Problem with date extractor converter
Hi all,
I’m trying to parse a date string with format yyyy/MM/dd HH:mm:ss
I think the format is correct because the extractor “try” button report this for the messages
But when I set the converter like yyyy-MM-dd HH:mm:ss
I got this error in log: failed to parse date field [2022-06-09T15:39:24.000Z] with format [yyyy/MM/dd HH:mm:ss||yyyy/MM/dd||epoch_millis]]]
If i set the converter like yyyy-MM-dd HH:mm:ss.SSS i got the error ERROR [Extractor] Could not apply converter [DATE] of extractor <StartTime (015fc1e1-e777-11ec-832a-0050569363a3)>:
java.lang.IllegalArgumentException: Invalid format: “2022/06/10 10:48:39” is malformed at “/06/10 10:48:39”
if I explode the message content I found the time field with the error “Invalid Date”, but the field in search is showed up as DateTime.
Any hint?
Hello
Can you show an accurate example of this message, leaving out private info?
I have seen this issue around here. If my memory is correct it has something to do with mill seconds at the end of Date/Time. It possible to use a GROK pattern or Pipeline to normalize the date time on the Input.
yyyy-MM-dd HH:mm:ss.SSS Z
Found that here.
And Here
And here
thanks, I’ve already read those links but with no luck.
I’m really new to graylog so, maybe, there’s something I can’t understand.
This is an example message
field1,field2,field3,field4,field5,field6,field7,field8,field9,field10,field11,field12,field13,field14,field15,field16,field17,field18,field19,field20,field21,field22,field23,field24,field25,field26,field27,field28,field29,field30,field31,field32,field33,field34,field35,2022/06/13 16:16:48,field37,field38,field39,field40,field41,field42,field43,field44,field45,field46,field47,field48,field49,field50,field51,field52,field53,field54,field55,field56,field57,field58,field59,field60,field61,field62,field63,field64,field65,field66,field67,field68,field69,field70,field71,field72,field73,field74,field75
In position #36 we find the date in format yyyy/MM/dd HH:mm:ss and the extractor using split by comma is working
If I open a message in “preview” of all messages the date is reported as invalid as already said
But if I open the message clicking on it (the linked url is like https://myserver:9000/messages/graylog_5/762ebd00-eb23-11ec-8f8f-0050569363a3) I get the right value
Even if I create a new extractor of type “copy input”
I got the same problem, the field in elasticsearch is identified by date, why?
Edit:
I’ve tried, as suggested, to copy the original field to another field and do some pipeline conversion like
rule "parse date"
has_field("StartTime")
let new_date = parse_date(to_string($message.StartTime2), "yyyy-MM-dd'T'HH:mm:ss.SSSSZ");
/*let new_date = parse_date(to_string($message.StartTime2), "yyyy/MM/dd HH:mm:ss");*/
set_field("StartTime3", new_date);
but the log has again the errors
Error: In call to function ‘parse_date’ at 5:15 an exception was thrown: Invalid format: “2022/06/13 17:33:09” is malformed at “/06/13 17:33:09”)
or
failed to parse date field [2022-06-13T17:36:46.000Z] with format [yyyy/MM/dd HH:mm:ss||yyyy/MM/dd||epoch_millis]]]
Edit2:
If I create an extractor copying a string field to another field, for example StarTime4 and than I set the value with the pipeline code
rule "parse date"
let new_field = to_string($message.StartTime);
set_field("StartTime4", new_field);
the value is visible, but I cannot search as it was a datetime because it’s a string…
Looking at pipelines on how to convert Date/time and since were deal with epoch time have you seen these links? You can just use a pipeline to convert the date/time and remove the extractor I believe or unless you have to use an extractor.
1.Fortigate changed eventtime from seconds to nanoseconds - #2 by shoothub
Or perhaps this?
2.Graylog Knowledge Base - Pipeline Rule Samples
Is it possible to give a more accurate example of the raw message received and insure personal info is either replaced or removed?
Here is an example of mine.
rule "Epoch Convert"
  has_field("eventtime")
  let ts_millis = to_long($message.eventtime) / 1000;
  let new_date = parse_unix_milliseconds(ts_millis);
  set_field("epoch_timestamp", new_date);
  //set_field("timestamp", new_date);
The right hint was remove the extractor and only use the pipeline.
Using this code
rule "parse date"
let new_field2 = parse_date(
                value: new_field,
                pattern: "yyyy/MM/dd HH:mm:ss",
                timezone: "Europe/Rome");
set_field("StartTimeEC", new_field2);
it works!
Just one little thing, when I click on “StartTimeEC” value like this
and I select “add to query”, the value is in UTC time
so I need to do all the query using time -2 hours compared to Europe/Rome timezone. That’s not a big deal, but any hint on this?
