ERROR [Extractor] Could not apply converter [DATE] of extractor
Greetings. I am seeing errors in my log file even though my extractor is properly converting epoch dates. I’m wondering why the errors are triggering (and how to stop them).
Environment:
  • Graylog 3.1.4+1149fe1
  • Elastic Search 5.6
Error message:
2021-03-23T16:42:09.404-05:00 ERROR [Extractor] Could not apply converter [DATE] of extractor [9f96c3c4-6aee-11ea-ab2c-0efa831ef056].
java.lang.IllegalArgumentException: Invalid format: "1616510609950" is malformed at "9950"
	at org.joda.time.format.DateTimeFormatter.parseDateTime(DateTimeFormatter.java:945) ~[graylog.jar:?]
	at org.joda.time.DateTime.parse(DateTime.java:160) ~[graylog.jar:?]
	at org.graylog2.inputs.converters.DateConverter.convert(DateConverter.java:87) ~[graylog.jar:?]
	at org.graylog2.plugin.inputs.Extractor.runConverters(Extractor.java:260) [graylog.jar:?]
	at org.graylog2.plugin.inputs.Extractor.runExtractor(Extractor.java:247) [graylog.jar:?]
	at org.graylog2.filters.ExtractorFilter.filter(ExtractorFilter.java:77) [graylog.jar:?]
	at org.graylog2.messageprocessors.MessageFilterChainProcessor.process(MessageFilterC^ChainProcessor.java:100) [graylog.jar:?]
	at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.handleMessage(ProcessBufferProcessor.java:126) [graylog.jar:?]
	at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.dispatchMessage(ProcessBufferProcessor.java:112) [graylog.jar:?]
	at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:89) [graylog.jar:?]
	at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:45) [graylog.jar:?]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Example source message:
{"IntegrityLevel":"16384","ParentProcessId":"794440353170","SourceProcessId":"794440353170","aip":"67.185.87.215","SHA1HashData":"0000000000000000000000000000000000000000","UserSid":"S-1-5-18","event_platform":"Win","TokenType":"1","ProcessEndTime":"","AuthenticodeHashData":"32edce500c8f918b255a3d2b75a69d6a380006befcbc141b3f7ba8db9f134673","ParentBaseFileName":"ngentask.exe","ImageSubsystem":"3","id":"225278d1-8be6-11eb-b7b3-028d8a0523db","EffectiveTransmissionClass":"3","SessionId":"0","Tags":"53, 54, 12094627905582, 12094627906234","timestamp":"1616510609950","event_simpleName":"ProcessRollup2","RawProcessId":"27080","ConfigStateHash":"1390867394","MD5HashData":"b6c3fe33b436e5006514403824f17c66","SHA256HashData":"a446d35f5e60bdae1a7117b71d90abb0fea424ee416b0e0ecd2c485dc5939a68","AuthenticationId":"999","ConfigBuild":"1007.3.0012806.1","CommandLine":"\"C:\\Windows\\Microsoft.NET\\Framework64\\v4.0.30319\\ngen.exe\" uninstall \"C:\\WINDOWS\\assembly\\NativeImages_v2.0.50727_64\\Microsoft.Ink\\4b1202b64c06bf0e2ef81f3f537923b1\\Microsoft.Ink.ni.dll\" /noroot /LegacyServiceBehavior","ParentAuthenticationId":"999","TargetProcessId":"794541773446","ImageFileName":"\\Device\\HarddiskVolume4\\Windows\\Microsoft.NET\\Framework64\\v4.0.30319\\ngen.exe","SourceThreadId":"32172102601597","Entitlements":"15","name":"ProcessRollup2V19","ProcessStartTime":"1616505105.549","aid":"8ac8d6d48a78498b9bbc55bf9cbbddaf","SignInfoFlags":"1835008","cid":"6b4eb5e8aa1c41ea82159a331fbf8af5"}
Regular Expression:
\btimestamp\"\:\"([0-9]*)"
Extractor Preview:
1616510609950
Screenshot of timestamp_epoch being properly parsed and “timestamp” field being properly populated:
Screenshot of extractor config:
Screenshot of errors:
Please let me know if you need any additional information to debug. Thank you so much!
That’s very obvious. Value 1616510609950 is epoch in ms, but graylog can’t parse it using extractor. So use pipeline rule like this:
rule "Epoch Convert"
  contains(to_string($message.message), "event_simpleName")
  let ts = regex(pattern: "\btimestamp\":\"([0-9]*)", value: to_string($message.message));
  let ts_millis = to_long(ts["0"]);
  let new_date = parse_unix_milliseconds(ts_millis, "America/Chicago");
  set_field("timestamp_epoch", new_date);
https://docs.graylog.org/en/4.0/pages/pipelines/functions.html#parse-unix-milliseconds
Thank for responding. I tried your suggestion and end up with the following:
timestamp_epoch:
1970-01-01T00:00:00.000Z
What we have now that is working (except causes all the errors) is a pipeline rule and extractor.
The pipeline rule references the field timestamp_epoch created by the extractor
Extractor
      "title": "CrowdStrike-Timestamp",
      "extractor_type": "regex",
      "converters": [
          "type": "date",
          "config": {
            "locale": "en-US",
            "time_zone": "America/Chicago",
            "date_format": "yyyy-MM-dd HH:mm:ss.SSS Z"
      "order": 0,
      "cursor_strategy": "copy",
      "source_field": "message",
      "target_field": "timestamp_epoch",
      "extractor_config": {
        "regex_value": "\\btimestamp\\\"\\:\\\"([0-9]*)\""
      "condition_type": "string",
      "condition_value": "event_simpleName"
Pipeline rule
rule "Crowdstrike-timestamp"
   to_string($message.filebeat_host_name) == "security-cstrike"
    let timestamp = parse_unix_milliseconds(to_long($message.timestamp_epoch));
    set_field("timestamp", timestamp);
Actual result
Timestamp extracts properly but my log is spammed with errors
Expected Result
