Graylog not taking syslog
My Graylog is not taking any Syslog data, and I got the following error message on my Graylog log file:
2017-08-10T09:34:41.723-04:00 ERROR [NettyTransport] Error in Input [Syslog TCP/59833c2a6cc2e22d8214bca5] (channel [id: 0xe5ec9347, /10.10.60.41:54774 => /10.10.60.122:9542])
java.lang.NumberFormatException: For input string: "10-Aug-2017"
        at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:1.8.0_141]
        at java.lang.Integer.parseInt(Integer.java:580) ~[?:1.8.0_141]
        at java.lang.Integer.parseInt(Integer.java:615) ~[?:1.8.0_141]
        at org.graylog2.inputs.syslog.tcp.SyslogOctetCountFrameDecoder.decode(SyslogOctetCountFrameDecoder.java:45) ~[graylog.jar:?]
        at org.jboss.netty.handler.codec.frame.FrameDecoder.callDecode(FrameDecoder.java:425) ~[graylog.jar:?]
        at org.jboss.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:303) ~[graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) ~[graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
        at org.graylog2.inputs.syslog.tcp.SyslogTCPFramingRouterHandler.messageReceived(SyslogTCPFramingRouterHandler.java:53) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.messageReceived(SimpleChannelHandler.java:142) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:88) [graylog.jar:?]
        at org.jboss.netty.handler.traffic.AbstractTrafficShapingHandler.messageReceived(AbstractTrafficShapingHandler.java:718) [graylog.jar:?]
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.messageReceived(SimpleChannelUpstreamHandler.java:124) [graylog.jar:?]
        at org.graylog2.plugin.inputs.util.PacketInformationDumper.messageReceived(PacketInformationDumper.java:51) [graylog.jar:?]
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [graylog.jar:?]
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [graylog.jar:?]
        at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [graylog.jar:?]
        at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [graylog.jar:?]
        at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_141]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_141]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_141]
Any help is apperciated !!
Try using a Raw/Plaintext UDP or TCP input instead of a Syslog UDP or TCP input.
