API URL Wrong Unable to call http://api/system
Inputs won’t start. The log is filled with Unable to call http://api/system warnings.
Clicking on node 8964c162 / localhost shows me the monkey. Error getting data.
  • OS Information:
    Ubuntu 20.04.4
  • Package Version:
    4.2.7-1
    Unable to call h**://api/system/inputstates/623b45dc20fad36bfa76229d on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
nginx
server
listen 443 ssl http2;
server_name graylog.datanat.com;
ssl_certificate /etc/ssl/certs/localhost.crt;
ssl_certificate_key /etc/ssl/private/localhost.key;
add_header ‘Content-Security-Policy’ ‘upgrade-insecure-requests’;
location /
proxy_set_header X-Graylog-Server-URL https://$server_name/;
proxy_pass h**://10.141.0.64:9000;
server.conf
http_bind_address = 10.141.0.64:9000
http_publish_uri = h**://$http_bind_address/
http_external_uri = h**://$http_publish_address/
I originally had http_bind_address set to 127.0.0.1:9000. Changed it to the network IP 10.141.64:9000. Tried accessing the web server directly without going through NGINX. Re-installed the whole server.
I tried setting http_external_uri = 10.141.0.64:9000
What is causing the server to access h**://api/system/inputstates instead of h**://10.141.0.64/api/system/inputstates ?
h** = http, the forum wouldn’t let me use more than two http://
Thanks!
Hello && Welcome
I’m unsure exactly what’s going on. From what I can understand is the Graylog server is not work at all, is this correct?
If you could us the markdown for posting Configuration files and logs that would be great, you can find more information here on “HowTo”.
If you can give us a great amount of details what’s happening that would be great.
Showing your whole configuration file would be nice. NOTE: remove personal information when posting.
Example:
cat /etc/graylog/server/server.conf | egrep -v "^\s*(#|$)"
Output
[root@graylog ingest-attachment]# cat /etc/graylog/server/server.conf | egrep -v "^\s*(#|$)"
is_master = true
password_secret =en22EBT17elgGTUJgbD
root_password_sha2 =2df7fef0a4171ea6
root_email = "greg.smith@domain.com"
http_bind_address = graylog.domain.com:9000
http_publish_uri = https://graylog.domain.com:9000/
http_enable_cors = true
http_enable_tls = true
http_tls_cert_file = /etc/pki/tls/certs/graylog/graylog-certificate.pem
http_tls_key_file = /etc/pki/tls/certs/graylog/graylog-key.pem
elasticsearch_hosts = http://10.10.10.10:9200
Question: Did this Graylog server work before with/without Nginx?
Thank you for responding.
The web portion works. When the web portion tries to access the API, it fails. It appears to be trying to access the API without using an IP + port number in the URL.
This is a new build. Disabling Nginx and accessing http://10.141.0.64:9000/ directly also causes the issue.
server.conf
is_master = true
password_secret = ****
root_password_sha2 = ****
root_timezone = EST
http_publish_uri = http://$http_bind_address/
http_external_uri = http://10.141.0.64:9000/
http_enable_gzip = true
http_max_header_size = 8192
http_thread_pool_size = 16
http_enable_tls = false
trusted_proxies = 127.0.0.1/32, 0:0:0:0:0:0:0:1/128
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
server.log
2022-03-24T13:41:42.070-04:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-03-24T13:41:44.067-04:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.2.7 [org.graylog.aws.AWSPlugin]
2022-03-24T13:41:44.068-04:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integrations 4.2.7 [org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin]
2022-03-24T13:41:44.068-04:00 INFO  [CmdLineTool] Loaded plugin: Integrations 4.2.7 [org.graylog.integrations.IntegrationsPlugin]
2022-03-24T13:41:44.069-04:00 INFO  [CmdLineTool] Loaded plugin: Collector 4.2.7 [org.graylog.plugins.collector.CollectorPlugin]
2022-03-24T13:41:44.069-04:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise 4.2.7 [org.graylog.plugins.enterprise.EnterprisePlugin]
2022-03-24T13:41:44.070-04:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES6 Support) 4.2.7 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es6.EnterpriseES6Plugin]
2022-03-24T13:41:44.071-04:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES7 Support) 4.2.7 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es7.EnterpriseES7Plugin]
2022-03-24T13:41:44.071-04:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.2.7 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-03-24T13:41:44.071-04:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.2.7+879e651 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-03-24T13:41:44.072-04:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.2.7+879e651 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-03-24T13:41:44.110-04:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2022-03-24T13:41:44.280-04:00 INFO  [Version] HV000001: Hibernate Validator null
2022-03-24T13:41:47.630-04:00 INFO  [InputBufferImpl] Message journal is enabled.
2022-03-24T13:41:47.658-04:00 INFO  [NodeId] Node ID: 8964c162-c032-4db5-880f-82e3258b9a05
2022-03-24T13:41:47.991-04:00 INFO  [LogManager] Loading logs.
