I’m running 2 nodes of seperate graylogs on my boxes, one of them is staging/breaking env where upon I try things and it’s generally been fine. I noted that Graylog had gotten somewhat out of date and promptly upgraded 5.2 → 6.0 → 6.1 → 6.2 and it went without hitch. Looking at this great success, I tried with my “home production” env and alas, I can’t get it to upgrade past the 6.0!
OS Information: Debian 12, Docker version 28.1.1
Package Version: 6.0 → 6.1 on docker
Both boxes run same-ish versions of software; here’s docker compose
services:
mongo:
image: mongo:7.0.20
networks:
- graylog
volumes:
- ./mongo:/data/db
restart: always
opensearch:
image: opensearchproject/opensearch:2.15.0
environment:
OPENSEARCH_JAVA_OPTS: '-Xms1g -Xmx1g'
bootstrap.memory_lock: 'true'
discovery.type: 'single-node'
action.auto_create_index: 'false'
plugins.security.ssl.http.enabled: 'false'
plugins.security.disabled: 'true'
OPENSEARCH_INITIAL_ADMIN_PASSWORD: 'nuhhuh
ulimits:
memlock:
hard: -1
soft: -1
nofile:
soft: 65536
hard: 65536
volumes:
- ./opensearch:/usr/share/opensearch/data
restart: always
networks:
- graylog
ports:
- 9200:9200
graylog:
image: graylog/graylog:6.1
volumes:
- ./graylog-data:/usr/share/graylog/data
- ./graylog.config:/usr/share/graylog/data/config
environment:
GRAYLOG_PASSWORD_SECRET: 'dunnolol'
GRAYLOG_ROOT_PASSWORD_SHA2: 'huh'
GRAYLOG_HTTP_EXTERNAL_URI: 'http://127.0.0.1:9000/'
GRAYLOG_HTTP_ENABLE_TLS: 'false'
entrypoint: /usr/bin/tini -- wait-for-it 127.0.0.1:9200 -- /docker-entrypoint.sh
networks:
- graylog
restart: always
depends_on:
- mongo
- opensearch
ports:
- 9000:9000
# and bunch of ports that are ingesting stuff
networks:
graylog:
external: false
Box is hidden behind nginx reverse proxy handling the SSL.
What happens is that the service won’t start:
graylog-1 | 2025-05-20 12:12:27,853 ERROR: org.graylog2.bootstrap.CmdLineTool - Startup error:
graylog-1 | com.google.inject.CreationException: Unable to create injector, see the following errors:
graylog-1 |
graylog-1 | 1) [Guice/ErrorInjectingConstructor]: IllegalArgumentException: Illegal base64 character 1e
graylog-1 | at CustomCAX509TrustManager.(CustomCAX509TrustManager.java:42)
graylog-1 | while locating CustomCAX509TrustManager
graylog-1 | at ServerPreflightChecksModule.configure(ServerPreflightChecksModule.java:44)
graylog-1 | while locating X509TrustManager
and bunch of other errors relating to that.
On staging box it just works, and it baffles me. Both run identical configurations.
How do I disable all the SSL related things so I can get this thing started? I have no need for TLS, everything’s all hidden behind FW and all the public access it gets is by the reverse proxy
