Unable to access Graylog Web Interface - Ubuntu 18.04
Hello!
I am having an issue trying to access the Graylog web interface.
I am running on Ubuntu Server 18.04.2 LTS, and followed the instructions provided here: http://docs.graylog.org/en/3.0/pages/installation/os/ubuntu.html
I installed Elasticsearch, MongoDB, Java, Graylog, etc. according to the guide, and edited the config files as described.
When I try to access the web interface using http://<server_ip>:9000, I get an “err_connection_refused” error on Google Chrome on my Windows PC.
I am able to SSH into the Ubuntu server itself and ping the IP, so I’ve ruled any issues with that out. I think it may be an error on my end, as far as the config file.
I appriciate any assistance in advance! Thank you!
Here is my server.conf file, I would post the entire thing, but evidently it exceeds the body character limit for posting:
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = ubDMny9dg4njHGg3zTx8hGtGol7Ivpwmkyz21jcV9lkoF4tmmXfA1wTpsAyIR6YQo3swWjDPCPvrO8HAxmISfpOOwM0U9ofo
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = 80182643f7b964877bbe496f5abc1ac502a513ddb8415f9a2bf81760825a5983
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
#http_bind_address = http://127.0.0.1:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
#http_publish_uri = http://192.168.1.1:9000/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri =
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_subject_prefix = [graylog]
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = true
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
You should define http_publish_uri. Now it defaults to http_bind_address, which in turn defaults to local loopback address 127.0.0.1:9000 and is not accessible from other hosts.
Thank you! I changed the http_publish_uri and restarted the graylog-server service, and still no luck.
Here is the change I made:
http_publish_uri = http://10.13.37.107:9000/
Is there something else I need to do? Thanks!
Edit: I just rebooted, and tried to start graylog-server, and this is the output of systemctl status graylog-server:
graylog-server.service - Graylog server
Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2019-06-11 13:01:29 UTC; 1s ago
Docs: http://docs.graylog.org/
Process: 2625 ExecStart=/usr/share/graylog-server/bin/graylog-server (code=exited, status=1/FAILURE)
Main PID: 2625 (code=exited, status=1/FAILURE)
Jun 11 13:01:29 esslogs systemd[1]: graylog-server.service: Failed with result 'exit-code'.
This is the output of systemctl status elasticsearch:
sudo systemctl status elasticsearch
● elasticsearch.service - Elasticsearch
Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-06-11 12:52:43 UTC; 11min ago
Docs: http://www.elastic.co
Main PID: 995 (java)
Tasks: 38 (limit: 4915)
CGroup: /system.slice/elasticsearch.service
└─995 /usr/bin/java -Xms1g -Xmx1g -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitia
Jun 11 12:52:44 esslogs elasticsearch[995]: warning: Falling back to java on path. This behavior is deprecated. Specify JAVA
Jun 11 12:52:43 esslogs systemd[1]: Started Elasticsearch.
Jun 11 12:52:50 esslogs elasticsearch[995]: OpenJDK 64-Bit Server VM warning: Option UseConcMarkSweepGC was deprecated in ve
Jun 11 12:52:50 esslogs elasticsearch[995]: OpenJDK 64-Bit Server VM warning: UseAVX=2 is not supported on this CPU, setting
you should read what the different configuration settings are …
First, if you have # in the line at first sign - this line is not used because it is seen as a comment. Second http_bind_address is address and not uri - that is where Graylog is binding itseld too.
http_publish_uri is where Graylog can reach itself and other Graylog nodes in the Cluster could reach this node. http_external_uri is where your Browser can reach Graylog.
Read that the defaults are, read the comments above the settings.
