Error after upgrade from 6.0 to 6.1
After upgrading to 6.1 I cannot access the search page or dashboards, hangs on updating search results and then this is taking a bit longer. Using Apache as proxy in front of graylog no tls set up on graylog. Started after upgrading the Ubuntu package to 6.1
  • OS Information: Ubuntu 22.04 LTS
  • Package Version:6.1.4-2
    from server.log
    2024-12-06T07:25:30.392-06:00 WARN [ProxiedResource] Failed to call API on node , cause: None of the TrustManagers trust this certificate chain. (duration: 8 ms)
Imported CA into the truststore as advised by mutiple searches. Restarted Graylog and full server. I have been unable to find an answer via searches.
Checked server.conf to make sure publish url had not changed.
Any chance someone has seen this same issue that can point me at what to look at for a fix. Searches have given somewhat incomplete answers, mostly about adding the CA cert to the truststore which I have completed but still no luck in accessing search.
Thank you in advance.
Sorry for the noise. I had a typo in the JAVA opts line that it was not reading the truststore file that I created.
Hey @gcstech
Are you certain TLS is not enabled on within your server.conf? Could you post a redacted version of your server.conf?
Could you tell me exactly what you did? I’m lost with this error.
Regards.
Will do the best I can. The fix came from this page
https://graylog.org/post/how-to-guide-securing-graylog-with-tls/
I am running mine through Apache proxy with an internal certificate authority. What I needed to do was to add the CA file for my authority to the truststore and then configure graylog to use it.
Starting under the Java Key Store section
sudo cp /usr/share/graylog-server/jvm/lib/security/cacerts /etc/graylog/graylog.jks
sudo chown graylog:graylog /etc/graylog/graylog.jks
sudo keytool -importcert -keystore /etc/graylog/graylog.jks -storepass changeit -alias cachain -file /etc/graylog/enterpriseRootCA.pem
with enterpriseRootCA.pem being my certficate authority file
Then follow the instructions on that page under Configure Graylog adding the -Djavax.net.ssl.trustStore=/etc/graylog/graylog.jks to the
GRAYLOG_SERVER_JAVA_OPTS line
GRAYLOG_SERVER_JAVA_OPTS=“-Xms8g -Xmx8g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/etc/graylog/graylog.jks”
That got me functioning again after I fixed a typo in the /etc/default/graylog-server file.
Phil
Thank you very much. I will try it.
