Graylog not found any syslog
When i installed the graylog 4.2x,i can not found any syslog from the network device.
  • OS Information:Graylog v4.2.8+c9edd92
  • Package Version:
I have increasd the jvm form 1g to 6g and set the receive buffer,checked the logfile not found any error message.but it still not working.Plese help.
i have tried edited iptables as shown:
iptables -t nat -A PREROUTING -p tcp --dport 514 -j REDIRECT --to 1514
iptables -t nat -A PREROUTING -p udp --dport 514 -j REDIRECT --to 1514
service iptables save
What is your syslog coming from? Your input is syslog UDP, maybe you are sending syslog TCP?
I have checked the syslog is using UDP protocol.
Hello @teamonelove
Not sure if you have seen this post , but it may have some ideas on how to fix this issue.
It does some Iptables configurations shown from this member also.
Hi gsmit,
Thank you for your reminder,It turned out that my iptable was not started… Now the problem has been solved, thank you for your help. :grinning:
It happens to all of us at one time or another :laughing:
If you could make this as resolved that would be great :+1:
