Nodes error system unavailable
May i know why this is appearing, do you guys having any idea?
hej @shann
did you check your Graylog server.log ?
This is what i can see from the log.
2017-05-26T17:34:29.115+08:00 WARN [ProxiedResource] Unable to call http://10.31.22.114:9000/api/system/metrics/multiple on node
at okio.Okio$4.newTimeoutException(Okio.java:227) ~[graylog.jar:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:284) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:240) ~[graylog.jar:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:325) ~[graylog.jar:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:314) ~[graylog.jar:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:210) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1Codec.readResponse(Http1Codec.java:191) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:132) ~[graylog.jar:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:54) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:179) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:63) ~[graylog.jar:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:174) ~[graylog.jar:?]
at org.graylog2.shared.rest.resources.ProxiedResource.lambda$null$0(ProxiedResource.java:76) ~[graylog.jar:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_131]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_131]
at okio.Okio$2.read(Okio.java:138) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:236) ~[graylog.jar:?]
… 29 more
hej @shann
please place log files or configuration inside of triple back tics to get it better readable.
TEXT
It looks like Graylog is not able to connect to the configured rest_listen_uri at http://10.31.22.114:9000/api/ - is something blocking the request?
