Unexpected Application Error after Upgrade from 6.0.7 to 6.1.1
After Upgrade from 6.0.7 to 6.1.1 i receive the following error message in the frontend (web browser) after logging in (hostname anonymized):
Unexpected Application Error!
useLicenseCheck must be used within a LicenseCheckProvider.
f@https[:]//hostname/graylog/assets/plugin/org.graylog.plugins.enterprise.EnterprisePlugin/plugin.org.graylog.plugins.enterprise.EnterprisePlugin.5d5bd6404c53801f96be.js:6875:3505
useCondition@https[:]//hostname/graylog/assets/plugin/org.graylog.plugins.enterprise.EnterprisePlugin/plugin.org.graylog.plugins.enterprise.EnterprisePlugin.5d5bd6404c53801f96be.js:3018:5847
6kKi+oxr/sn/Ye<@https[:]//hostname/graylog/assets/app.c27238c54d36f84fc206.js:5272:2662
sn@https[:]//hostname/graylog/assets/app.c27238c54d36f84fc206.js:5272:2630
Sa@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:690:20582
L_@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:692:45470
h_@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:692:41075
J_@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:692:41003
ha@https[:]//hostname/graylog/assets/vendor.437b8293e063schie2fce4768.js:692:40852
ci@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:692:37096
z_@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:692:37906
Ar@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:690:3290
4448/Vo/<@https[:]//hostname/graylog/assets/vendor.437b8293e0632fce4768.js:692:35396
  1. Describe your environment:
OS Information:
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.5 LTS
Release:        22.04
Codename:       jammy
Package Version:
graylog-6.1-repository/stable,stable,now 1-1 all  [installiert]
graylog-enterprise/stable,now 6.1.1-1 amd64  [installiert]
graylog-sidecar-repository/now 1-5 all  [Installiert,lokal]
graylog-sidecar/sidecar-stable,now 1.5.0-2 amd64  [installiert]
mongodb-database-tools/jammy,now 100.10.0 amd64  [Installiert,automatisch]
mongodb-mongosh/jammy,now 2.3.3 amd64  [Installiert,automatisch]
mongodb-org-database-tools-extra/jammy,now 6.0.19 amd64  [Installiert,automatisch]
mongodb-org-database/jammy,now 6.0.19 amd64  [Installiert,automatisch]
mongodb-org-mongos/jammy,now 6.0.19 amd64  [Installiert,automatisch]
mongodb-org-server/jammy,now 6.0.19 amd64  [Installiert,automatisch]
mongodb-org-shell/jammy,now 6.0.19 amd64  [Installiert,automatisch]
mongodb-org-tools/jammy,now 6.0.19 amd64  [Installiert,automatisch]
mongodb-org/jammy,now 6.0.19 amd64  [installiert]
opensearch/stable,now 2.17.1 amd64  [installiert]
  1. Service logs, configurations, and environment variables:
There are no errors in the logs. No changes in configuration or environment variables.
  1. What steps have you already taken to try and solve the problem?
Check Service logs and configurations.
  1. How can the community help?
Anyone has the same effekt after upgrade to 6.1.1?
Any ideas where to look for a reason?
Are you seeing this in server.log or on the frontend (e.g. in your web browser?)
Can you describe what steps lead to this error?
Also can you confirm you intend to use the licensed package, graylog-enterprise vs the Graylog Open package, graylog-server?
Thanks!
  1. I see it in the frontend (web browser).
  2. Upgrade from 6.0.7 to 6.1.1: after logging in, the error message appears immediately.
  3. yes, I want to use the licensed package graylog-enterprise (for reporting and other functions). License for this is valid.
Thanks for the answer!
I have identified the problem: it is NGINX.
Without NGINX (http://<fqdn>:9000/welcome) it works without errors. If I go through NGNIX, the error message appears.
Here is my NGNIX configuration for Graylog (this still worked with 6.0):
location /graylog/ {
                proxy_set_header X-Graylog-Server-URL https://$server_name/graylog/;
                rewrite          ^/graylog/(.*)$  /$1  break;
                proxy_pass       http://127.0.0.1:9000;
and server.conf:
is_leader = true
password_secret = <password_secret>
root_password_sha2 = <root_password_sha2>
root_timezone = Europe/Berlin
http_publish_uri = http://<fqdn>:9000/
trusted_proxies = 127.0.0.1/32, 0:0:0:0:0:0:0:1/128
rotation_strategy = time
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 1500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_enabled = false
integrations_scripts_dir = /usr/share/graylog-server/scripts
what is wrong?
Thanks for reporting this! I was able to reproduce this issue even without using the proxy when setting the graylog http URI to something other than the default /
I’ve opened a GH issue: Accessing Graylog Web Interface using a URI other than `/` returns a frontend error · Issue #20837 · Graylog2/graylog2-server · GitHub
