API timeout /system
When I go to the page System / Nodes it says “System information is currently unavailable” below my single node.
The graylog server logs says:
WARN [ProxiedResource] Unable to call http://ip:9000/api/system on node : timeout
I’ve checked with the developper console on my browser and the timeout is exactly 10 seconds.
Then many pages have issues, I need to restart the graylog-server service to get Graylog fine again (except the Nodes page of course).
There is no reverse proxy and no firewall between my browser and Graylog, it’s a direct access.
Strange thing: when I try a simple curl on this URI directly executed on the Graylog server I get a good answer (code 200 and a response body) but after a very very long time: 4 minutes!!!
My environment:
CentOS 7.9
Java OpenJDK 1.8.0_312
Elasticsearch OSS 7.10
MongoDB 4.4
Graylog 4.2.5
Graylog plugins: graylog-plugin-collector-4.2.5 and graylog-storage-elasticsearch7-4.2.5
It’s a fresh install (it isn’t an upgrade).
I’ve found multiple topics on this subject, and there can be multiples causes, but I checked all of them and I can’t resolve my issue.
It’s not a DNS issue as I access Graylog directly with its IP address.
I set http_bind_address = ip:9000
I didn’t set http_publish_uri nor http_external_uri as by default they should use http_bind_address.
(I tried to set both of them but the result is the same)
It’s not a resource issue because I don’t receive any log.
The host has 8 CPU and 16 GB RAM.
Graylog heap size = 2 GB (I tried 3 GB but same issue)
Elastic heap size = 3 GB
Load average = 0.04
4 GB free RAM.
It’s not a certificate issue as I don’t use https.
Any idea ?
To know for sure on how to fix this issue we need more information. Your Elasticsearch, Graylog configuration file.
Your status of both Elasticsearch and Graylog would be nice :slight_smile:
systemctl status elasticsearch
systemctl status graylog-server
A couple suggestion:
  • Permission on Graylog directory chown graylog:graylog -R /etc/graylog/
  • Selinux enabled?
  • The /etc/hosts file, does it have your IP Address for the Graylog server?
  • Did you check Elasticsearch log and/or execute root# sudo journalctl to find out more on this issue?
Thank you for trying to help me.
Both services are running:
(graylog service was started few minutes ago because I restarted it after some tests like after chown but the issue is still there)
   Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2022-02-02 10:02:55 CET; 7min ago
     Docs: http://docs.graylog.org/
 Main PID: 36718 (graylog-server)
    Tasks: 180 (limit: 49452)
   Memory: 1.5G
   CGroup: /system.slice/graylog-server.service
           ├─36718 /bin/sh /usr/share/graylog-server/bin/graylog-server
           └─36753 /usr/bin/java -Xms2g -Xmx2g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -jar -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm /usr/share/graylog-server/graylog.jar server -f /etc/graylog/server/server.conf -np
Feb 02 10:02:55 graylog systemd[1]: Started Graylog server.
● elasticsearch.service - Elasticsearch
   Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2022-01-26 17:54:38 CET; 6 days ago
     Docs: https://www.elastic.co
 Main PID: 24537 (java)
    Tasks: 72 (limit: 49452)
   Memory: 3.9G
   CGroup: /system.slice/elasticsearch.service
           └─24537 /usr/share/elasticsearch/jdk/bin/java -Xshare:auto -Des.networkaddress.cache.ttl=60 -Des.networkaddress.cache.negative.ttl=10 -XX:+AlwaysPreTouch -Xss1m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -XX:-OmitStackTraceInFastThrow -XX:+ShowCodeDetailsInExceptionMessages -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dio.netty.allocator.numDirectArenas=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Djava.locale.providers=SPI,COMPAT -Xms2g -Xmx2g -XX:+UseG1GC -XX:G1ReservePercent=25 -XX:InitiatingHeapOccupancyPercent=30 -Djava.io.tmpdir=/tmp/elasticsearch-513546673359258236 -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=/var/lib/elasticsearch -XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log -Xlog:gc*,gc+age=trace,safepoint:file=/var/log/elasticsearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m -XX:MaxDirectMemorySize=1073741824 -Des.path.home=/usr/share/elasticsearch -Des.path.conf=/etc/elasticsearch -Des.distribution.flavor=oss -Des.distribution.type=rpm -Des.bundled_jdk=true -cp /usr/share/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -p /var/run/elasticsearch/elasticsearch.pid --quiet
Jan 26 17:54:20 graylog systemd[1]: Starting Elasticsearch...
Jan 26 17:54:38 graylog systemd[1]: Started Elasticsearch.