2022-03-24T13:41:48.084-04:00 INFO  [LogManager] Logs loading complete.
2022-03-24T13:41:48.089-04:00 INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-03-24T13:41:48.125-04:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-03-24T13:41:48.168-04:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-03-24T13:41:48.443-04:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:206}] to localhost:27017
2022-03-24T13:41:48.447-04:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=2921619}
2022-03-24T13:41:48.463-04:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:207}] to localhost:27017
2022-03-24T13:41:49.211-04:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2022-03-24T13:41:49.772-04:00 INFO  [ElasticsearchVersionProvider] Elasticsearch cluster is running v7.10.2
2022-03-24T13:41:50.900-04:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-03-24T13:41:50.959-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-03-24T13:41:50.966-04:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-03-24T13:41:50.973-04:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:208}] to localhost:27017
2022-03-24T13:41:50.989-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-03-24T13:41:51.012-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-03-24T13:41:51.031-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-03-24T13:41:51.050-04:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2022-03-24T13:41:51.563-04:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2022-03-24T13:41:51.565-04:00 INFO  [ServerBootstrap] Graylog server 4.2.7+879e651 starting up
2022-03-24T13:41:51.565-04:00 INFO  [ServerBootstrap] JRE: Private Build 17.0.2 on Linux 5.4.0-99-generic
2022-03-24T13:41:51.565-04:00 INFO  [ServerBootstrap] Deployment: deb
2022-03-24T13:41:51.565-04:00 INFO  [ServerBootstrap] OS: Ubuntu 20.04.4 LTS (focal)
2022-03-24T13:41:51.565-04:00 INFO  [ServerBootstrap] Arch: amd64
2022-03-24T13:41:51.588-04:00 INFO  [PeriodicalsService] Starting 37 periodicals ...
2022-03-24T13:41:51.588-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2022-03-24T13:41:51.592-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2022-03-24T13:41:51.621-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
2022-03-24T13:41:51.622-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2022-03-24T13:41:51.624-04:00 INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2022-03-24T13:41:51.632-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2022-03-24T13:41:51.637-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2022-03-24T13:41:51.637-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2022-03-24T13:41:51.638-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2022-03-24T13:41:51.653-04:00 INFO  [LookupTableService] Data Adapter watchlist-mongo/623b40e120fad36bfa761d19 [@84bcffe] STARTING
2022-03-24T13:41:51.654-04:00 INFO  [LookupTableService] Data Adapter watchlist-mongo/623b40e120fad36bfa761d19 [@84bcffe] RUNNING
2022-03-24T13:41:51.669-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2022-03-24T13:41:51.674-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2022-03-24T13:41:51.675-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2022-03-24T13:41:51.676-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2022-03-24T13:41:51.680-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2022-03-24T13:41:51.684-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2022-03-24T13:41:51.687-04:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2022-03-24T13:41:51.688-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2022-03-24T13:41:51.688-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2022-03-24T13:41:51.690-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2022-03-24T13:41:51.693-04:00 INFO  [LookupTableService] Cache watchlist-cache/623b40e120fad36bfa761d1b [@467aa05d] STARTING
2022-03-24T13:41:51.694-04:00 INFO  [LookupTableService] Cache watchlist-cache/623b40e120fad36bfa761d1b [@467aa05d] RUNNING
2022-03-24T13:41:51.702-04:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:209}] to localhost:27017
2022-03-24T13:41:51.717-04:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2022-03-24T13:41:51.718-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2022-03-24T13:41:51.718-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2022-03-24T13:41:51.722-04:00 INFO  [LookupTableService] Starting lookup table watchlist/623b40e120fad36bfa761d1d [@569cd649] using cache watchlist-cache/623b40e120fad36bfa761d1b [@467aa05d], data adapter watchlist-mongo/623b40e120fad36bfa761d19 [@84bcffe]
2022-03-24T13:41:51.724-04:00 INFO  [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2022-03-24T13:41:51.727-04:00 INFO  [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2022-03-24T13:41:51.727-04:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
2022-03-24T13:41:51.728-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2022-03-24T13:41:51.728-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2022-03-24T13:41:51.728-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2022-03-24T13:41:51.733-04:00 INFO  [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2022-03-24T13:41:51.734-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2022-03-24T13:41:51.734-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.forwarder.ForwarderStatePeriodical] periodical in [0s], polling every [15s].
2022-03-24T13:41:51.734-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.license.LicenseManagerPeriodical] periodical in [0s], polling every [300s].
2022-03-24T13:41:51.735-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.license.LicenseReportPeriodical] periodical in [300s], polling every [3600s].
2022-03-24T13:41:51.735-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.license.StagedLicenseInstallerPeriodical] periodical, running forever.
2022-03-24T13:41:51.736-04:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:210}] to localhost:27017
2022-03-24T13:41:51.737-04:00 INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:211}] to localhost:27017
2022-03-24T13:41:51.738-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.auditlog.mongodb.MongoAuditLogPeriodical] periodical in [0s], polling every [3600s].
