How to transform a timestamp in ms to datetime format?
for example, i want to tranform a timestamp like 1514736000000 to a datetime format 2018-01-01 00:00:00.000.
also can we directly compare the datetime with > < == or != ?
Graylog 3.0.0 will come with a pipeline function for that: parse_unix_milliseconds().
In Graylog 2.x, there’s unfortunately no simple way to achieve this, since parse_date() doesn’t support creating a date from a UNIX epoch timestamp.
You can try the workaround described in Epoch time to readable datetime stamp.
it seems when i compare an DateTime object to each other with < or >. systemctl try to cast it into long, and all input message stuck in message journal:
and error report by graylog:
2018-04-18T17:02:46.446+08:00 WARN  [ProcessBufferProcessor] Unable to process message <430acce0-42e7-11e8-86d6-525400cde656>: java.lang.ClassCastException: org.joda.time.DateTime cannot be cast to java.lang.Long
after rewrite the pipeline rules, how to restart to processing those messages in journal?
after correct the rules, the processing of message journal move forward.
on this other side, can we convert a datetime to long ? i just need compare the log time to now() to make sure the log time is not later than time we analysis it. of course if there is a compare methods(==, !=, <, >, <=, >= ) implementation between datetime objects would be great.
it seems that i got wrong datetime by this way.
my caculation as:
	let epoch = parse_date("1970-01-01 00:00:00.000", "yyyy-MM-dd HH:mm:ss.SSS");
	let ts_ms = to_long($message.x2_procedure_end_time_input);
	let end_time = format_date(epoch + millis(ts_ms),"yyyy-MM-dd HH:mm:ss.SSS","+08:00");
	set_field("x2_procedure_end_ms",ts_ms);
	set_field("x2_procedure_end_time",end_time);
	remove_field("x2_procedure_end_time_input");
but i got a result as:
where 1519488016350 should be beijing time 2018-02-25 00:00:16.350 instead of 1970-01-26 04:31:23.647
eventually found can be caculated as following:
	let end_time = to_date(epoch + seconds(ts_ms/1000) + millis(ts_ms%1000),"+08:00");
	set_field("x2_procedure_end_time",format_date(end_time,"yyyy-MM-dd HH:mm:ss.SSS","+08:00"));
but i cannot achieve a “>” compare between log time and now() in the when condition.