SELinux is Disabled.
Chown done but the issue is still present.
Graylog configuration:
is_master = true
password_secret = xxx
root_password_sha2 = yyy
http_bind_address = 192.168.0.2:9000
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
Elasticsearch configuration:
cluster.name: graylog
path.data: /data/elasticsearch
path.logs: /var/log/elasticsearch
About the /etc/hosts file are you talking about the one on the Graylog server or the one on my workstation ?
I don’t understand why I should add it because I access graylog directly to its IP address (http://192.168.0.2:9000) and this IP is set for the http_bind_adress.
I don’t find any error in Elasticsearch logs (/var/log/elasticsearch/graylog.log and journalctl -u elasticsearch).
Hello
Perhaps these might help
Unfortunately it doesn’t help because those issues where related to bad use of rest_xxx and web_xxx which were the old configuration syntax (it has been replaced by http_xxx which is easier).
If you can login the Web UI and Graylog is unable to Call that URI(http://ip:9000/api/system). then it might be API problem with that URL. This could be a couple different issues. Either its being block or Graylog is unable to find that Address. Configuring your /etc/hosts might help. Whenever you open a website by typing its hostname/ipaddress, your system will read through the hosts file to check for the corresponding IP and then open it. If your hostname is called localhost some thing like this should be configured.
192.168.0.2 localhost
OR
192.168.0.2  myhostname
Restart network service or reboot.
I personally use IP address and make my network static. This prevents issue in the future.
I’m using GL 4.2, ES 7.10, Mongo 4.4 here is my environment.
Elasticsearch config…
path.data: /var/lib/elasticsearch
network.host: 8.8.8.8
http.port: 9200
discovery.type: single-node
Graylog config…
[root@graylog server]# cat /etc/graylog/server/server.conf | egrep -v "^\s*(#|$)"
is_master = true
password_secret =epOqmLi7r7CdZxl76QOQxr8bRUPYstNdcBuajsaSNfG5bkXXFxyHAAsdgmCfyHhSKlKXjMQG9ojc0bn22EBT17elgGTUJgbD
root_password_sha2 =272c3ac6b26a795a4244d8d2caf1d19a072fbc1c88d497ba1df7fef0a4171ea6
root_email = "greg.smith@domain.com"
http_bind_address = 8.8.8.8:9000
http_enable_cors = true
elasticsearch_hosts = http://8.8.8.8:9200
output_batch_size = 5000
processbuffer_processors = 8
ring_size = 65536
message_journal_max_size = 12gb
mongodb_uri = mongodb://localhost:27017/graylog
transport_email_hostname = localhost
transport_email_port = 25
transport_email_from_email = root@domain.com
transport_email_web_interface_url = https://8.8.8.8:9000
http_connect_timeout = 10s
Some suggestion if you haven’t done this already.
Perhaps check all directory’s that Graylog would need to use, specially plugins, ect… for permission issues.
Check system journal by executing this journalctl -xe looking for anything that would pertain to connecting IP ADD 192.168.0.2 or something similar.
Restart services and tail the log files elasticsearch, Graylog and MongoDb etc…
Next, I know its default but I would try to set this in my Graylog configuration file
http_enable_cors = true and restart GL service.
I’m assuming your using localhost instead of 127.0.0.1 for Graylog and Elasticsearch connection? If so, then I would make sure the my etc/hosts file know what localhost is
Example
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
Just an idea,
Yes I can login the Web UI and I don’t have any problem with others pages. The only issue is with this API call.
I’ve checked if hotsname were used somewhere to replace them with IP addresses to not have any problem with hostname resolution.
First I’ve found mongodb_uri = mongodb://localhost/graylog.
So I set mongodb_uri = mongodb://127.0.0.1/graylog.
(It may be not part of the solution because in /etc/hosts there is by default 127.0.0.1 localhost)
Then I’ve found the elasticsearch_hosts.
It was commented but it says by default it’s http://127.0.0.1:9200
I uncommented it to force it to http://127.0.0.1:9200.
Finally I restarted Graylog to apply this 2 settings.
And it works!
But it’s strange, if I revert those settings it’s still work…
Maybe it’s also stored somewhere in MongoDB (I didn’ find where).
In my 2nd Graylog I use TLS and I’ve found a typo in javax.net.ssl.trustStore (I typed “ss” instead of “ssl”…).
It’s really hard to find the root cause of this issue.
It can be many things, and logs don’t help, they only say “timeout”.
And I don’t understand why this specific page acts diffrently than other pages.
Awesome :+1:
It Graylogs dark magic, what should be will not necessary will be :smiley:
