Good Morning
clicking the node name displays the screen:
Check the logs of your Graylog node(s).
http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
Abaixo está o log do meu graylog
2018-02-26T17:15:47.022-03:00 WARN [ProxiedResource] Unable to call http://192.168.153.136:9000/api/system on node <5908f180-1b37-48ef-8535-d9a926b1bf16>
at okio.Okio$4.newTimeoutException(Okio.java:230) ~[graylog.jar:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:285) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[graylog.jar:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:345) ~[graylog.jar:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:217) ~[graylog.jar:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:211) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:187) ~[graylog.jar:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:88) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:125) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:76) ~[graylog.jar:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_152]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_152]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_152]
at okio.Okio$2.read(Okio.java:139) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[graylog.jar:?]
... 28 more
2018-02-26T17:16:06.984-03:00 WARN [ProxiedResource] Unable to call http://192.168.153.136:9000/api/system/metrics/multiple on node <5908f180-1b37-48ef-8535-d9a926b1bf16>
Caused by: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:1.8.0_152]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) ~[?:1.8.0_152]
at java.net.SocketInputStream.read(SocketInputStream.java:171) ~[?:1.8.0_152]
... 28 more
2018-02-26T17:16:17.004-03:00 WARN [ProxiedResource] Unable to call http://192.168.153.136:9000/api/system on node <5908f180-1b37-48ef-8535-d9a926b1bf16>
... 28 more
Segue o meu arquivo de configuração do server.conf
is_master = true
password_secret = lZNy7DVB3ZWWDc6To5LYtIgXHy0tfojZi9yKYSEw86txQiLW1GXIqNWl1DslEqIBG6IxOwDWwZCiA0fKvzPmH2QL5SA3r8Mt
root_password_sha2 = 03ac674216f3e15c761ee1a5e255f067953623c8b388b4459e13f978d7c846f4
root_timezone = UTC
rest_listen_uri = http://0.0.0.0:9000/api/
elasticsearch_discovery_zen_ping_unicast_hosts = 127.0.0.1:9300
web_listen_uri = http://0.0.0.0:9000/
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 1
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
file elasticsearch
cluster.name: graylog
script.inline: false
script.indexed: false
script.file: false
the same configuration on the ubuntu server worked.
Are these the complete logs of your Graylog node?
Is http://192.168.153.136:9000/api/ the correct URI for the Graylog REST API?
What’s the output of the following command on the machine running Graylog?
# curl -i 'http://192.168.153.136:9000/api/?pretty=true'
[root@centos ~]# curl -i 'http://192.168.153.136:9000/api/?pretty=true’
HTTP/1.1 200 OK
X-Graylog-Node-ID: 5908f180-1b37-48ef-8535-d9a926b1bf16
X-Runtime-Microseconds: 2944
Content-Type: application/json
Date: Tue, 27 Feb 2018 12:40:35 GMT
Content-Length: 253
“cluster_id” : “9494d151-0ad1-4433-992c-8f51482dabe0”,
“node_id” : “5908f180-1b37-48ef-8535-d9a926b1bf16”,
“version” : “2.4.3+2c41897”,
“tagline” : “Manage your logs in the dark and have lasers going and make it look like you’re from space!”
Any news to me?
Below I informed the result of the command that you requested.
On the log file the only data that appears in the log file is the one I sent.
