Hey,
i have this problem when i try to get information about a graylog node it says that the information is not available.
after a few seconds when i try to call the node i get this wonderful monkey:
The associated graylog log:
19.10.2020 13:23:4511:23:45.522 [http-worker-2] ERROR org.graylog2.shared.rest.exceptionmappers.AnyExceptionClassMapper - Unhandled exception in REST resource
19.10.2020 13:23:45java.net.SocketTimeoutException: connect timed out
19.10.2020 13:23:45 at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_265]
19.10.2020 13:23:45 at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_265]
19.10.2020 13:23:45 at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_265]
19.10.2020 13:23:45 at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_265]
19.10.2020 13:23:45 at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_265]
19.10.2020 13:23:45 at java.net.Socket.connect(Socket.java:607) ~[?:1.8.0_265]
19.10.2020 13:23:45 at okhttp3.internal.platform.Platform.connectSocket(Platform.java:130) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:263) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:183) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.java:224) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.java:108) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.java:88) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.connection.Transmitter.newExchange(Transmitter.java:169) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:41) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[graylog.jar:?]
19.10.2020 13:23:45 at okhttp3.RealCall.execute(RealCall.java:81) ~[graylog.jar:?]
19.10.2020 13:23:45 at retrofit2.OkHttpCall.execute(OkHttpCall.java:190) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.graylog2.rest.resources.cluster.ClusterSystemResource.jvm(ClusterSystemResource.java:91) ~[graylog.jar:?]
19.10.2020 13:23:45 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_265]
19.10.2020 13:23:45 at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_265]
19.10.2020 13:23:45 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_265]
19.10.2020 13:23:45 at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_265]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
19.10.2020 13:23:45 at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
19.10.2020 13:23:45 at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
19.10.2020 13:23:45 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
19.10.2020 13:23:45 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
19.10.2020 13:23:45 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
19.10.2020 13:23:4511:23:45.531 [http-worker-6] ERROR org.graylog2.shared.rest.exceptionmappers.AnyExceptionClassMapper - Unhandled exception in REST resource
19.10.2020 13:23:45 at org.graylog2.rest.resources.cluster.ClusterSystemPluginResource.list(ClusterSystemPluginResource.java:76) ~[graylog.jar:?]
19.10.2020 13:23:4711:23:47.448 [proxied-requests-pool-15] WARN org.graylog2.shared.rest.resources.ProxiedResource - Unable to call https://****URL****/api/system/metrics/multiple on node <**NODE-ID**>: connect timed out
19.10.2020 13:23:5011:23:50.543 [proxied-requests-pool-17] WARN org.graylog2.shared.rest.resources.ProxiedResource - Unable to call https://**URL**/api/system on node <**NODE-ID**>: connect timed out
19.10.2020 13:23:5011:23:50.543 [proxied-requests-pool-18] WARN org.graylog2.shared.rest.resources.ProxiedResource - Unable to call https://**URL**/api/system/inputstates on node <**NODE-ID**>: connect timed out
19.10.2020 13:23:5311:23:53.441 [proxied-requests-pool-19] WARN org.graylog2.shared.rest.resources.ProxiedResource - Unable to call https://**URL**/api/system/metrics/multiple on node <**NODE-ID**>: connect timed out
19.10.2020 13:23:5511:23:55.566 [proxied-requests-pool-20] WARN org.graylog2.shared.rest.resources.ProxiedResource - Unable to call https://**URL**/api/system on node <**NODE-ID**>: connect timed out```
I have no idear why this happens can u help me?
have a nice day ^^
itstimetoforget
PS: If I made a mistake with the formatting I am sorry. This is my first question here and I am new ^^
