
  • So how did you configure this input and what have you done to resolve this issue?
This Warning below shows there was something wrong with your index and graylog tried to correct it. I personally would use Curl commands from the other post/s to see if you shards are good.
  • I realize it is a tedious task, But could you show your current configurations and versions here?
This error below shows that Graylog could not connect to elasticsearch.
  • Could you show how you configured your indices and configuration to Elasticsearch?
What I noticed was this in the logs, It seams that all the input are running. I’m assuming this was a restart of the node or services on Graylog. Sometimes these errors occur because the incorrect service was start first. Example: Elasticsearch and MongoDb should be running before Graylog.
If your using certificates I would fall back to just using http to see if that is the problem.
Start small and work you way up is the best way to troubleshoot major issues with multiple problems.
These issue/s could be multiple things gone wrong. For example configuration between MongoDb , Elasticsearch and Graylog. Something is preventing Graylog from connecting to Elasticsearch. Using certificates that are incorrect or not configured properly with Graylog. The certification issue is a major problem I have seen here. 9 /10 times when members use certificates and have issues it because of that.
I did not configure the input. I am picking up someone else’s work. The graylog web admin page is down, so I do not know how to reconfigure the input without getting into the web admin page.
Feb 8
  • OS Information:
    Sidecars are on Windows. Graylog server is on CentOS7.
  • Package Version:
    graylog-server-3.0.2-1.noarch
    elasticsearch-6.8.0-1.noarch
    mongodb-org-tools-4.0.9-1.el7.x86_64
    monbodb-org-server-4.0.9-1.el7.x86_64
    mongodb-org-mongos-4.0.9-1.el7.x86_64
    mongodb-org-shell-4.0.9-1.el7.x86_64
# GRAYLOG CONFIGURATION FILE
# (deleted initial explanatory part of file)
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = <removed secret>
root_username = root
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = <removed password>
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = <removed http_bind_address>
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
http_publish_uri = <removed URI>
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri =
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
http_enable_tls = true
http_tls_cert_file = <removed cert file location>
http_tls_key_file = <removed key location>
# The password to unlock the private key used for securing the HTTP interface.
http_tls_key_password = <removed password>
# requires authentication.
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
mongodb_uri = mongodb://mongo_admin:<removed connection string>
# '+'-signs in the username or password need to be replaced by '%2B'
mongodb_uri = mongodb://mongo_admin:<removed>
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
transport_email_hostname = <removed>
transport_email_port = 25
#transport_email_auth_username =
#transport_email_auth_password =
transport_email_from_email = <removed>
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
transport_email_use_tls = false
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
transport_email_web_interface_url = <removed>
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
When you try to login the Web UI. what error/s are you seeing that’s preventing you from logging into the Web interface? I don’t see any information shown here that’s preventing a user from logging in to this Graylog instance.
What Have you tried to do so far to correct this issue?
For example what I stated earlier.
What is the status of Elasticsearch, Graylog & MongoDb?
Are you tail’ing your Graylog file when trying to logging the Web interface? if so, what do you see?
Normally if there is a issue with logging into the Web interface this will be shown in Graylog log file.
I found something here in you configuration file that does not seem correct. Only one should be configured, not three. If you using a user name and password on MongoDb make sure the credentials match for the user you add to MongoDb. If you did not create a user/password for MongoDb then I would just leave it as default
Example
mongodb_uri = mongodb://mongo_admin:some_password@localhost:27017/graylog
OR
mongodb_uri = mongodb://localhost:27017/graylog
EDIT:
I’m not sure if your HTTPS configuration is correct but here is mine, Please noticed the little details.
My certificates match my FQDN, so I matched my setting to correspond to those certs.
http_bind_address = graylog.domain.com:9000  <--- You can use an IP Address, I just prefer FQDN
http_publish_uri = https://graylog.domain.com:9000/  <--  HTTPS & FQDN or IPADDRESS
http_enable_cors = true
http_tls_cert_file = /etc/graylog-server/graylog-certificate.pem
http_tls_key_file = /etc/graylog-server/graylog/graylog-key.pem
I cannot fall back to using http, the certs have to stay in place.
Nothing at all happens in the graylog log file. It is not possible to get to the graylog web interface to log in. The browser says this site cannot be reached. This same thing happens whether you try to go to the graylog FQDN from another vm on the net or from the graylog server itself. The connection times out.
I think before I start changing those settings it would be good to be able to log into the web interface, correct? I prefer to try to focus on solving one problem at a time.
Number one cause of that error would be If the certificates are incorrect and the wrong certificate is inserted in the Keystore or it could be both.
It is possible you can get that same error with the following:
  1. Firewall is incorrect or enable.
  2. DNS server or /etc/hosts file is incorrect.
  3. Selinux/Apparmor is enable or configured incorrect
  4. External firewall Cisco/Fortinet could be blocking you FQDN/IP address. ( sometimes ACL’s are in place)
  5. Graylog configuration file is Incorrect
  6. Permission issues on files and directories ( i.e. Graylog is unable to access files it needs)
Out of curiosity can you PING you Graylog servers ( FDQN) from another node inside this environment?
I can ping both the IP and the FQDN from another node inside the environment (as of today).
Sorry for the late response , To be honest not sure, I gave you all the suggestion I know on how to fix this issue. From my over all observation you have a lot of configuration that are incorrect. So basically if there are incorrect configurations your server would run for a few and then crash.
The point is…
TOP Things to look at are…
1.Graylog Service
2.Firewall
3.Permission
4.Certificates (Since you stated you can make configuration to HTTPS not sure what to tell you on check those)
5.Configurations and/or Resources
