Timestamp extractor error
I try to add timestamp extractor on input in Graylog 4.2.1+5442e44 but get :
gl2_processing_error:
Value <16.12.21 19:14:01.687> caused exception: Invalid format: “16.12.21 19:14:01.687” is malformed at “.12.21 19:14:01.687”.
look like date format is bad ??
  1. for extractor use split and this is Extractor preview : 16.12.21 19:14:01.768 for example
  2. add - Convert to date type
  3. Format string : dd.MM.yy HH:mm:ss.SSS
I used same extractor on same input in Graylog 2.4.3 and it was OK
  • OS Information:
    Kernel: Linux 3.10.0-693.el7.x86_64
  • Package Version:
    elasticsearch-7.13.4-x86_64
when i save extractor as different filed name it is success and no error and value present as date.
maybe elasticsearch need something extra fore timestamp field ?
Hello
From the looks of your screenshot this post looks something familiar to yours.
Sorry about that, but some things have change.
Hope that helps
