does syslog udp input support customized encoding feature?
I’m facing a problem that one host sends syslog with encoding “gbk”, graylog seems decode content with default locale “UTF-8”.
it didn’t work after I changed system locale to “gbk”.
I used the log stash to do encoding converter. and it’s solved.