2022-03-24T13:41:51.738-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.report.scheduler.ReportPeriodical] periodical in [120s], polling every [60s].
2022-03-24T13:41:51.738-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] periodical in [60s], polling every [180s].
2022-03-24T13:41:51.738-04:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2022-03-24T13:41:51.739-04:00 INFO  [Periodicals] Starting [org.graylog.plugins.files.CleanupPeriodical] periodical in [0s], polling every [86400s].
2022-03-24T13:41:52.013-04:00 INFO  [JerseyService] Enabling CORS for HTTP endpoint
2022-03-24T13:41:55.213-04:00 INFO  [JerseyService] Started REST API at <10.141.0.64:9000>
2022-03-24T13:41:55.213-04:00 INFO  [ServiceManagerListener] Services are healthy
2022-03-24T13:41:55.216-04:00 INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2022-03-24T13:41:55.216-04:00 INFO  [ServerBootstrap] Services started, startup times in ms: {GracefulShutdownService [RUNNING]=1, BufferSynchronizerService [RUNNING]=1, FailureHandlingService [RUNNING]=1, UrlWhitelistService [RUNNING]=1, LocalKafkaMessageQueueWriter [RUNNING]=4, LocalKafkaMessageQueueReader [RUNNING]=4, JobSchedulerService [RUNNING]=8, OutputSetupService [RUNNING]=9, EtagService [RUNNING]=9, DevelopmentDirectoryObserverService [RUNNING]=10, InputSetupService [RUNNING]=14, PrometheusExporter [RUNNING]=15, UserSessionTerminationService [RUNNING]=16, StreamCacheService [RUNNING]=16, ConfigurationEtagService [RUNNING]=16, ProcessingConfigurationManager [RUNNING]=22, MongoDBProcessingStatusRecorderService [RUNNING]=34, LocalKafkaJournal [RUNNING]=42, LookupTableService [RUNNING]=119, PeriodicalsService [RUNNING]=160, JerseyService [RUNNING]=3627}
2022-03-24T13:41:55.227-04:00 INFO  [ServerBootstrap] Graylog server up and running.
2022-03-24T13:41:55.228-04:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2022-03-24T13:41:55.239-04:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/623b45dc20fad36bfa76229d] is now STARTING
2022-03-24T13:41:55.477-04:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/623b45dc20fad36bfa76229d] is now RUNNING
2022-03-24T13:43:12.371-04:00 WARN  [TeamSyncProvisionerAction] No valid enterprise license found. Teams synchronisation is disabled.
2022-03-24T13:43:12.442-04:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2022-03-24T13:43:20.334-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:26.864-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:31.954-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:32.808-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:33.250-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates/623b45dc20fad36bfa76229d on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:33.253-04:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2022-03-24T13:49:36.998-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:38.802-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:42.034-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:44.798-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:47.074-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:51.047-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:52.114-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:56.817-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:49:57.154-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:01.922-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:02.202-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:02.819-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:05.926-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:07.246-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:08.814-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:10.058-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:12.058-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:12.290-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:14.798-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:15.927-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:17.330-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:19.934-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:21.062-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:21.938-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:22.366-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:25.930-04:00 WARN  [ProxiedResource] Unable to call http://api/system/inputstates on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
2022-03-24T13:50:27.054-04:00 WARN  [ProxiedResource] Unable to call http://api/system/metrics/multiple on node <8964c162-c032-4db5-880f-82e3258b9a05>: Connect timed out
I have a suggestion you can try.
First you can comment these two line out
#http_publish_uri = http://$http_bind_address/
#http_external_uri = http://10.141.0.64:9000/
Second add/uncomment this line.
elasticsearch_hosts = http://127.0.0.1:9200
Make sure you elasticsearch yaml file is correct.
cluster.name: graylog
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
network.host: 127.0.0.1
http.port: 9200
discovery.type: single-node
If you have to make adjustments to either file, the service will have to be restarted. If you do have to make adjustment to both files I personal would stop Graylog service and restart elasticsearch. Once elasticsearch is running without issues Then start Graylog service and tail -f Graylogs log file to insure there are no problems. If there are issues, posting them here would help, Don’t forget to remove personal info.
EDIT: I forgot to mention check Firewall/Selinux/Apparmor. Insure the permissions in Graylog’s directory are correct. This maybe a no brainer but I have seen Graylog unable to access its own files.
Check Elasticsearch Health.
curl -XGET http://127.0.0.1:9200/_cluster/health?pretty=true
Check status on these two services, sometimes there could be a error /warning that could help troubleshoot.
root# systemctl status mongod
root# systemctl status graylog-server
I just noticed you tried using HTTPS, On that note make sure your URL is correct and you trying to connect http://10.141.0.64:9000 also you /etc/hosts file is correct.
Oh… thank you so much! I commented those lines out and restarted. It’s now working fine.
Glad it worked out for you, If you could mark this as resolved for future issues that would be great :smiley:
