Graylog server up and running but web-interface not showing up
I am new to Graylog, I am installing graylog 2 on centos 7, and I couldn’t get graylog2 web interface showing up in my browser.
For the graylog 2 log file, if I restart graylog server I got this:
[y.xiang@NJ-GL2 graylog-server]$ sudo tail -f /var/log/graylog-server/server.log
2017-06-16T11:38:05.913-04:00 INFO  [NetworkListener] Started listener bound to [10.10.60.122:12900]
2017-06-16T11:38:05.914-04:00 INFO  [HttpServer] [HttpServer] Started.
2017-06-16T11:38:05.915-04:00 INFO  [JerseyService] Started REST API at  http: //10.10.60.122:12900/
2017-06-16T11:38:08.442-04:00 INFO  [NetworkListener] Started listener bound to [10.10.60.122:9000]
2017-06-16T11:38:08.442-04:00 INFO  [HttpServer] [HttpServer-1] Started.
2017-06-16T11:38:08.443-04:00 INFO  [JerseyService] Started Web Interface at http: //10.10.60.122:9000/>
2017-06-16T11:38:08.443-04:00 INFO  [ServiceManagerListener] Services are healthy
2017-06-16T11:38:08.444-04:00 INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2017-06-16T11:38:08.445-04:00 INFO  [ServerBootstrap] Services started, startup times in ms: {OutputSetupService [RUNNING]=3, BufferSynchronizerService [RUNNING]=5, KafkaJournal [RUNNING]=8, JournalReader [RUNNING]=8, InputSetupService [RUNNING]=8, ConfigurationEtagService [RUNNING]=12, StreamCacheService [RUNNING]=39, PeriodicalsService [RUNNING]=73, IndexerSetupService [RUNNING]=3230, JerseyService [RUNNING]=13343}
2017-06-16T11:38:08.452-04:00 INFO  [ServerBootstrap] Graylog server up and running.
^C[y.xiang@NJ-GL2 graylog-server]$ clear
2017-06-16T11:40:37.482-04:00 INFO  [Server] SIGNAL received. Shutting down.
2017-06-16T11:40:37.485-04:00 INFO  [GracefulShutdown] Graceful shutdown initiated.
2017-06-16T11:40:37.485-04:00 INFO  [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2017-06-16T11:40:41.492-04:00 INFO  [Buffers] Waiting until all buffers are empty.
2017-06-16T11:40:41.494-04:00 INFO  [Buffers] All buffers are empty. Continuing.
2017-06-16T11:40:41.494-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] stopping ...
2017-06-16T11:40:41.494-04:00 INFO  [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
2017-06-16T11:40:41.495-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.AlertScannerThread].
2017-06-16T11:40:41.495-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.AlertScannerThread] complete, took <0ms>.
2017-06-16T11:40:41.496-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread].
2017-06-16T11:40:41.496-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] complete, took <0ms>.
2017-06-16T11:40:41.496-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ClusterHealthCheckThread].
2017-06-16T11:40:41.496-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ClusterHealthCheckThread] complete, took <0ms>.
2017-06-16T11:40:41.496-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexerClusterCheckerThread].
2017-06-16T11:40:41.496-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexerClusterCheckerThread] complete, took <0ms>.
2017-06-16T11:40:41.496-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRetentionThread].
2017-06-16T11:40:41.497-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRetentionThread] complete, took <0ms>.
2017-06-16T11:40:41.497-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRotationThread].
2017-06-16T11:40:41.497-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRotationThread] complete, took <0ms>.
2017-06-16T11:40:41.497-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.VersionCheckThread].
2017-06-16T11:40:41.497-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.VersionCheckThread] complete, took <0ms>.
2017-06-16T11:40:41.497-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ThrottleStateUpdaterThread].
2017-06-16T11:40:41.497-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ThrottleStateUpdaterThread] complete, took <0ms>.
2017-06-16T11:40:41.498-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
2017-06-16T11:40:41.498-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventPeriodical] complete, took <0ms>.
2017-06-16T11:40:41.498-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
2017-06-16T11:40:41.501-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventCleanupPeriodical] complete, took <0ms>.
2017-06-16T11:40:41.502-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical].
2017-06-16T11:40:41.502-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical] complete, took <0ms>.
2017-06-16T11:40:41.502-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical].
2017-06-16T11:40:41.503-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical] complete, took <0ms>.
2017-06-16T11:40:41.504-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical].
2017-06-16T11:40:41.505-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical] complete, took <0ms>.
2017-06-16T11:40:41.505-04:00 INFO  [PeriodicalsService] Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
2017-06-16T11:40:41.506-04:00 INFO  [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] complete, took <0ms>.
2017-06-16T11:40:41.509-04:00 INFO  [GracefulShutdown] Goodbye.
2017-06-16T11:40:41.510-04:00 INFO  [JournalReader] Stopping.
2017-06-16T11:40:41.510-04:00 INFO  [JerseyService] Shutting down HTTP listener at http: //10.10.60.122:12900/>
2017-06-16T11:40:41.514-04:00 INFO  [LogManager] Shutting down.
2017-06-16T11:40:41.537-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] stopped
2017-06-16T11:40:41.537-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] closing ...
2017-06-16T11:40:41.550-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] closed
2017-06-16T11:40:41.561-04:00 INFO  [LogManager] Shutdown complete.
2017-06-16T11:40:41.576-04:00 INFO  [NetworkListener] Stopped listener bound to [10.10.60.122:12900]
2017-06-16T11:40:41.576-04:00 INFO  [JerseyService] Shutting down HTTP listener at http: //10.10.60.122:9000/>
2017-06-16T11:40:41.584-04:00 INFO  [NetworkListener] Stopped listener bound to [10.10.60.122:9000]
2017-06-16T11:40:41.585-04:00 INFO  [ServiceManagerListener] Services are now stopped.
2017-06-16T11:40:45.192-04:00 INFO  [CmdLineTool] Loaded plugin: Elastic Beats Input 2.2.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-06-16T11:40:45.194-04:00 INFO  [CmdLineTool] Loaded plugin: Collector 2.2.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-06-16T11:40:45.195-04:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.2.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-06-16T11:40:45.196-04:00 INFO  [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.2.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-06-16T11:40:45.207-04:00 INFO  [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.2.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-06-16T11:40:45.207-04:00 INFO  [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.2.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-06-16T11:40:45.479-04:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2017-06-16T11:40:45.725-04:00 INFO  [Version] HV000001: Hibernate Validator null
2017-06-16T11:40:48.209-04:00 INFO  [InputBufferImpl] Message journal is enabled.
2017-06-16T11:40:48.236-04:00 INFO  [NodeId] Node ID: c6740bc5-c488-48d8-ba71-3468825865dd
2017-06-16T11:40:48.476-04:00 INFO  [LogManager] Loading logs.
2017-06-16T11:40:48.537-04:00 INFO  [LogManager] Logs loading complete.
2017-06-16T11:40:48.537-04:00 INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2017-06-16T11:40:48.555-04:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2017-06-16T11:40:48.577-04:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2017-06-16T11:40:48.630-04:00 INFO  [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2017-06-16T11:40:48.651-04:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:277}] to localhost:27017
2017-06-16T11:40:48.653-04:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 2, 14]}, minWireVersion=0, maxWireVersion=4, maxDocumentSize=16777216, roundTripTimeNanos=580271}
2017-06-16T11:40:48.661-04:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:278}] to localhost:27017
2017-06-16T11:40:49.028-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] version[2.4.4], pid[4291], build[fcbb46d/2017-01-03T11:33:16Z]
2017-06-16T11:40:49.028-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] initializing ...
2017-06-16T11:40:49.035-04:00 INFO  [plugins] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] modules [], plugins [graylog-monitor], sites []
2017-06-16T11:40:50.709-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] initialized
2017-06-16T11:40:50.786-04:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2017-06-16T11:40:52.541-04:00 INFO  [RulesEngineProvider] No static rules file loaded.
2017-06-16T11:40:52.841-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-16T11:40:52.848-04:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2017-06-16T11:40:52.927-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-16T11:40:52.999-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-16T11:40:53.063-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-16T11:40:53.119-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-16T11:40:53.856-04:00 INFO  [ServerBootstrap] Graylog server 2.2.3+7adc951 starting up
2017-06-16T11:40:53.857-04:00 INFO  [ServerBootstrap] JRE: Oracle Corporation 1.8.0_131 on Linux 3.10.0-514.21.1.el7.x86_64
2017-06-16T11:40:53.857-04:00 INFO  [ServerBootstrap] Deployment: rpm
2017-06-16T11:40:53.857-04:00 INFO  [ServerBootstrap] OS: CentOS Linux 7 (Core) (centos)
2017-06-16T11:40:53.857-04:00 INFO  [ServerBootstrap] Arch: amd64
2017-06-16T11:40:53.861-04:00 WARN  [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2017-06-16T11:40:53.887-04:00 INFO  [PeriodicalsService] Starting 26 periodicals ...
2017-06-16T11:40:53.887-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2017-06-16T11:40:53.890-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [60s].
2017-06-16T11:40:53.895-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] starting ...
2017-06-16T11:40:53.895-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2017-06-16T11:40:53.898-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2017-06-16T11:40:53.899-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical, running forever.
2017-06-16T11:40:53.900-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2017-06-16T11:40:53.900-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2017-06-16T11:40:53.900-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2017-06-16T11:40:53.901-04:00 INFO  [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2017-06-16T11:40:53.901-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2017-06-16T11:40:53.902-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2017-06-16T11:40:53.902-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2017-06-16T11:40:53.903-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2017-06-16T11:40:53.903-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2017-06-16T11:40:53.904-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2017-06-16T11:40:53.904-04:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:279}] to localhost:27017
2017-06-16T11:40:53.907-04:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:281}] to localhost:27017
2017-06-16T11:40:53.907-04:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:280}] to localhost:27017
2017-06-16T11:40:53.911-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2017-06-16T11:40:53.912-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2017-06-16T11:40:53.912-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2017-06-16T11:40:53.914-04:00 INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:282}] to localhost:27017
2017-06-16T11:40:53.917-04:00 INFO  [connection] Opened connection [connectionId{localValue:7, serverValue:283}] to localhost:27017
2017-06-16T11:40:53.918-04:00 INFO  [connection] Opened connection [connectionId{localValue:9, serverValue:285}] to localhost:27017
2017-06-16T11:40:53.919-04:00 INFO  [connection] Opened connection [connectionId{localValue:8, serverValue:284}] to localhost:27017
2017-06-16T11:40:53.948-04:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2017-06-16T11:40:53.951-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2017-06-16T11:40:53.951-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2017-06-16T11:40:53.951-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2017-06-16T11:40:53.955-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2017-06-16T11:40:53.955-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2017-06-16T11:40:53.958-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical] periodical in [300s], polling every [21600s].
2017-06-16T11:40:53.958-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical] periodical in [300s], polling every [21600s].
2017-06-16T11:40:53.960-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2017-06-16T11:40:53.960-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2017-06-16T11:40:53.963-04:00 INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2017-06-16T11:40:54.007-04:00 INFO  [transport] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] publish_address {10.10.60.122:9350}, bound_addresses {10.10.60.122:9350}
2017-06-16T11:40:54.013-04:00 INFO  [discovery] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] graylog/JE25UuHKSRChj4qyRkPeBQ
2017-06-16T11:40:54.026-04:00 INFO  [V20161130141500_DefaultStreamRecalcIndexRanges] Cluster not connected yet, delaying migration until it is reachable.
2017-06-16T11:40:54.471-04:00 INFO  [JerseyService] Enabling CORS for HTTP endpoint
2017-06-16T11:40:57.017-04:00 WARN  [discovery] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] waited for 3s and no initial state was set by the discovery
2017-06-16T11:40:57.017-04:00 INFO  [node] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] started
2017-06-16T11:40:57.106-04:00 INFO  [service] [graylog-c6740bc5-c488-48d8-ba71-3468825865dd] detected_master {Remy LeBeau}{pdWGs9RzSPuxpf5LVSZytg}{127.0.0.1}{127.0.0.1:9300}, added {{Remy LeBeau}{pdWGs9RzSPuxpf5LVSZytg}{127.0.0.1}{127.0.0.1:9300},}, reason: zen-disco-receive(from master [{Remy LeBeau}{pdWGs9RzSPuxpf5LVSZytg}{127.0.0.1}{127.0.0.1:9300}])
2017-06-16T11:41:05.087-04:00 INFO  [NetworkListener] Started listener bound to [10.10.60.122:12900]
2017-06-16T11:41:05.089-04:00 INFO  [HttpServer] [HttpServer] Started.
2017-06-16T11:41:05.089-04:00 INFO  [JerseyService] Started REST API at http: //10.10.60.122:12900/>
2017-06-16T11:41:07.674-04:00 INFO  [NetworkListener] Started listener bound to [10.10.60.122:9000]
2017-06-16T11:41:07.674-04:00 INFO  [HttpServer] [HttpServer-1] Started.
2017-06-16T11:41:07.674-04:00 INFO  [JerseyService] Started Web Interface at http: //10.10.60.122:9000/>
2017-06-16T11:41:07.675-04:00 INFO  [ServiceManagerListener] Services are healthy
2017-06-16T11:41:07.676-04:00 INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2017-06-16T11:41:07.676-04:00 INFO  [ServerBootstrap] Services started, startup times in ms: {BufferSynchronizerService [RUNNING]=2, OutputSetupService [RUNNING]=3, JournalReader [RUNNING]=6, InputSetupService [RUNNING]=7, ConfigurationEtagService [RUNNING]=7, KafkaJournal [RUNNING]=16, StreamCacheService [RUNNING]=41, PeriodicalsService [RUNNING]=80, IndexerSetupService [RUNNING]=3229, JerseyService [RUNNING]=13789}
2017-06-16T11:41:07.684-04:00 INFO  [ServerBootstrap] Graylog server up and running.
The configuration for graylog is ;
rest_listen_uri = http:// 10.10.60.122:12900
web_listen_uri = http:// 10.10.60.122:9000/
elasticsearch_shards = 1
elasticsearch_replicas = 0
elasticsearch_cluster_name = graylog
elasticsearch_http_enabled = false
elasticsearch_network_host = 10.10.60.122
elasticsearch_network_bind_host = 10.10.60.122
(I changed the format of ip since new user is not allowed to put up more than 2 address)
Graylog Version:
graylog2
Elasticsearch Version:
2.4.5
MongoDB Version:
3.2.14
Operating System:
centos 7
Browser version:
chrome
Any help is appreciated !!
How are you trying to access the web interface?
What’s the output of the following commands:
$ curl -i http://10.10.60.122:9000/
$ curl -i -H 'Accept: application/json' http://10.10.60.122:12900/
You can circumvent this by properly formatting your text snippets:
Text
Thanks for your reply Jochen, I got Failed connect XXX Connection refused for both cases
Make sure that no packet filter or firewall is blocking access to these ports.
Hi Jochen, thank you so much for the reply, while I check this, do you mind answer my question posted here Graylog/elastic search ip address configuration files set up ? I am really confused about those uri set-ups.
Thanks a lot !!!
I restart the server and I got:
HTTP/1.1 200 OK
X-Graylog-Node-ID: db4bf93e-dd54-4864-aef6-d5cfc9d618fc
X-UA-Compatible: IE=edge
Content-Type: text/html
Date: Mon, 19 Jun 2017 13:55:49 GMT
Content-Length: 1290
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="robots" content="noindex, nofollow">
    <meta charset="UTF-8">
    <title>Graylog Web Interface</title>
    <link rel="shortcut icon" href="/assets/favicon.png">
  </head>
  <body>
    <script src="/config.js"></script>
    <script src="/assets/vendor.js"></script>
    <script src="/assets/polyfill.35e28e4da7743596569a.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.pipelineprocessor.ProcessorPlugin/plugin.org.graylog.plugins.pipelineprocessor.PipelineProcessorPlugin.0cbe11128085ed745b77.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.map.MapWidgetPlugin/plugin.org.graylog.plugins.map.MapWidgetPlugin.5011f2ebff35ef956f1b.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin/plugin.org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin.3e5ff59c400f972516bd.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.collector.CollectorPlugin/plugin.org.graylog.plugins.collector.CollectorPlugin.13edb0af11e27a17b001.js"></script>
    <script src="/assets/app.35e28e4da7743596569a.js"></script>
  </body>
</html>
Please post the output of both commands.
Additionally, please try to properly format your text snippets by using triple back ticks:
TEXT
So for command curl -i http://10.10.60.122:9000/ I got :
HTTP/1.1 200 OK
Date: Mon, 19 Jun 2017 14:16:14 GMT
<!DOCTYPE html>
<html>
  <head>
  </head>
  <body>
  </body>
</html>
For command curl -i -H ‘Accept: application/json’ http://10.10.60.122:12900/ I got:
curl: (7) Failed connect to 10.10.60.122:12900; Connection refused
Thanks !!
Well, the Graylog REST API on http://10.10.60.122:12900 isn’t running.
Either your configuration is wrong or there’s still some packet filter blocking access to that interface.
Hi Jochen, how can i check if there’s some packet filter blocking ? I disabled all firewalls and when I have this command:
sudo nmap -sT -O localhost
I got this:
Starting Nmap 6.40 ( http://nmap.org ) at 2017-06-19 11:15 EDT
Nmap scan report for localhost (127.0.0.1)
Host is up (0.00013s latency).
Other addresses for localhost (not scanned): 127.0.0.1
Not shown: 996 closed ports
PORT STATE SERVICE
22/tcp open ssh
25/tcp open smtp
631/tcp open ipp
9200/tcp open wap-wsp
Device type: general purpose
Running: Linux 3.X
OS CPE: cpe:/o:linux:linux_kernel:3
OS details: Linux 3.7 - 3.9
Network Distance: 0 hops
OS detection performed. Please report any incorrect results at http://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 2.10 seconds
Please contact the administrators of your server and/or the network administrators of your company for that.
As you can see from the output of your nmap run, neither port 9000/tcp nor 12900/tcp is open.
