System information is currently unavailable error
I am basically having the same issue as this person,
I am on Graylog 3.0 but I was getting this issue on 2.5 too, the server is a physical server in our data centre (Intel(R) Xeon(R) CPU E5620 @ 2.40GHz with 64GB of RAM).
Server conf
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret =
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 =
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
#http_bind_address = 127.0.0.1:9000
http_bind_address = 10.3.11.250:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
http_publish_uri = http://10.3.11.250:9000/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri = 10.3.11.250/
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
Default: http://10.3.11.250:9200
#elasticsearch_hosts = http://elasticsearch:9200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
#no_retention = false
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
#http_proxy_uri =
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
Server is in our DC which we have a site to site VPN with, the odd issue is that when the alerts calm down and the messages slow down, it starts to work.
Otherwise it’s fine.
Could you please re-edit your post, so the other config file and all the logging are also in code blocks (</>) of their own? That’ll help us read them. Thanks! :blush:
Now, about that box of yours:
I am on Graylog 3.0 but I was getting this issue on 2.5 too, the server is a physical server in our data centre (Intel® Xeon® CPU E5620 @ 2.40GHz with 64GB of RAM).
Are you saying you’re using one physical box to house Graylog, Mongo and ElasticSearch all-in-one? That can definitely work, as long as you configure the heap sizes correctly and force Graylog to not take too many processors.
With 64GB of RAM I would set Graylog heap to a max of 2GB (by recommendation of @jan) and the ElasticSearch heap to max at 25GB. This would still leave ample RAM for I/O caching, the OS and MongoDB. (2+25)*2 = 54GB, which leaves 10GB for the OS and MongoDB, plus room to spare.
Now, the E5620 has four physical cores, which with hyper-threading would behave mostly like eight cores. If you don’t want to starve Mongo, Elastic and the OS, you should not let Graylog take more than half of that; so four cores. You’ll have to search the forums for instructions on how to do that; we’ve recently been going over that a few times, the settings are in the Graylog server.conf.
Of course, these are just my own ideas. There are many more experienced people on these forums.
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
# Before you set out to tweak and tune the configuration, make sure you
# understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: graylog
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
#node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
# path.data: /var/lib/elasticsearch
# Path to log files:
# path.logs: /var/log/elasticsearch
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
#network.host: 10.3.11.250
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is [“127.0.0.1”, “[::1]”]
#discovery.zen.ping.unicast.hosts: [“host1”, “host2”]
# Prevent the “split brain” by configuring the majority of nodes (total number of master-eligible nodes / 2 + 1):
#discovery.zen.minimum_master_nodes: 3
# For more information, consult the zen discovery module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
# http.cors.enabled: true
# http.cors.allow-origin: “*”
Graylog log shows:
    Feb 15 17:22:15 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: 2019-02-15 17:22:15,052 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call http://10.3.11.250:9000/api/sys
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: … 28 more
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at okio.Okio$2.read(Okio.java:140) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_151]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_151]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: Caused by: java.net.SocketException: Socket closed
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_151]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_151]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_151]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at retrofit2.OkHttpCall.execute(OkHttpCall.java:180) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
    Feb 15 17:22:14 [ix3-graylog001.secure.livedrive.com](http://ix3-graylog001.secure.livedrive.com/) graylog-server[22216]: at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126) ~[graylog.jar:?]
Thanks for that information, still getting the same issue.
CPU utilisation is around 8% and using 30.86GB of RAM at the moment.
I get around 200-400 MSG’s a second, so didn’t think it would be such an issue…
Edit: Noticed a oddity, System Information is current unavailable goes away and comes back intermittently. Not a network issue as I have confirm that between me and the box and even on local LAN I get the same issue. When it blipped it said it had a max heap size of 2GB when I set it in JVM options as per recommended…
Try increasing the Graylog heap size - I had the same problem after upgrading and it seems that restoring the heap size to what we originally configured solved the intermittent 500 errors on ProxiedResources.
Mine’s set to 2GB as per the recommendation above, what do you have it set as? What size resolved it?
I run 3 nodes behind a load balancer with 16Gb heap each :slight_smile:
Wow, that’s way beyond what @jan and the official docs recommend :slight_smile:
I did 16GB each and still getting the same issue… Am I hammering Graylog with 300MSG/s? Another update to the issue is that if I pause message processing, it’s fine.
Edit: Pausing it doesn’t improve the situation, same issue persists.
No, don’t worry. 300 messages per second should be very doable, depending on your setup.
Set up is all on that one physical box, do I need multiple nodes?
Well… yeah. That would be A Good Thing™.
Especially if you want something like high-availability.
